02-02-2022, 03:08 PM | #23 |
Rep 2,946
Drives: 2020 BMW 530xe
There are risks in the system as none of these will be perfect no matter how much code and sensors there are...
I believe, can be corrected if wrong, you can override it using the gas pedal. I believe you have to take your foot off the gas then apply gas again to override. If it applied it while you were accelerating it won't listen if you press harder. At least on my car and this is faint memory from the one rare time I had it engage when I was doing 70MPH. Overriding it took a second and was a non-issue... In my case I think it was the sun hitting the camera in just the right way to cause a significant shadow. But generally you want to keep your windshield and sensors as clear as possible. So use the wash function regularly especially in snowy and road salt conditions... If the system detects bad weather it will turn itself off, but that's not perfect I imagine. Either way, report it to NHTSA. The only way to get the government to know they need to force a recall or tweaks is to let them know... https://www.nhtsa.gov/report-a-safety-problem They are actively trying to compile data on this stuff. |
02-02-2022, 04:09 PM | #24 |
Rep 4,246
Though I've never experienced a situation where the system applied braking as you described.
I've experienced recent conditions where I'm traveling on the VA Express Lanes with active cruise, alongside local highway traffic crawling, and the system falsely detected slow traffic ahead and applied short emergency braking but resumed. It only happened once. I discerned it to the radars detection local traffic through the light barrier poles running along side express and local traffic.
02-02-2022, 08:50 PM | #25 |
Rep 75
this is concerning. one of the reasons why i am getting a new car is because i wanted the preventative safety features. the car i traded in only had collision warning, not mitigation. looks like the features are still not fully tuned.
02-02-2022, 10:55 PM | #26 |
185
Rep 355
I'm sure the manufacturers would assure you that 99.99% of the time, the car behaves exactly as intended, and only 0.01% of the time does it possibly do random dangerous stuff. So you're basically fine; if you drive for 10,000 seconds, maybe one of those will have a random swerve into another lane or slam on the brakes from 80mph, but the other 9999 seconds will be smooth sailing.
Granted, that might be a bit optimistic; in my experience, it's probably only ~3000 seconds between each random false-positive intervention from lane departure assist while on the freeway, but you get the idea. |
02-02-2022, 10:56 PM | #27 | |
Spencer Gotts
12
Rep 12
bayarea328xit500.50 |
02-02-2022, 10:58 PM | #28 |
Spencer Gotts
12
Rep 12
02-02-2022, 11:00 PM | #29 | |
Spencer Gotts
12
Rep 12
02-02-2022, 11:02 PM | #30 |
Spencer Gotts
12
Rep 12
02-02-2022, 11:06 PM | #31 | |
Spencer Gotts
12
Rep 12
02-02-2022, 11:10 PM | #33 | |
Spencer Gotts
12
Rep 12
02-02-2022, 11:17 PM | #34 |
Rep 793
Wow that’s scary and concerning but I was not completely surprised it would do such thing. My iDrive rebooted itself completely once when I was turning into a street with moving cars. The whole screen was blacked out. I thought it would stop and be rear ended. Scary as &$&$. My front sensors randomly stop working. I randomly get alert for the front camera for no reason. I randomly get uneven surface alert when the road is just as flat as it can be and none when it was supposed to. So your car probably “saw” something. I would definitely file a complaint. The more we know, the more I wonder if it’s worth the “driving experience”. Bmw should have done a better job testing their new products. Hope you get over that feel soon. That rebooting stayed on my mind for a good period.
02-03-2022, 12:39 AM | #35 |
Rep 459
I've had this happen in my 2020 G06 maybe 3-4 times in 2-years and 24,000+ miles. In pretty much all of the cases, I saw the large, red, flashing car, got the "beep, beep, beep" (I think it's 3 quick beeps/chimes) and it briefly applied emergency breaking. I either took control or it discovered there was nothing there within maybe a second and the alarm and breaking ceased.
Never anything as severe as the OP indicated and I think there was nothing consistent about the occurrences. I'm pretty sure I've never had the seat belts lock. (I think I had ACC on 2 of the times, one time I know I didn't, which was the most significant one (partly because I was slowing down to a stop sign at about 20 miles an hour, so even a brief emergency break brought the vehicle to a near complete stop...)) I had the same thing happen on our F15, but that's always the same scenario. ACC is enabled, passing a semi on the interstate, and the semi serves towards and maybe barely crosses the center line. The radar/sensors pick-up on the "crowding" and will apply a brief emergency stop until I take over...Probably happened at least a dozen times or more in about 7 years and 90K miles... But, as was mentioned, it's probably saved me more than any "scare" I've had in false alarms. The worst thing for me tends to be the "scream and stare" from my wife and the "What are you doing?" question...
2020 BMW X6 (G06) M50i - Manhattan Green/Coffee - 11/2022.63
Auricom4361.50 |
02-03-2022, 12:36 PM | #36 |
Rep 202
This happened on my MY'22 a month ago. I was on a local road driving 30mph, car in front moved to the middle turning lane. My car freaked out, it showed red cross traffic warning and slammed on the breaks bringing the car to a halt. Guy behind me almost hit me.
02-03-2022, 05:21 PM | #37 |
Rep 62
Though I didn't get stuck my 2018 530e did do this twice - once while exiting the garage and once in front of the garage. Both times were when going from shade to full bright sun.
2019 BMW X5 40i (PCD)
2018 Tesla Model 3 2018 BMW 530e Hybrid (early return) 1990 BMW 735i 1984 BMW 533i (missing it) |
sigmabody185.00 |
02-03-2022, 05:36 PM | #38 | |
Spencer Gotts
12
Rep 12
02-03-2022, 05:56 PM | #39 |
Rep 6,806
On my last long road trip, I was going around a curve on the interstate, a tractor trailer crowded my lane, the X5 showed a warning, and moved out of its lane to keep some distance. The times when it has intervened, it's been understandable.
What version of software do you have in your vehicle? Each OTA update improves and hopefully fixes glitches they find. Some people avoid doing any updates which may not be wise in the long run. If there's a glitch in your system, it may not even try to update, which should call for an intervention. |
02-03-2022, 06:09 PM | #40 |
185
Rep 355
It sounds like BMW is not the only manufacturer struggling with this issue, as per this article today: https://www.cnn.com/2022/02/03/busin...ing/index.html
02-03-2022, 06:17 PM | #41 | |
185
Rep 355
But totally agree with the psychological aspect: I learned to trust my Acura's lane keeping assist, because it worked well most of the time, and when it didn't, it just disabled. The BMW, on the other hand, can't do lane keeping without also cruise control (which you can somewhat mitigate by reducing the cruise speed manually down to some low number, but that's tedious to do manually every time), and when it gets confused it tends to swerve rather than disable. The Acura was nowhere near the overall quality of the BMW, and I wouldn't call their driver assistance software "good", but it looks good in comparison. I'd say the quality of the driving assistance software, or lack thereof, is the largest disappointment for me with my BMW. |
02-03-2022, 06:23 PM | #42 | |
13276
Rep 19,807
02-05-2022, 12:37 AM | #43 | |
Rep 193
2022 X6 x40i MSport black sapphire / Cognac
