02-29-2024, 10:45 AM | #1 |
11
Rep 47
Remote software upgrade tips!
See picture.
Remote update was downloaded but not installing. Followed the process ( parked car, headlights off, windows up, etc) but not installing. I’m thinking this is also the reason my avatar/profile picture isn’t updating either even though it updated on the app. Any idea how to get this update to go through without going to a dealership? ( warranty expired so they will probably charge me for that) |
02-29-2024, 10:52 AM | #2 |
13275
Rep 19,805
So far the answer has been elusive.
I think most take this approach:
slilley45.50 thereef5101165.00 |
02-29-2024, 12:58 PM | #4 |
Rep 6,806
If you have a battery charger, put it on the vehicle. Depending on how big it is, it could actually take a couple of days. The batteries in the vehicle must be above a certain level prior to it starting the update, and especially in the winter, they may not be.
This doesn’t resolve it all of the time, but it is a reason the update won’t start. I wish BMW would tell you why it won’t start, rather than leaving you hanging. |
02-29-2024, 01:26 PM | #5 |
Rep 4
How do you start the download to your phone? 2022 g06
ThomC.X5MC7.50 |
02-29-2024, 01:44 PM | #6 |
13275
Rep 19,805
BMW does not support updates on demand so it is not possible to download the update unless notified that it is available for your vehicle.
02-29-2024, 03:11 PM | #7 | |
Rep 63
02-29-2024, 03:31 PM | #8 |
Rep 169
My car successfully downloaded it and it did prompt me one time to install, but I was leaving for work so I said remind me later, and it has never prompted me again. I did throw it on the charger yesterday, but it did not help. Very strange.
SCBMW02125.00 |
02-29-2024, 03:34 PM | #9 |
13275
Rep 19,805
That is "normal" as it happened to me and some other members. My brother actually texted me yesterday asking about it since his offered the update but he wanted to wait until after a road trip he was taking, it never offered it again.
02-29-2024, 04:03 PM | #10 |
Rep 116
Drives: 2024 X5 50e LCI
One thing I experienced that may get over looked, is make sure the parking brake is set. I have seen my two G05's update with and without the parking brake set. You might even see a check list to remind you of the requirements before you can proceed, depending on the version of software your are upgrading from.
X3_Alaska142.00 |
02-29-2024, 04:11 PM | #12 |
Rep 508
Drives: 2022 X5 xdrive40i msport
I found out on my last update that you need to be parked and have parking break on and it goes from letting you know when it's ready to be installed to You can install. I got that same message and waited and waited etc...
02-29-2024, 04:11 PM | #13 |
13275
Rep 19,805
Why do you do that? Do you mean instead of taking a drive?
02-29-2024, 04:14 PM | #14 |
Rep 508
you have to take a drive with wifi and bluetooth connected so the phone app can upload the update to idrive for installation. After that it's ready to go after successful upload completion.
you will then get the message it will let you know when it is ready to be installed. It has to prep the upgrade before you can apply it. |
02-29-2024, 04:20 PM | #15 |
Rep 97
Be patient, it will prompt you to install eventually. Mine took a couple of days. It's not a major update so you're no really missing anything with this update anyway.
02-29-2024, 07:33 PM | #16 |
Rep 169
Another strange bug I noticed. Even in my heated garage the temperature continues to display 17°f. Even if I start the car and put it in gear it continues to display that same temp. I think the temperature has to be above 48° or so for the update to install right?
02-29-2024, 07:40 PM | #17 | |
13275
Rep 19,805
X3_Alaska142.00 |
02-29-2024, 09:38 PM | #18 |
Rep 169
03-01-2024, 07:54 AM | #19 | |
110
Rep 318
Mine didn't update for several years - always had to get the dealer to finish it off from the 'preparations complete' stage. They told me it was because I do not use the car much (its a second car used only on weekends - late 2019 with mileage not even hitting 15k yet!) and the battery was probably sitting at a low charge. They updated for me, and never thought much of it. Couple of weeks back I hooked up a battery tender (I've started doing this every few months) and a week later I was informed of an update - here we go again I thought - but to my surprise this time it actually went through the install perfectly fine - first time ever! I think it has more to do with battery levels then anything else.... yes, if its super cold outside, then this will affect battery levels also..... |
03-01-2024, 01:57 PM | #21 |
Rep 401
Wondering why my app downloaded 03/2023.67 when others here are showing 03/2023.50? Different X5 model?
I am in the same boat - downloaded to the vehicle but does not instal (with fully charged battery, parking brake and level ground). I was hoping to update once before getting my anti dazzle coded. Oh well. |
03-01-2024, 02:04 PM | #22 | |
13275
Rep 19,805
