07-19-2020, 09:17 AM | #1 |
Rep 228
11/2019.70 OTA UK Rollout
Just got the push notification that update is available today for 11/2019.70 OTA for my GO5. Currently running 11/2019.55.
07-20-2020, 12:44 PM | #2 |
Rep 228
The update has been transferred to the car but it's not giving me option to install yet. What am I doing wrong? Left it overnight and tried again this am and still no option. Any thoughts?
07-20-2020, 01:54 PM | #3 |
Rep 236
I just got a message after switching the engine off that it was ready for install. The car had done the download automatically on its own , not through my phone app. I just hit install and it started. Locked the car , came back an hour later and it said upgrade completed. Job done.
Have you tried To activate it in general setting, remote upgrade? |
07-20-2020, 02:00 PM | #4 | |
Rep 228
07-20-2020, 04:09 PM | #6 | |
Rep 810
I had exactly this issue for 2 - days, then put the car on a charger for around 6 hours- got the charge up above 80%. Went for a spin around the block, came home and switched off, then wham got the option to initiate upgrade came up straight away. I stayed in the car while it went through the motions - with 11/2019.70 it took around 20-30mins from start-finish. |
07-20-2020, 04:16 PM | #7 | ||
1197
Rep 1,587
If the car thinks there is an issue with the battery condition, then it will disable the RSU service entirely. Not the issue In this case which is probably charge related, but could be an explanation as to why some never get the updates OTA. |
07-20-2020, 04:27 PM | #8 | |||
Rep 228
07-20-2020, 05:04 PM | #9 | ||||
1197
Rep 1,587
This is the error that BMW would see if RSU was completely disabled due to a battery issue, not specific to charge level but condition. In your case it could be charge level so either take it for a long run, or stick on a charger as James suggested. |
07-20-2020, 07:09 PM | #10 |
Rep 810
07-21-2020, 06:24 AM | #12 | |
Rep 228
07-31-2020, 07:12 AM | #14 |
Rep 116
Drives: 2024 X5 50e LCI
Nothing really that I can find coming from 11/2019.40 to 11/2019.70. Mostly maintenance fixes I suspect. I found no feature enhancements.
