10-18-2022, 11:01 AM | #463 |
Rep 47
Ok. this version has already been provided together with BU. What I ask and if it is necessary to then update Esys with new versions or whether to always use that . Thank you
10-18-2022, 12:44 PM | #464 |
Rep 8,364
10-30-2022, 02:58 AM | #466 |
Rep 8,364
11-19-2022, 05:36 AM | #467 |
B58 Power
492
Rep 628
Drives: 05/2022 M340i xDrive Touring
Has someone found a way to extend the time until the car expects the driver to hold the wheel again?
I know the value is pretty low (30 seconds?) in europe but higher in the US (90 seconds?). Has someone ever found a way how to extend this value?
05/2022: BMW G21 ///M340i xDrive Touring - Individual Verde Ermes
01-22-2023, 05:20 AM | #468 | |
Rep 10
And it works on some (there is a confirmation in telegram)(t.me/bmwg05chat ). Although the cars are the same, the encodings are the same, the cards are the same. The differences are only in the firmware version of the software. On some machines, after encoding, it also works in Russia. They didn't work for me (because the firmware is fresh). I also thought it was the maps, but it turns out that the software versions starting from about 2020y TLA are blocked for some regions and maps do not matter. The main thing is that some managed to circumvent the restrictions, but they do not want to share information. Most likely, you need to remove the blocking of regions in some other blocks by comparing the software versions. If you can do it, please share the encodings |
01-22-2023, 03:33 PM | #469 | |
Rep 451
Drives: 2017 X5 & 2020 X5
Secondly I think all European spec cars include the Kafas FSC code for GWW (Give Way Warning) and Stop light Recognition. Australian Spec cars do not have this and I am of the opinion this may have something to do with TLA not working here where others have said no. If i get it working I will definitely post my findings on the forum
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 01-22-2023 at 03:43 PM.. |
01-23-2023, 01:51 AM | #470 | |
Rep 10
For the second problem, the FSC code for GWW is definitely not needed. Traffic lights work in Russia on cars who do not have GWW |
02-20-2023, 01:33 AM | #472 |
Rep 8,364
02-26-2023, 07:45 AM | #473 | |
Rep 6
02-26-2023, 11:35 AM | #474 |
Rep 68
Nope, you cant activate it via Bimmercode. You need access to SAS3 ecu to activate it which only esys can afaik
BMW X5 G05 40i M Sport
03-09-2023, 05:56 PM | #475 |
Rep 10
This forum is like those tiktok clickbait videos. After 22 pages and about an hour of reading it came to an abrupt end with no information the last year and a half.
Are there any updates on this? Is it available in the US now? All the information seem to point to Esysx, however Esysx has been deprecated. EsysNeXt is now the new one, but I did not see anyone with success? Have there been updates, and is it working better? Do they cater for different signal layout now? |
03-10-2023, 12:20 AM | #476 | |
Rep 1,165
I have a sensor issue on my car so booked in for early April so will probably wait until then before applying as no doubt the first thing they will do is apply 03/2023. I've post more recently on a G20 forum thread. Newer software seems to have improved TLA, particularly on driving away after the light goes green. |
03-13-2023, 06:05 AM | #477 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Gerhard Lamprecht ,
To address your first question, I'm in the US. I coded TLA into my 2020 M340. As ifr indicates, it doesn't work well in some parts of the world. The US is in that category. As best as I can surmise it's because of the inconsistent location of traffic lights at intersections -- some on far side, some overhead, as opposed to Europe where, as I recall, they're on near side. My car would stop in middle of intersection or act up; needless to say I uncoded. Because the coding involves the SAS module, you can't use Bimmercode (doesn't work on that module), but you can use many others. I used initially, ProLauncher & then EysX. I would think BimmerUtility or the Chinese program (name escapes me). Each of these programs "maps" functions & values into ESys because BMW has been "clipping" that out of the program Hope that helps
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
Almaretto2374.00 |
03-27-2023, 01:58 AM | #478 |
Rep 16
There is any possibility to code with BU Urban Cruise Control C_SLA_UCC_Land_aktiv from default value to 0xFFFFFFFF? I don't have any other option then default Nr000_Bausteinpartitionierung
03-27-2023, 10:28 PM | #479 |
Rep 1,142
Second what RSnic mentioned about the TLA. I have been playing around with it for a month or two now and have noticed the same thing about stopping distance. It will detect the light, but because the lights in the US are typically across the intersection instead of on the near side, it will not stop at the correct location and instead try to continue in to the intersection. For purposes of the drive off alert, it works just fine.
05-27-2023, 08:23 AM | #480 | |
Rep 5
I'm new user and have bimmer unitily s/w. I tried enable aSLA and traffic light assist on my G01 2022 car. But when I enable Traffic light function. Car will show the function dont support this country.Could you please kind share experience how to enable full region for TLA ? Pls help.Much Thanks bro. |
08-07-2023, 04:51 PM | #481 |
Rep 2
You should get a custom value checkbox so when you click it will let you edit each byte of the value. Just set each one to FF.
08-07-2023, 04:55 PM | #482 |
Rep 2
Is there any recent experience in Australia with UCC and TLA? I have enabled LCA but not having any luck with UCC here which others have said works in Australia. Bambazonke are you able to give an update on what works for you?
08-19-2023, 02:35 AM | #483 | |
Rep 451
UCC & aSLA work fine here in Australia in non LCI X5's after coding as per my cheat sheet I was unable to check the new X5s if the Give Way/Stop Sign Warning which require FSC codes was enabled but I highly doubt it. Not confident with BMW Australia's current ability to be abreast of local driving regulations eg photos of contacts on Australian spec models are still disabled in the iDrive menu but are visible in AA Carplay and many other car brands sold in Australia proprietary phone software
MY 17 X5 2.5d sDrive |
MM20.00 |
08-19-2023, 02:21 PM | #484 |
Rep 226
Drives: 2022 BMW X5 M50i
I coded TLA , UCC in my 2022 X5M50i with the help of Bambazonke cheat sheet last month and i used Bimmerutilty and esys 1st time, it took me 2 days to understand how to code it lol, but finally i coded everything and from that day I'm driving my car only using iDrive maps and as per my experience TLA works around 70% of time it recognize the light but hesitate where to actually stop and it has to do with positioning of traffic lights here in US but UCC and highway exit works around 90% of time in city streets on turns UCC kicks in and slow down the car so no need to lower the speed manually and highway exit works fine too and the iDrive maps shows the exact lane you are driving in .
I don't know if its possible to code stop sign recognition coz it can make UCC even better. |
