12-04-2019, 06:17 PM | #1 |
Rep 2
Software update - no welcome external lights
I picked up my car yesterday after the software update. I noticed the external welcome lights no longer lit up as I walk towards my car. Anybody experienced the same issue?
I check the settings in idrive, all the boxes were checked for headlights, side lights and handle lights. thanks! |
12-04-2019, 07:28 PM | #2 |
13216
Rep 19,694
There was a discussion on this the other month. I think we determined that now the welcome lights only work if you have comfort access enable to unlock the doors. Mine light up and have it set to unlock. You may want to do a search and get confirmation.
12-04-2019, 07:37 PM | #3 | |
134
Rep 326
12-05-2019, 06:09 AM | #4 |
Rick James
305
Rep 784
12-05-2019, 06:44 AM | #5 | |
134
Rep 326
12-05-2019, 09:39 AM | #6 |
Rick James
305
Rep 784
homerrr Ok, good to know. I know on 07/2019.70 does have the pathway lighting, but I do have comfort access turn on. I just hate how "dumb" the comfort access can be if you need to unload something from your car. The lock, unlock, lock cycle gets annoying! Especially with the acoustical confirmation.
12-05-2019, 09:50 AM | #7 | |
134
Rep 326
12-05-2019, 09:54 AM | #8 |
Rick James
305
Rep 784
homerrr I need to do that. I don't see the point of the unlock since the handle grab unlocks it anyway. The proximity is nice, but is a nuisance. Do you have any problems with the vehicle not locking when walking away? I happens maybe 1 out of every 10 times.
12-05-2019, 10:23 AM | #9 | |
134
Rep 326
12-05-2019, 10:38 AM | #10 |
Rick James
305
Rep 784
That's probably it. There are so many what ifs, and it is definitely user error. The worst, the car not powering down when opening the door. If I am on a call, hang up, and get out...iDrive does not power down. However, if I am just listening to music, stop and down down, then open the door...iDrive shuts down. These are first world problems, so I'll take it.
01-15-2020, 07:28 PM | #12 |
134
Rep 326
01-16-2020, 09:08 PM | #14 |
Rep 2,609
The question was: "Confirm you have welcome lights come on without the car unlocking when approaching?" There is a reason it was asked that way. Can you please answer the asked question.
01-16-2020, 10:20 PM | #15 | |
805
Rep 1,790
There are exterior light settings in iDrive where you can set these parameters. You can also disable the carpet lighting altogether. General information Depending on the equipment, the exterior lighting of the vehicle can be set individually. Activating/deactivating Via iDrive: "CAR" "Settings" "Exterior lighting" Select the desired setting: "Welcome and goodbye" When unlocking the vehicle, individual light functions are switched on for a limited time. "Door handle lights" Door handles and the ground in front of the doors are illuminated for a limited time. "Welcome Light Carpet" The area next to the vehicle is illuminated for a limited time. |
01-16-2020, 11:10 PM | #16 | |
13216
Rep 19,694
For 07/2019.55 I can confirm that the lights come on when approaching the vehicle without the doors being unlocked but once I get closer then the doors do unlock. In this case the welcome lights come on without the doors being unlocked but I do have it set to unlock so it is just a timing issue. From what others have reported, if I didn't have it set to unlock the welcome lights wouldn't come on. |
01-17-2020, 01:21 AM | #17 | |
805
Rep 1,790
It would just be easier for the OP if someone told him how it's supposed to work based on how the available settings are configured so he can troubleshoot the problem. |
01-17-2020, 05:53 AM | #19 | |
134
Rep 326
Thanks for the clarifications y'all |
01-18-2020, 12:56 PM | #20 | |
805
Rep 1,790
Pretty freaking obvious those idiot Engineers at BMW don't test "EVERYTHING" before releasing their updates. Either that or they knew it broke the Welcome Light functionality but felt the other enhancements/bug fixes in this version were worth bricking other functionality/options. Typical crap for the IT Industry! Last edited by mitch57; 01-18-2020 at 01:05 PM.. |
01-18-2020, 10:52 PM | #21 |
Rep 253
Something small but my welcome lights were not working and after a bit of troubleshooting i realized it wss due to the interior lights being switched off (i had disabled them the week before by holding down middle dome light for over 3 seconds)
Small chance but worth a try. |
01-19-2020, 05:24 AM | #22 |
Rep 79
Correct. I have tried it a few times. Closing trunk and while trunk is closing running away from the car doesn't close the doors 2 of 3 times.
