2010 2011 BMW 5 Series Forum F10 Lets build an LCI MSport wheel and retrofit it! |
09-20-2017, 03:31 AM | #23 | |
Rep 2
The -paddle Off : 5.3kohm On : 1.283kohm The +paddle did match : 5.3kohm off and 2.297kohm on. Anyway, I read your message wrong the first time. You said you were going to source SMD resistors in the right values. I read that as - get the same resistors that are now on the F10 paddles. Of course, you meant getting resistors to achieve the same off/on values as the F10 paddles are measuring. My bad. Now ordered again. It's a good thing these smd's are cheap Edit : I stand corrected. Your measurements were on point. I'm an ass and measured the testpoints instead of the cable. Hence my bad reading for the - paddle. They work ! So thank you ! Last edited by idog; 09-21-2017 at 12:55 PM.. Reason: I'm an ass |
08-31-2018, 03:45 AM | #24 | |
Rep 30
09-13-2018, 06:04 PM | #25 |
Rep 30
In case anyone else stumbles across this thread trying to retrofit F30 paddles on an F10 I thought I’d clear up what resistors go where. The down paddle requires removing both resistors and placing a 1.691k ohm resistor on the bottom pad where the 348ohm resistor was. The up paddle needs both resistors removed and replaced with a 2.2k ohm and 3k ohm resistor.
The readings on a multimeter will match for the down paddle but will differ on the up paddle. Expect 5.18kohm not pressed and 2.192kohm pressed. The F10 paddles read 5.361kohm not pressed and 2.297kohm pressed. It’s a negligible difference and doesn’t affect the operation. Thanks to my dad for his help |
01-20-2019, 06:44 AM | #26 |
Rep 16
Fitment of a F30 M Sport Steering wheel to a F10
Hey guys,
Idk if this is a foolish question. But I'll go ahead. While skimming through the used LCI version M sport steering wheels on eBay I came across that F30 version M Sport steering wheel is much cheaper than the F10 version. Is it possible to retrofit the F30 m sport steering wheel to a F10? It looks the same but don't know whether it's retrofittable. F30 versions are pretty cheaper. Have a look @ this one. |
01-20-2019, 02:29 PM | #27 |
Rep 1,397
01-20-2019, 04:29 PM | #28 | |
Rep 30
08-06-2019, 08:45 PM | #29 |
Rep 254
I purchased a wheel online and it came with an airbag without the blue sensor, does anyone have any solutions for this or should I return it? I don't think BMW sells just the harness nor do I think I can reuse the harness and sensor from my old wheel.
08-06-2019, 10:04 PM | #30 | |
Rep 5,389
08-07-2019, 08:20 AM | #31 | |
Rep 254
02-21-2020, 10:56 AM | #32 |
Rep 808
So if I get LCI f10 paddles they will work on a pre lci f10? I got some paddles for my pre lci f10 and it's doing what you're talking about when I put the car in drive, goes right into manual mode and goes crazy.
05-13-2020, 03:08 AM | #33 |
Customize Everything!
44
Rep 279
[ATTACH][ATTACH][/ATTACH][/ATTACH]Can someone assist me with the airbag light issue. I just installed the M sport wheel and I have that dreaded airbag light that will not go away. Is it a matter of coding or do i have to buy a new airbag? The old steering wheel airbag did not throw the airbag light after further troubleshooting. But the new airbag did.
when i went to install the old wheel cause i was fed up, the light came back on with the old wheel now. So I essentially am committed to resolving this issue and keeping the new wheel on the car. But need to get this airbag warning light issue resolved. Airbag is US spec. See a couple of pictures before and after below. |
05-13-2020, 03:12 AM | #34 |
44
Rep 279
I have the same airbag and same issue now....how did you get yours to work? Did you get a new airbag?
05-30-2020, 08:58 PM | #35 |
Rep 277
Did you get this sorted? I'm curious to know if F10 LCI paddles and steering wheel are straight plug n play to preLCI or just coding required?
07-18-2020, 11:15 AM | #36 | |
Rep 34
I know I am super late to the party but I did this similar retrofit (went from pre-LCI non sport wheel with paddle shifters to LCI M sport wheel with shifters), so my car already had the paddle shift function. After doing the swap, everything works except my shifters... And I was under the impression that at least the minus paddle shifter should be working since the resistance is the same between pre LCI and LCI (but not 100% sure on that). I am getting the error code "No message (operation of shift paddle, ox207): Receiver EGS, transmitter FEM/SZL". With that being said I am wondering if doing the resistor swap on the LCI paddles will even cure the problem. Please let me know. I can give you detailed pics etc. Thank you. |
07-18-2020, 11:17 AM | #37 |
Rep 34
11-25-2021, 04:21 PM | #39 |
Rep 3
i have a big question: i can use the module and the vibration motor from f30 m steering on my f11 steering wheel ? (i have f10 lci m sport steering wheel retrofited at my f11)
i hope you understand my english |
11-26-2021, 12:24 AM | #40 | |
Rep 1,356
The module will not work. Only 5 and 6 series are interchangeable (F07, F10, F11, F06, F12 and F13) |
11-28-2021, 03:52 AM | #41 |
Rep 3
03-15-2024, 04:36 AM | #44 |
Rep 26
Drives: BMW 218i Coupe
My retrofit does not work and I honestly think that the cables of the harness (especially the ones that are supposed to feed the shifters are in the wrong order). Would it be okay to use a multimeter to check if there is a voltage running on the live circuit of the paddles or would that cause any issues?
