02-23-2022, 04:11 PM | #441 | |
Rep 451
Drives: 2017 X5 & 2020 X5
TLA does not work here in Australia but I have since managed to get UCC and some other MY21 features that IFR identified working. I think in your case you will be able to recode all the changes you made previously but will not be able to add any new ones that BMW may have added in the last 6 months or so using your current version of Esyx. The sequence and location of the FDL codes in the NCD file do not appear to change and from my experience, any new ones are introduced in an already reserved allocated places previously labelled "UNBELEGT" see image below If you update, please remember to PM Shawn Sheridan for a link to the latest PSdz Data files and update them into your ESys directory otherwise you will get errors when you run ESysX to recode the updated files in your X5
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
marcosg24.50 |
02-24-2022, 11:21 AM | #442 |
Rep 77
Thanks for your helpful response. I am glad you have achieved some success with your efforts but not with TLA due to restrictions. It is a great function but not by any means 100% reliable.
I actually have a G20 but coded these features successfully using the Spreadsheet that was originally posted on the G05/X5 Forum. If I have my istep version upgraded from 02/2021.30 to 03/2022.XX which would hopefully be available when my service is due, I am concerned that I am treading in unknown and undocumented territory especially using an older version of EsysX. I don't know if anyone else has attempted this with the most recent istep version 11/2021 or newer. I have the latest PSdZData_Lite_v4.33.21 from Shawn but I guess this will change again by March. Should I leave things well alone or is there any kind of test run I could/should do to see if the software I have is still valid? Also, I am aware of the current status of EsysX but is it likely to be resurrected or are there other reliable ways of doing this type of coding? Your view would be appreciated. |
02-24-2022, 03:55 PM | #443 | |
Rep 451
If you are happy with how things are at present then don't ask for an upgrade. You can always pop into a dealer and tell them you are looking at upgrading and see what are the features in the new models for peace of mind. Are you familiar with Coding Verification menu in ESysX? Do you know how to edit your FA ie build date? Save your *.ncd files in *.fwl format and import them into Excel? I use Coding Verification to simulate coding changes to my ncd files as if my vehicle was specked for the UK market and built after March 2021 I then use Excel to do comparisons and then trial/apply the changes accordingly. In you case I would save a copy of your FA change your build date in your FA file to match your latest Pzsd Data and do comparisons on ncd files you have modified. Look for changes in lines starting with UNBELEGT to give you an idea if there are new features not mapped in your current version of ESysx
Fpgiuliano43.00 |
02-24-2022, 05:01 PM | #444 |
Rep 77
Thanks for your prompt response.
Unfortunately, a year has passed by since I applied my coding changes and I am a little rusty on the coding front as its not something I do very often. I am not familiar with the Coding Verification menu in ESysX or how to edit my FA ie build date or save my *.ncd files in *.fwl format and import them into Excel. I guess I need to read up on these capabilities before proceeding any further. If you have any pointers that might assist me, I would be very grateful? Thanks again. |
03-02-2022, 09:49 PM | #445 |
Rep 7
has the cheat sheets updated?
try to code aSLA on my 2021 G30 540i with 5AU, i-level 11/21-560,all the function in BDC and HU_MGU can code correctly, but in SAS3 module, most of the function missing the value 0XFFFFFFFF so I can not set. |
03-03-2022, 03:04 AM | #446 |
Rep 8,364
That is a werte value that you can edit.
03-04-2022, 01:35 AM | #447 |
Rep 7
Hi ifr, I was trying to code iSLA and TLA on my MY21 G30 with 5AU, i-step 11/21-560, but when I open esys, I can not find module DSC_VIP, only DSC_VIP2.
And in DSC_VIP2 module, there is no CAFD file to code. How can I fix this? |
04-13-2022, 09:23 AM | #448 |
30
Rep 47
Unblocked TLA in my car yesterday, it was blocked by country but all menus related to the TLA was in idrive. Only changed 2 land masks to FF,FF,FF,FF in SAS3 as in previous posts in this thread. Car with factory installed 07-21 and 5AU. Have to say , I am not impressed by this function, hit rate is no more than 50% , especially on the roundabout, or on the twisted road. When tried to run over red ( push little bit further , but obviously not drive) had huge traffic light symbol on the HUD and acoustic warning. I think it can work on less complicated roads , when light is visible form the distance. My conclusion is that is more gimmick than real functionality and probably for this is not available in UK.
04-13-2022, 10:01 AM | #449 | |
Rep 1,165
04-28-2022, 11:17 AM | #450 | |
Rep 18
(the latest thats available as far as I know). I have aSLA working so believe all the prerequisites exist on the vehicle. I am mainly interested in TL recognition testing and getting TL color change alerts vs full TLA, but understand from this thread that the whole TLA has to be programmed to get to that point. Thanks! |
04-28-2022, 05:10 PM | #451 |
Rep 9
Hello,
I'm having an issue the same with some guys here with Driving Assistance Affected error after pressing the button Cruise Control with Distance Control in the steering wheel. I have changed the SLINPI values to 00 and FF, it reads the signs very good and also the Distance Control works good but as soon as I press the button in steering wheel it shows the Driving Assistance Affected in head unit. Is there anyone that can help me? Car is G05 MY2020. Thank you! |
05-10-2022, 02:46 PM | #452 | |
9
Rep 37
Hi the link to your cheat sheet seems right be broken. Would you be so kind as to share? Thank you. |
08-30-2022, 09:53 AM | #454 | ||||
Rep 242
Is there a way to save ncd files in fwl now that EsysX doesn't support the new psdzdata? (The firmware on my car is 07/2022.33) I also have BimmerUtility but is doesn't provide the possibility of making the entire ncd readable like EsysX did with winmerge (BU only show the comparable function and not the whole text) Thanks |
08-30-2022, 10:37 PM | #455 | |
Rep 451
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 08-30-2022 at 10:53 PM.. |
08-30-2022, 11:32 PM | #456 | ||
Rep 242
08-31-2022, 04:55 AM | #457 | |
Rep 8,364
08-31-2022, 06:52 AM | #458 | ||
Rep 242
Is not readable/mapped Any other suggestions ? Thanks |
08-31-2022, 06:39 PM | #459 |
Rep 451
Ok i was under the impression that all the functions in the coding verification menu worked in the BU software setup. I was able to create mapped fwl files in my old Launcher Pro 3.7 software and paste the contents into an excel file for comparison checks.
I have not used this option since BU offered the very useful NCD compare tool which saves me a lot of time now and gives me the information i ultimately need.
09-21-2022, 04:07 AM | #460 | |
Rep 8,364
Launcher Pro works because integrated solution that provides mapping as opposed to BU which is separate tool. You can use Launcher Pro NCD compare or BU NCD Compare directly. |
10-16-2022, 11:51 AM | #461 | |
Rep 47
10-17-2022, 09:17 PM | #462 |
Rep 8,364
