TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Building an E90 Endurance Car
      08-13-2023, 09:33 PM   #1
GasBurnlife(landapanda)
Drives: BMW M2
Howdy! New to the E9x forum, but a long time Bimmerpost fan and active on the M2 F87 pages. After 5 years of tracking my M2 and meeting many like-minded souls at the track, a group of us finally decided to build an endurance car. We finally found a perfect donor - a 2011 auto E90, and will be documenting our journey on YouTube - feel free to drop by and say hi! Looking forward to chatting with many of you as we will surely find many things unique to the E92 that we'll be reaching out to you all for help.
Appreciate 3
      08-21-2023, 12:15 PM   #2
Drives: BMW M2
Well a week later and we have stripped the interior, removed the seats and airbags and now need to work on removing the sound insulation. We then have engine and tranny preventative maintenance scheduled for September and cage install in early October.
https://youtube.com/shorts/7deM-PiGsY0?feature=share
https://youtube.com/shorts/iGDH0K_4FxY?feature=share
      08-22-2023, 05:13 PM   #3
rismo
Drives: BMW E92 335
Nice project! Keep us posted, planning to convert mine also to a dedicated track car. Keen to learn from your adventure.
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3
      08-28-2023, 06:31 AM   #4
Drives: BMW M2
https://youtu.be/MZLfWtXFSuk?si=bmCkuNr5DejRFnPT
      10-13-2023, 03:33 PM   #5
Drives: BMW M2
https://youtu.be/ZcpphI9OUV4?si=LbtIkCCYLTYTcWAE
      10-30-2023, 04:41 PM   #6
san40k
21
Drives: 2008 E90 335i N54 6MT
Have you seen https://spece9x.com/ ? Doesn't seem to be super popular, but might be useful.
      10-31-2023, 11:40 AM   #7
Drives: BMW M2
We are going off the list - somewhat loosely though because we are not planning to participate in the spec class.
      11-29-2023, 02:30 PM   #8
Drives: BMW M2
3 months later we are now 3 days away from our first test. Here is an update from this last weekend:
https://youtube.com/shorts/AGhTCSqTO...1SBYXH24t76RNd
      12-03-2023, 12:41 PM   #9
Drives: BMW M2
First shakedown test is in the books!
https://youtu.be/Ig1goAQLz9c?si=0zslwRWKTiBVGOKN
      12-03-2023, 03:38 PM   #10
M-technik-3
2117
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
That's an expensive build, hope the AT holds up. Any reason why you did not purchase someone else's build?
      12-06-2023, 04:43 AM   #11
Drives: BMW M2
Part of the experience for us was building out the car itself. It was a project car for us and something to bond over the off-season on.
      12-10-2023, 07:02 PM   #12
Drives: BMW M2
… and the fun continues now that we are digging deeper into the implications of running the N51 engine while trying to maximize its power delivery:
https://youtu.be/z0PU-SXKC0o?si=psgTKNi8d-7OIUu_
      12-11-2023, 11:08 AM   #13
simontibbett
simontibbett's Avatar
32
Drives: BMW
Really cool informative video there. Props for doing so much research and knowing what you have!
VIR in March? Need a driver/coach? I have a few thousand laps there.
      12-12-2023, 08:37 AM   #14
Drives: BMW M2
We may actually. We all have a good number of laps at vir but haven’t driven the south config.
      01-28-2024, 05:14 PM   #15
Drives: BMW M2
We’ll we are finally done with all the mechanical work. Finished installing plastic rear windows and exhaust install yesterday, so posting a few vids of progress.
https://youtube.com/shorts/92pG97H3k...eipZC_pRHeixD9
https://youtube.com/shorts/X2jbFaXOd...g30qJSAlZBOBLp
https://youtube.com/shorts/W0hUw8Ksi...QjckosyDvgA4ZQ
https://youtube.com/shorts/tbT3WvgHD...QXybj8hia-fR42
rismo77.00
      02-26-2024, 01:06 PM   #16
rismo
Drives: BMW E92 335
In regards to the AT, what I have learned is to manage it's temp and replace the fluid as soon as you have overheated the oil.
This requires ideally a good ZF diagnostics head to readout the TCU metrics and also a cooling solution.
The stock cooling is not adequate and might lead to severe and premature wear. The rebuild of the gearbox on my former 3 series costed me around 2.5/3k. I then learned from that mechanic that much more and relevant metrics can be pulled from the TCU itself.
      02-26-2024, 07:08 PM   #17
Drives: BMW M2
Appreciate the info. What’s the max temp threshold to keep the temps under?
      02-28-2024, 05:04 PM   #18
rismo
Drives: BMW E92 335
If I remember well target around max 100/105c with an operating temp at 90.
What I learned is that to keep the box in shape, flush the atf as soon as you suspect sincere overheating. This as the ATF becomes significant less efficient afterwards.
On my n54 the gearbox temp trailed during warmup in avg 10-15 behind engine temps. So these gearboxes warmup slower and so later full operational when compared to the engine itself.
I checked the ZF ATF spec sheet but much info about these ranges is not provided:
https://aftermarket.zf.com/remotemed...-australia.pdf
I did find this link with halfway a nice graphic showing some temperature ranges and impact:
https://www.ridgelineownersclub.com/...%20ATF%20fluid.
      05-02-2024, 11:36 AM   #19
FiberMonkey
FiberMonkey's Avatar
Drives: M5 Comp, E46 M3, E30 E90 325i
We run an E90 in Champ/Lucky. Are you going to try to make the 24 hr at VIR this year? It would be awesome to have another E90 on track. We didn't make the March race this year. We were running at CMP that weekend. You should check out Lucky Dog. No points restrictions.
      05-10-2024, 06:21 AM   #20
Drives: BMW M2
Hi - no plan for the 24h race. We are focusing on AER this year and will be back at VIR at the end of this month. Hopefully we’ll run into you at one of the next races.
      05-11-2024, 08:37 PM   #21
dominancex
What Can Brown Do For You?
dominancex's Avatar
Drives: E90 LCI 335i & F30 335iX
That's exciting, we just ran AER @ Watkins Glen. I won't be able to make it to VIR but the team (Laying Pipe Racing) should be there. Would love to check out the build if you'll be at any other events. I usually take my E90 out during HDPE in the morning.
