M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > EC7 Wheel Sizing
      05-02-2024, 07:47 PM   #1
Alanine
17
Drives: 2017 M2
EC7 Wheel Sizing
I’d love to order some EC7 wheels for my OG in 19” and am trying to pick the front wheel which will fit my setup:
M Performance Suspension at suggested ride height of 595/600
Factory top mounts (no camber adjustment)
It seems that Apex recommends either the 19x9.5 ET 28 with a 5mm spacer, or the unspaced 19x9.5 ET22. I’d prefer to run without spacers, so the question is, at the recommended MPS ride height (595mm) and with a 255/35/19 front tire, will I encounter rubbing without camber plates?
I appreciate it depends on the tread width of the tire I choose. I’m planning on running a street oriented tire like the PS4S or one of the new Contis in that class.
I’d be interested to hear from anyone who has a similar config. Bonus if you have any pics too! An ET22 9.5” wheel will poke out about 13mm further than the OEM wheels and I don’t want it to look goofy. I guess I could simulate it with a 13mm spacer on my OEM wheels?
Thank you!
      05-06-2024, 05:04 PM   #2
Dabozo
Dabozo's Avatar
635
Drives: 17 M2 BSM MT
I have apex vs5rs wheels. Front is 9.5 x et22. Will take a pic for you shortly.
Granted it will be with oem rubber so it’s a bit stretched. But you’ll get a sense of the stance/poke. I don’t think it looks bad. But I’m def switching out tires. Thinking 255/35 or 265. I have a similar question re fitments in another thread.
      05-06-2024, 09:55 PM   #3
Dabozo
Dabozo's Avatar
635
Hope this helps. Forgot to mention that I have 12mm spacers fitted temporarily. So keep that in mind.
Alanine16.50
      05-08-2024, 12:57 AM   #4
Alanine
17
Drives: 2017 M2
Thanks very much for the pics! Those are all of the rears, correct? It’s the front offset/poke that I’m most concerned about. Cheers!
      05-08-2024, 09:45 AM   #5
Dabozo
Dabozo's Avatar
635
oh my bad...not sure why i put rears in my head when i snapped those lol...Ill upload the fronts in the next hour or so...The +22 does give me the slightest of poke it looks like...but hard to be certain since the rubber is oem and stretched at the moment...I feel like i made a mistake with these 22's ...its limiting my options for tires!
      05-08-2024, 03:09 PM   #6
Dabozo
Dabozo's Avatar
635
Hope this helps!
Telluride135.50
Alanine16.50
      05-08-2024, 10:52 PM   #7
Telluride
Drives: 2020 M2C
Originally Posted by Dabozo View Post
Hope this helps!
Looks good!
I don't know if I've seen a black M2 with front mud flaps. I like because I barely noticed them. You a fan, which are they and what was the install process? Thanks.
      05-09-2024, 12:56 AM   #8
Alanine
17
Drives: 2017 M2
Dabozo thanks for the pics!
Dabozo635.00
      05-09-2024, 06:58 AM   #9
Dabozo
Dabozo's Avatar
635
Originally Posted by Telluride View Post
Looks good!
Thanks!
AutoTecknic F87 M2 / F87 M2 Competition Carbon Fiber Front Splash Guards
https://autotecknic.com/products/aut...-guards-f87-m2
Installation is easy and straightforward and will take no longer than 20 min for both sides. The package includes a pair of carbon fiber splash guards and rivets for the F87 M2 and F87 M2 Competition.
Telluride135.50
      05-09-2024, 09:04 AM   #10
aatlas
aatlas's Avatar
215
Drives: 2020 M2 Competition
19X9.5 et22
19X10.5 et45
These photos were taken with 10mm FC spacers all around and the oem spec mpss tires.
No Rubbing
Ohlins ride height:
F: 590mm
R: 595mm
-3 Camber in the front
-2 Camber in the rear.
Get the et22’ up front..
Ohlins RT/SPL/Millway
Paragon/Pagid
BMC/Active EL/Remus Race
BBS e88/513m
IG: @aatlas_M2C
Appreciate 3
Dabozo635.00
Alanine16.50
Telluride135.50
      05-09-2024, 10:05 AM   #11
Dabozo
Dabozo's Avatar
635
so clean....looks amazing!
aatlas214.50
      05-09-2024, 05:35 PM   #12
Alanine
17
Drives: 2017 M2
Originally Posted by aatlas View Post
19X9.5 et22
Love the pics!!! Do you still recommend ET22 if I keep OEM top mounts (i.e. standard camber) and run a 595mm front ride height? I don't plan to use camber plates.
      05-09-2024, 08:34 PM   #13
aatlas
aatlas's Avatar
215
Yeah, I’d still go with et22
Paragon/Pagid
BBS e88/513m
IG: @aatlas_M2C
Alanine16.50
m2
