01-11-2021, 09:55 AM | #45 | |
Schmollbraten
12512
Rep 1,985
Would you mind to list all the specific SMD's and amount for the referring place where installed, that would be high appreciated.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
01-11-2021, 05:58 PM | #46 |
1070
Rep 1,812
Make sure that circuits aren't crossed with new solder or that all circuits are completed. I'm guessing some solder may be shorting something out.
01-12-2021, 02:27 AM | #47 | |
26
Rep 47
But I like to work on this stuff yes, all of my previous cars had something very specific which was I created. At my previous car I bought a diffusor which was slightly different then what I wanted, so I cut pieces off, and used fiberglass and fillers to adjust and shape it perfectly. In another car I build a complete high-end sound system and adjusted a lot. I'm a perfectionist, so I'll work on just about anything, not scared to discover new stuff, and take things apart. It needs to work and look like high-end OEM, so I spend a lot of time on perfecting the details. Another thing I'm annoyed about is the screen and navigation, also looks outdated/low-res, even though I have the big screen and prof. navigation with live traffic. So I want to upgrade that to an Android system soon. Then I'm done with interior for now, and will move to the outside. |
01-12-2021, 02:37 AM | #48 | |
26
Rep 47
Dashboard section - LED 1206 - 30 pcs / LED 3528 -38 pcs / LED 0603 - 8 pcs - [x] Cluster - LED 3528 x 12 white - [x] Headlight switch - LED 1206 x 6 white - [x] Laneswitch/warning buttons - LED 1206 x 2 white - [x] Steering wheel buttons - LED 0603 x 8 white - [x] Start/stop button - LED 1206 x 3 white/blue - [x] Doorlock + Emergency light buttons - LED 1206 x 1 white - [x] Climate control ambient light - LED 1206 x 4 - blue/white - [x] Radio controls - LED 1206 x 12 - 10 white/2 blue - [x] Airco controls - LED 3528 x 22 white - [x] Cupholder ambientlight - LED 1206 x 2 - blue/white - [x] Footwell lighting left - LED 3528 x 2 - blue/white - [x] Footwell lighting right - LED 3528 x 2 - blue/white Midconsole - LED 1206 - 27 pcs / LED 0508 - 8 pcs - [x] Parking + sport buttons - LED 1206 x 5 white - [x] Gearknob - LED 1206 x 7 white - [x] iDrive buttons LED 1206 x 7 white - [x] iDrive halo LED 0508 x 8 blue Ceiling front - LED 1206 - 7 pcs / LED 3528 - 4 pcs - [x] Ambient lights - LED 1206 x 4 blue/white - [x] Light control buttons - LED 1206 x 3 white - [x] SOS + Airbag - LED 3528 x 4 white Ceiling back - LED 1206 - 7 pcs - [x] Ambient lights - LED 1206 x 4 blue/white - [x] Light control buttons - LED 1206 x 3 white Doors - LED 1206 - 11 pcs / LED 3528 - 7 pcs - [x] Front left controls (driver) - LED 3528 x 7 white - [x] Front left ambient - LED 1206 x 2 white/blue - [x] Front right controls (passenger)- LED 1206 x 1 white - [x] Front right ambient - LED 1206 x 2 white/blue - [x] Back left controls - LED 1206 x 1 white - [x] Back left ambient - LED 1206 x 2 white/blue - [x] Back right controls - LED 1206 x 1 white - [x] Back right ambient - LED 1206 x 2 white/blue |
01-12-2021, 04:58 PM | #49 | |
1070
Rep 1,812
01-12-2021, 05:34 PM | #50 |
1070
Rep 1,812
Holy balls these 0805 LED's are super tiny! Does a regular soldering iron work with these things? I've soldered things before and I'm comfortable doing so, but I've never work with such small components lol.
01-12-2021, 06:32 PM | #51 | |
26
Rep 47
01-12-2021, 06:40 PM | #52 |
26
Rep 47
I guess you didn't see the 0603 leds in the steering wheel those are the tiniest ever! It is doable if you have the sharpest soldering tip, and a stable hand. You need to melt some wire on the pads and the led itself, and then positioning them perfectly, and heating up both ends. That should do the job, but I did melt away some leds while doing it, so be sure to have extras laying around
01-13-2021, 12:43 AM | #53 | ||
Rep 178
01-13-2021, 08:35 AM | #55 |
Rep 595
Yeah that was my thinking but I can't see anything to cause the issue. I've ordered a second hand button for £15 just incase I can't get it sorted.
01-16-2021, 12:44 PM | #56 |
1070
Rep 1,812
My blue/white replacement LED's for the front/rear door panels and footwell finally came in from benzinfabrik.com yay!
OMG you should see the box it's destroyed and wet and has some other liquid on it it's disgusting. It seems like it was dropped outside when being loaded on a truck and was left outside for who knows how long. After 3 weeks it finally hit New Jersey (from tracking) so I believe it arrived at the New Jersey international hub and was lost and finally scanned. I'm amazed the products are still inside the box and undamaged honestly. I'll post some pics of the box later lol. Now to install these bad boys! I'll post pics when it gets dark after I get them installed hopefully it goes smoothly and I can get it done today. Last edited by eff32fl; 01-16-2021 at 07:37 PM.. |
01-16-2021, 05:26 PM | #57 |
1070
Rep 1,812
Well I got the 2 front door panels and 2 footwell LED's replaced. I ran out of sun light and couldn't finish installing the 2 rear panel LED's so will have to finish up tomorrow. I also have replacement LED's for the radio trim but no promises on how that's going to go lol that LED is TINY. I got extras though It's looking super awesome so far!
It was weird and kinda scary, after I put the passenger door panel back on after upgrading the LED module the top of the door panel was getting hot not a little warmth from sun contact but like an electrical type of hot. I disconnected the battery and took the door panel off so I could see what was heating up (thought maybe something was shorting out) but it stopped thankfully. I put the door panel back on gently and it's been fine since. Weird! After all that my PDC stopped working and my car was throwing all kinds of errors in Bimmerlink. I cleared all the errors and went for a drive and my PDC started working again. I think it was from the battery being disconnected and various systems have to initialize and it's not an instant type of thing. |
01-17-2021, 11:19 AM | #58 | |
Schmollbraten
12512
Rep 1,985
But a (maybe silly) question for converting the LED types: I got installed into my doors for the ambient light type 5630/5050 modules (smaller black ones) and into the foot well type 2016 (bigger white ones); you could find pictures of the sealed bags at first page of this thread. How to find out why yours are designated as 1206 for the doors and 3528 for the footwell? According to some pictures they look complete different to mine
01-17-2021, 05:04 PM | #59 | |
26
Rep 47
For example the "halo" on the iDrive originally has round LEDs which exactly fit in the holes of the PCB board. I couldn't find those, so I tried it with the 1206 LEDs. Those also worked perfectly fine, even though they have a rectangular shape. The brightness was better, the soldering was sturdy. It's trial and error, I had certain type of LEDs lying around, and I read on other forums that they used the 1206 type. That's why I went for it. Hope this answers your question a bit |
Dang3r12512.00 |
01-18-2021, 06:26 PM | #61 |
1070
Rep 1,812
I attempted to replace the LED's in my radio trim but without much success. I got it all taken apart but these things are too tiny to handle and my soldering skills aren't up to par, with something this small at least.
I'm going to go to an electronics repair shop and ask them to do it for me. This shoots down the possibility of changing out the other LED's in my car but oh well. Soldering super tiny components isn't my forte apparently lol. I tip my hat to you guys that managed to do this successfully! |
01-18-2021, 06:48 PM | #62 |
1070
Rep 1,812
Here are the pictures after the ambient lighting was upgraded to blue. My phone's camera distorted these a bit but you get the idea. I love the new look! Ignore the front trim that's still removed lol.
01-18-2021, 07:40 PM | #63 | |
26
Rep 47
I also emailed them with the question if they are planning to make the LED parts for the radio trim, and their answer was YES! They are launching these LEDs in february some time. So if I were you, let it go for now, and order those when they are online. I am going to do the same, because also with the radio trim they don't light up that much. |
01-18-2021, 07:52 PM | #64 | |
1070
Rep 1,812
That's great news that Benzinfabrik is going to offer the radio trim replacement LED board soon. Yeah I should just wait to order from them. That's right around the corner too! They definitely offers a great product. Sure beats the Chinese junk you see on Alibaba! |
01-19-2021, 03:44 AM | #65 |
Schmollbraten
12512
Rep 1,985
Yeah, those are really good news and then I would wait until they release the Radio trim LED's. Do we have a DIY somewhere how to remove the Radio/Climate trim from the Panel? Hadnt done this before and wouldnt break the small holders.
01-19-2021, 06:16 AM | #66 | |
26
Rep 47
Dang3r12512.00 |
