04-25-2023, 08:33 PM | #23 | |
Rep 3,553
I had digital key for my LCI X7, about two weeks ago Samsung wallet updated and my key converted to Digital Key Plus, no OTA update on the car. proximity lock/unlock and uwb/ble functionality after the update/conversion. before that never had the functionality, it was only NFC. it seems to be controlled by samsung (software update wise, bmw is most likely part of the approval process). when i went from an S22 ultra to S23, i lost the nfc function for about a month until bmw approved it and samsung pushed out a wallet update.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC Last edited by Orient330iNYC; 04-25-2023 at 08:48 PM.. |
04-25-2023, 08:57 PM | #24 | |
Rep 8,700
Drives: eVeRyOnE mAD!
a) her key fob in her purse/pocket b) her phone in her purse/pocket if a), BMW has had that for many years, too, so they’re not “behind.” if b), that’s new for BMW with the Digital Key Plus feature. with this feature, one doesn’t need to carry the key fob anymore. the phone functions like the key fob with respect to advanced Comfort Access features, such as “unlock when approaching” and “lock when walking away.” can her Volvo do this with only her phone in her pocket/purse? if it can’t, then Volvo is behind! PS. I couldn’t find this “approach enter functionality” you’re referring to… |
04-26-2023, 09:28 AM | #25 | |
Rep 517
04-26-2023, 11:39 AM | #26 | |
Rep 849
M3 - X5 - 911 - Miata - Raptor - Edge
nZtiZia4656.00 SwissBeemer301.00 |
04-30-2023, 11:08 AM | #27 |
31
Rep 48
Digital key plus - does it work on the Apple Watch ? If yes how do you do it ? I have the bmw app on the watch and the Apple wallet but the wallet doesn’t show the key in the watch. Is there another way ?
04-30-2023, 11:23 AM | #28 |
Rep 225
Very interesting. Because here’s a phrase from a 2022 article: “According to Michael Schweitzer of Volvo Cars, the Swedish automaker currently has no vehicles with UWB technology in its lineup. However, this will be taken into account when planning future models, a Volvo spokesperson informed us.” Yet you’re saying your wife’s 2020 Volvo has it. Can you confirm that she uses her phone as a car key and she doesn’t even have to take it out of her purse and the car unlocks?
04-30-2023, 01:54 PM | #29 | |
13275
Rep 19,803
09-13-2023, 11:51 AM | #30 |
Rep 4,335
Drives: 2020 M850i Coupe
Dug up this thread vs starting a new one regarding the odd behavior I'm having with digital key plus on the 2024 40i (June build date and currently on 03/2023.45). I had originally set up my wife's profile first as it's her DD, assigned her fob to #1 seating, etc. with linkage to her BMW connected drive profile, etc. Then set up mine later tied to the other fob, seating position #2, etc. Everything worked great.
In the MyBMW app I had a tile to set up digital key plus. First attempt failed as only the primary user can enable a digital key (regardless of plus). Since my wife's profile was first set up it was by default the primary user and mine secondary. No big deal as migrated primary user rights from her profile to mine (simple process within the MyBMW app). The first attempt to set up digital key plus failed with a nonsensical error message about connectivity. Searched the forums and the apparent solutions were: A) remove the vehicle from my garage and start over or B) reset the digital key to factory settings within iDrive. Went with B as path of least resistance and worked like a champ with a successful digital key plus pairing to my Google Pixel 7 Pro and the key in my Google Wallet. This was done on a Saturday and all worked well every time I drove the X5 over the weekend to run errands (enjoying it when I can to further refine the iD8 settings for the wife and I). That said the next time I attempted to use my Pixel 7 Pro as my key it appeared to have reverted to digital key 2.0 (technically the Car Connectivity Consortium's standard with 3.0 including UWB). So had to touch the handle, put it in the wireless starting tray to start, etc. I just reset the digital key back to factory, re-paired digital key plus in the MyBMW app and was back in business. But then it happened again the next day. I realized at that point since I did the "fix" last Thursday evening, tested it multiple times, etc. the fact it didn't work on Friday evening (reverted back to 2.0) was my wife drove the X5 using her fob as usual to work on Friday. I found one hit on Reddit for a similar experience but in that case the OP shares the digital key with his wife's iPhone. Similar though as his works in 3.0 until his wife uses hers and then boom he's back in 2.0. Further testing on my end indicates UWB 3.0 is somewhat still active after the "bug" hits. The fact being in my wallet if within UWB range the buttons below the key to lock, unlock, tailgate, etc. all work. It's just the comfort aspect of the 3.0 UWB spec gets apparently broken. Pic attached shows them greyed out and not connected as my wife has the X5 today at work so nowhere within range. However, when she gets home I'll update with connected and all buttons active. Anybody have a similar experience and if so have you figured out the issue? |
09-13-2023, 04:18 PM | #31 | |
Rep 1,073
You make digital key the same way as your phone with both keys in the car. Have the watch on when you make the keys. It will prompt you after making the phone key. |
09-24-2023, 12:48 PM | #33 |
Rep 14
Just being proactive here, but does anyone know if one has to set-up a new Digital Key when you get a new phone or just it transfer over when doing the set up of the new phone. Going from iPhone 12 to 15?
09-24-2023, 01:03 PM | #34 | |
442
Rep 372
09-24-2023, 01:07 PM | #35 |
442
Rep 372
09-24-2023, 03:31 PM | #36 |
Rep 549
When I activated my new iPhone, the old digital key was no longer showing and I had to activate a new one. I believe once you do this, the old one becomes inactivate.
johneric20050.00 |
09-24-2023, 03:48 PM | #37 |
Rep 14
09-24-2023, 03:51 PM | #38 |
Rep 8,700
likely, but if able (old phone still works before upgrading), it’s better practice to remove the Digital Key before getting rid of the old phone
09-25-2023, 01:32 AM | #39 | |
301
Rep 382
I also can't add the car to my myBMW garage. I was able to do it as primary user but then removed the car again so my gf could add it and use DK+ (my phone doesn't support UWB) and she could add it fine but I only get to the point where the car is in the myBMW garage but says "Additional information required" and when I click on continue it asks me to accept the BMW TOS in an endless loop. I accept and it would load for 5s and ask me to accept again. Already tried everything. Removing the car completely, reinstalling the app, etc. (Apart from resetting the car completely to factory settings, which I would like to avoid.) (€dit: This was just fixed by the BMW Connected Drive Support.) Last edited by SwissBeemer; 09-25-2023 at 03:17 AM.. |
09-25-2023, 12:30 PM | #40 | |
Rep 4,335
For me there is no way I can come up with to get the UWB comfort access back alive without reprovisioning the key. The odd thing is that UWB is still active, e.g., the buttons on the key work to lock/unlock, etc. from 10 feet or more away from the X5. But if I unlock with the button on the key the X5 doesn't recognize my Google Pixel 7 Pro to start the car without putting it in the wireless tray. Same for lock/unlock without the key's buttons, i.e., I have to touch the door handle with the phone just like DK. |
09-26-2023, 01:37 AM | #41 | |
301
Rep 382
09-26-2023, 10:00 AM | #42 | ||
Rep 4,335
The reason for knowing this, i.e., Satellite vs Internet is the wife's old 2017 X5 with iD6 did not have Internet capabilities whatsoever. However, I could locate it via the MyBMW app as well as lock/unlock it remotely from my house while the X5 was ~25 miles away in her school parking lot. Locked it several times when she apparently forgot to do so in her morning rush to get to her classroom before the 1st period bell rang. 👍 Quote:
That said I did find this article on the IX forum as well: https://www.********.com/threads/and...onnected.2521/ which refers once again to waking the car up. I'm going to try that process again this evening when the wife is back home from working but this time with a little more patience. 😜 Edit: it looks like Bimmerpost masks the URL of competitive forums (seriously?) as I can post URLs all day long without the masking to news articles, Amazon store products (do that often for helping people by OBD modules, etc ). That said you can find it as article 2521 on the IX forum. |
09-26-2023, 01:08 PM | #43 |
Rep 5
Has anyone had this happen. My phone is what I have been using as a key on my 50e. We were away over the weekend and my wife had her keys in the car as well. I walked away to drop something at the hotel we were at and the car locked her keys inside. She was locked out and my infant son was inside. I was only gone for a few minutes but she was annoyed if locked when her keys were in the car.
09-26-2023, 01:28 PM | #44 | |
Rep 5
