08-05-2020, 04:20 AM | #1 |
Rep 71
Hi All,
I have been working on TLA/TLR since the last two weeks and have made some progress. I was wondering if someone is willing to work jointly on this and we identify the missing piece of the puzzle. Checked the blocking options codes 8LK & 8LR not present on my Aussie car. I have so far discovered all the relevant codes from BDC_BODY and HU_MGU. Traffic Light Assistant 1.Consider Traffic lights (visible and enabled) 2.Consider Stop signs (visible and enabled) 3.Resume at green Traffic Light Traffic Light recognition Display traffic light phases (visible and enabled) Distance Control 1. Avoid overtaking at the left side 2. Adjust distance acc. to situation Link for Codes https://drive.google.com/file/d/1i5I...ew?usp=sharing Thanks Jeet Last edited by jeet; 08-05-2020 at 04:38 PM.. |
08-05-2020, 09:30 AM | #3 | |
Rep 133
Thanks Armando |
08-05-2020, 08:23 PM | #6 |
1053
Rep 1,952
Just going on a hunch, but if traffic light assist follows the same logic as automatic speed limit assist then you may need to code some modules in the SAS2 ECU. I would start with the 42C1 CAFD file.
08-05-2020, 09:39 PM | #7 |
Rep 56
Drives: G05 X5 40i, F10 535xi, F26 X4
One I've noticed the SAS2 was renamed to SAS3 after 20-07 update. BTLD was changed as well.
08-05-2020, 11:04 PM | #8 | |
Rep 71
08-06-2020, 08:47 AM | #9 |
1053
Rep 1,952
I'm wondering if the same CAFD files need to be modified b/c all the CAFD files in SAS2 (now SAS3) that change for aSLA are concerning regional restrictions.
08-07-2020, 04:40 AM | #11 |
Rep 71
This is from another post from ifr
The following regions are explicitly excluded from TLA and will not get the feature even if they have DAP and a VO build of 11/2020+: All US 'type' models, China, Gulf, Japan, Korea, Australia, India, Brazil, Turkey, HK, Mexico, Singapore and Taiwan. Also, if the VO/FA includes either of the blocking Option codes '8LK' & '8LR' then the feature will be disabled. This is an example of the under the hood coding the car uses to configure the TLA feature: XPath=boolean(//cat[@val<"128"][crit[@val=3248]]) and boolean(//cat[@val="255"][crit[@val>=2011]]) and not(boolean(//cat[@val<"128"][crit[@val=186]]) That basically means if the car has DAP (3248) AND build version is >= 11/2020.x and the car is not one of a long list of exceptions (i abbreviated it, 186 = US type) then enable TLA. This boolean logic changes between i-step and also the underlying code in the software changes to be able to support an active feature, including bug fixes. |
jaimeen7768.00 |
08-07-2020, 10:14 AM | #12 |
265
Rep 345
Drives: 2019 X5 40i M
Be very careful with this. You have NOT identified all of the codes for BDC and HU_MGU. More importantly, there are several codes needed in SAS3. It is also questionable whether any of the Stop Sign recognittion will operate without the proper FSC for GWW being present.
I would not recommend changing any of these codes until the SAS3 files have been confirmed as well.
2019 X5 X40iM
08-18-2020, 04:34 AM | #13 |
Rep 71
I have made some progress and found codes in SAS3, these are definitely required for TLA/TLR requires UCC (Urban Cruise Control). Also the same codes are in DSC_VIP but I am not able to code anything in the ECU getting error. Have to wait for update from Esysx.
As soon as I enable the codes I get "Function not available in this Country" It will give the same message for all the countries as below, it is blocked by Salapa condtions. China, Gulf, Japan, Korea, Australia, India, Brazil, Turkey, HK, Mexico, Singapore, Taiwan and Russia. Someone from Europe or UK can you please try and advise if it works? Still working on it to get it working in all countries including Australia. Updated Link for Codes https://drive.google.com/file/d/1bDT...ew?usp=sharing |
08-18-2020, 10:42 AM | #14 | |
Rep 22
08-18-2020, 05:18 PM | #15 | ||
Rep 71
It won't work, it even checks the VO code and few more codes on other ECU's. Even if you change the VO code it still won't work. |
08-21-2020, 01:56 AM | #16 | |
1198
Rep 1,587
You are not only risking causing issues with your own car configuration, but could change the car to drive in an unexpected and dangerous manner. Any experienced and responsible coder can tell that the OP has no business asking anyone to code anything. The lack of understanding of the basics of coding is shocking. jeet - I took the time to explain at length to you why this coding should not be attempted. The i-step mappings for 07/2020 have not been made available to either TM or esysx! This means that even with the latest versions of these products any coder is working partly blind! Factor in the number of different combinations of mappings across different versions of products and its impossible to even reference some of the codes used for this advanced feature consistently. That's just one reason. There are many more which I explained, but you didn't acknowledge my reply and said 'F* you' and continued anyway. That is your right of course, as it is my right to tell forum members to STAY AWAY from your coding as you don't know what you are doing! How many simple codes have you published that have been tried and tested by the community and are now used safely on a regular basis? I have been privately testing this with some VERY experienced and reliable coders across regions in a controlled and responsible manner. I was planning on releasing the codes if and when it was safe to do so. This thread has put a permanent stop to that, and I will not be releasing any coding involving the new features. I will also not be providing any coding comments on any features moving forward jeet, so you can stop stalking and quoting my posts in case I let something slip! |
11
pho116.00 volodp196.50 mandomedic12240.50 marcosg24.50 Trojanlaw264.50 AshD101.50 homerrr133.50 FreddyBMW94.50 Saunders17283196.50 Silver.Solid116.00 BigMofoFrog180.50 |
08-21-2020, 09:36 AM | #17 | |
Rep 224
08-07-2022, 01:17 PM | #20 |
1060
Rep 1,512
I tried to code it based on the codes in the BimmerUtility software. That unlocked the TLA operation for me, but not the stop sign feature. Also, it does not give me option to adjust the green light indicator from early-late, etc
08-08-2022, 05:02 PM | #21 | |
1060
Rep 1,512
The way you reacted aggressively against the OP is just weird and puzzling to me. He was sharing what he learned and users here are smart enough to decide if they want to follow or not follow his guidelines. You decided to not share your knowledge with anyone with regards to TLA for reasons you specified, which is fine. If so, at least let others post their own findings. We all want to try TLA coding just like you have it on your car. Many of us can be responsible enough to try it just like you tried it, but it is okay that you decided to not share your codes. In summary, at least let others share their story and codes. You don't need to announce that in your opinion they have no idea what they are doing!. It is SIMPLE! people can post code and add a disclaimer of "try it at your own risk!!" Problem solved, knowledge shared, risk is understood. I mean seriously, the TLA codes are now available in the cheat sheet in BimmerUtility. it is NOT perfect, so if anyone can make it better, come on guys just share the knowledge. |
NoClosedDoors115.00 |
