      07-27-2020, 12:19 PM   #1
IftiBashir
109
Drives: 2019 X5 MSport 40i
ACE 2.0 Camera System & Viewing footage
So I had the ACE system installed in my car.
When I connect to the system via the iPhone App, I can see a live preview from both the front and rear cameras - so they are both connected and working.
However, when I view back footage, whether it's via the app, or by inserting the SD Card locally into a computer, I find only footage from the front camera is recorded. I do not see any footage from the rear camera?
I have been through the settings and ensured the option for both Front and Rear recording is active.
What am I doing wrong????!!
Thanks
      07-27-2020, 12:26 PM   #2
IftiBashir
109
Ignore - just figured it out.
FYI - you have to open the file (AVI wrapper) within VLC Media Player.
Then Go to the Video menu, and select 'Video Track' and 'Track 2'.
It then shows both front and rear views simultaneously.
      07-27-2020, 07:57 PM   #3
parkstr8
parkstr8's Avatar
Drives: 2020 BMW X5 MSport Arctic Grey
Mine keeps not wanting to connect due to my Carplay connection...trying to figure that one out....
2020 BMW X5 M-Sport
2021 Audi Q7 Prestige
2016 Aston Martin Vantage V8
      07-28-2020, 09:10 AM   #4
IftiBashir
109
Yes I get the same. I have to disable bluetooth to get it off of the CarPlay. Then I connect to the ACE system. Seems to work that way!
parkstr8562.00
      07-28-2020, 03:41 PM   #5
IftiBashir
109
It would be lovely if the ACE system connected directly to the car and was viewable via the main vehicle display, just like the Drive Recorder.
Guess that would make too much sense to implement! lol
      07-28-2020, 04:17 PM   #6
parkstr8
parkstr8's Avatar
I just wish i could use it when outside the vehicle like i did with my old Owl cam. Just log on to the app and see what is going on...
I found this long post here about it:
https://www.babybmw.net/forum/viewto...9bc48477a7873e
2020 BMW X5 M-Sport
      07-29-2020, 06:51 AM   #7
IftiBashir
109
In theory - if its in parking mode then it is obviously active and running - so surely it wouldn't be so hard to bring out an update that would allow a wireless connection even with engine off.......
      08-03-2020, 02:50 AM   #8
TK - 421
There's a storm coming
TK - 421's Avatar
United Kingdom
252
Drives: BMW Vader
I’ve activated parking mode, not sure if it works as when I turn the engine off the camera says ‘system shutting down’ . I was under the impression it should say ‘parking mode active’?
Anyone any experience of this?
      08-03-2020, 11:30 AM   #9
IftiBashir
109
Yes thats what it should do - when I switch the engine off mine says Parking Mode Active.....
      08-03-2020, 11:55 AM   #10
TK - 421
TK - 421's Avatar
United Kingdom
252
Drives: BMW Vader
I’m guessing mine hasn’t been wired up correctly and should have a permanent live ?
      08-03-2020, 11:57 AM   #11
IftiBashir
109
Thats correct.
With the engine off and vehicle locked, as you walk across the front you should see a white light under the front camera flashing to indicate its picked up motion and is recording......
Also check back on the footage to see if its captured anything while parked....
      08-03-2020, 12:00 PM   #12
TK - 421
TK - 421's Avatar
United Kingdom
252
Drives: BMW Vader
Thats correct.
Ah, that’s answers that question then. Anyone know if it’s wired into the side panel passenger side (UK) I’ll have too pop off that panel and have a look. BMW are useless sometimes, sorry BMW Sytner High Wycombe are useless!
      08-04-2020, 08:53 AM   #13
IftiBashir
109
Not sure on that one - had mine installed at Sytner BMW too.
They did a decent job, although would have been better if they stuck the cameras on straight the first time!!! lol
      08-04-2020, 09:01 AM   #14
TK - 421
TK - 421's Avatar
United Kingdom
252
Drives: BMW Vader
I did have a quick look at the rear fuse box and couldn't see any link to the rear live hook up. I'm guessing they just wired to the front fuse box switched live only. Looks like I'll have to pay Williams to have a look
