05-07-2021, 03:48 PM | #1 |
Back in a BMW
285
Rep 383
Tire temps…
So wondering why the tire temps are heavy to the driver side.
Not being a nut job just curious others experience.
21' Donington on Black X5M | Comp | Exec
11' 1M Coupe Valencia 6MT OEM+ 289 of 740 |
05-07-2021, 06:48 PM | #3 |
Rep 3,507
Do you turn to the right a lot or highway speeds bank right alot? If so normal.
2022 M8 Comp Convertible
05-08-2021, 07:51 AM | #5 |
Back in a BMW
285
Rep 383
Interesting I'll try that out. Shouldn't be a bad sensor I mean stranger things happen. Lol
05-08-2021, 08:06 AM | #6 |
Rep 2,699
Drives: 23 X5MC
Something near that tire ( under hood) that is hot enough to throw off the sensor?
05-08-2021, 10:07 AM | #8 |
Rep 593
On my car all tires are usually 1-2º C, and its been like this on all BMWs I ever had. A difference of 9º F is too much, either the sensor is not accurate or the tire is out of alignment.
05-08-2021, 07:16 PM | #9 |
Rep 3,927
I've noticed that often after I park the car and get out, I can feel a lot more heat coming from under the car on the drivers side. I bet that is heating up the tires on the left side.
My car also reads higher on the left side. |
05-11-2021, 08:21 AM | #12 |
Rep 206
Pay attention to the location of the sun relative to the car during your commute. If the sun is predominantly on one side it can increase the tire temps by several degrees relative to the side not receiving the sun's rays.
hdahman236.50 Samurai of 2day2115.00 |
05-11-2021, 09:15 AM | #13 |
Rep 432
05-11-2021, 11:12 AM | #14 | |
Rep 591
05-17-2021, 07:11 AM | #16 | |
Rep 79
This one is really a head scratcher but happens to me frequently. Many time going to the ranch in far SE NM south of Carlsbad I will fight 20 to 40 and greater cross winds for hundreds of miles. Funny thing is that the slight turning into/fighting the wind will cause the temps to go up on one side. Conversely and this made me scratch my head at first my tires on the north side of the truck were 2psi lower (70 psi vs 72) than the south side of the truck. Then it dawned on me south side sun exposure with north wind blowing 25 and temps 15 degrees. Coming home the next day almost the same but 1 psi different just on the other side.
2021 Mineral White X5 M
05-17-2021, 09:03 AM | #17 |
Rep 593
I have been paying closer attention, and yes, it seems my car does the same thing. I have the temps set to C, and I see 3-4º C difference after extensive drives. No idea what is causing this.
05-17-2021, 05:11 PM | #18 |
Rep 738
Probably Bc there's an extra weight on that corner. Aka you.
?I AM M? ?
ed41367.50 Xccelerate284.50 |
