02-02-2010, 08:52 PM | #1 |
Rep 92
Any coupe owners get their headliner done?
One of the reasons i wish i got the ///M was because of the black headliner. I'm tired of the grey. I was wondering if anyone had theirs done? If so, what material did you use? I'm thinking alcantara would look nice and be durable enough.
My big worry is having someone tear my interior apart. Is it easy to remove the pillar trim and headliner myself? |
02-02-2010, 09:40 PM | #2 |
Rep 969
pillar trim should be easy - it normally pops off and is attached with slide clips of some sort. I'd check out the guys that replaced their roofs with a CF one because I'd imagine the procedure is nearly identical to a certain extent.
Plenty of people on other forums and cars replace their headliners with suede. In terms of a wanting an M for the headliner... well that's a debatable reason why! LOL Good luck. I would def use a professional for the wrapping portion of the project. Glue stains etc never look good when an amateur does it.
911 Carrera project car
Previous: E92 M3 ZHP - Sold E86 Z4M - Sold E36 M3 - Sold |
02-03-2010, 01:34 AM | #3 |
44
Rep 380
Great idea..My car is Black sapphire and she has imola interior..I want my headliner and pillars imola How can I do it??
Z4MC_Black Sapphire/Imola-_-DMS ECU ll H&S cat-back ll H&R coilovers ll CF Lip ll Lamin-X ll Matte black kidneys ll Afe drop in ll Afe intake elbow ll RPi scoop ll LeatherZ imola shift boot ll ZHP knob...
02-06-2010, 01:25 AM | #4 | |
Rep 92
Also, make sure you find real alcantara and not 2nd tier ultrasuede. You can get lucky on ebay, but to guarantee you'll get the right stuff you'll want to go to gulffabrics.com. And if you're going to diy, use 3M hi-strength 90 spray adhesive. |
02-06-2010, 09:22 AM | #6 | |
Engineer
216
Rep 2,122
Drives: M235I 2015, 335i 2011
just to let you know in case you brake something. |
02-07-2010, 12:55 PM | #7 | |
44
Rep 380
03-12-2010, 06:25 PM | #9 |
Rep 2,747
Does anyone know where to get real alcantra material?
LINK TO 07 IR PHOTO JOURNAL:http://www.zpost.com/forums/showthread.php?t=1303735
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 |
03-12-2010, 06:38 PM | #10 |
Rep 4,320
Drives: '07 Z4 M Coupe
03-12-2010, 07:53 PM | #11 | |
Rep 2,747
05-25-2011, 01:17 PM | #16 |
instagram 997turbotom
284
Rep 7,377
I use loctyte performance adhesive, after sitting in the sun all day, it holds MUCH better than the 3m shit. found in home depot
07-12-2023, 06:16 PM | #17 |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Decade bump. I left my car with a new speed shop who after completing the work, left the car outside for 1-2 days. With the scorching heat we’ve had recently, it apparently melted the glue and my headliner is now sagging, sigh.
I’ve seen write ups on how to remove the headliner but my question is there anyway to salvages (repair) the liner? Or is replacement cloth most likely required? Also does anyone know how much a good upholstery shop charge for something like this? I much prefer mechanical work than fiddling with interior pieces and clips - knowing me I just don’t have the patience. |
07-12-2023, 07:02 PM | #18 |
Rep 2,875
Drives: Anything
It's not repairable as far as what I've been told. The fabric is glued to a thin foam and most of the time it's the foam that is crumbling away.
Not sure if you had seen this post => https://www.bimmerpost.com/forums/sh...php?p=30270846 I just had my headliner, A/B pillars done in Alcantara. The cost can vary drastically depending on the shop...so you'll have to shop around. The first shop that I got quoted was around $2k. Then someone from one of the M3 forum recommended a nearby shop that did a wonderful job for about $800! They told me that doing it in the original fabric would cost similar, so I went with the Alcantara upgrade.
07-12-2023, 08:38 PM | #19 | |
2289
Rep 12,565
07-12-2023, 08:43 PM | #20 |
Rep 2,875
Drives: Anything
I left the car with them and picked it up the next day. The shop owner told me that I was the 4th or 5th coupe that they did and in fact just finished an Interlagos coupe a couple of weeks prior to doing mine.
07-12-2023, 09:25 PM | #21 |
2289
Rep 12,565
Thanks, very helpful. Wondering if I should buy a used headliner for less (with the risk it may too come apart some the road) or pay up and retrim my existing one.
07-12-2023, 10:03 PM | #22 |
Rep 2,875
Drives: Anything
I had thought about that as well, but ultimately I just told myself just do it once and be done instead of messing around with a used one that ultimately will end up suffering the same fate since this was the time frame that the German automakers were switching to the water-base adhesive. Both of the upholstery shops that I visited said they are doing a lot of headliners from this genre, especially Caymans.
