09-05-2023, 09:35 PM | #1 |
Rep 78
Adaptive Recuperation
I have a 2024 X5 50e. I did read the manual explaining adaptive recuperation and tried it a few times. I am still unclear what this setting is trying to accomplish.
09-06-2023, 07:58 AM | #2 |
Rep 8,726
Drives: eVeRyOnE mAD!
it adjusts the level of regeneration strength depending on the situation (could be stronger or weaker). note this does not apply to pressing the brake pedal
09-06-2023, 10:50 AM | #4 | |
Rep 8,726
if you have Adaptive Recuperation enabled, the vehicle decides the level of recuperation: little to none if no vehicle in front of you (feels like you’re coasting in neutral), stronger if it senses a vehicle in front of you (feels like applying the brakes). same with the regeneration strength when applying the brakes: stronger with harder application, weaker with lighter application |
09-06-2023, 10:53 AM | #5 |
Rep 208
I've found the D/S mode, pulling back the shifter 2 times, offers a lot of recouping a charge with out using the battery. I have yet to spend any time in Sport mode though.
09-06-2023, 02:57 PM | #7 |
Rep 206
It’s the level of regeneration (recharging the HV battery using your forward momentum to run the electric motor in reverse). I’ve found that with adaptive recuperation enabled it will also use signals such as your turn signal to engage higher regeneration. For example, when I approach the turn into my neighborhood from a 55mph road if I use my turn signal the car will slow due to high regeneration and if I do not use my turn signal I will coast and need to apply more brake. I’ve found that it works quite well. My only complaint is that I will sometimes release the gas pedal completely when following another car and fail to anticipate the regeneration so it can cause it to feel as though I abruptly applied brake.
09-06-2023, 04:27 PM | #8 |
Rep 8,726
I’m not a fan of this feature as it induces “jerky” vehicle movements leading to motion-sickness induced nausea of my passengers
