BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > JB Diesel Tuner 335D WOW
      01-05-2011, 08:16 AM   #45
Sailor737
Drives: 2010 335d
Originally Posted by Twilight1 View Post
Mine throws shadow codes at 100% but no SES lights.
Same here... Thankfully I checked before I had to bring it into the dealership! And that riverside rear bolt is a PITA!
      07-23-2011, 03:52 PM   #46
nhinnhuckyduc
Drives: F30 328D
What is the highest percent you have you JBD without having any issue yet. Just got my 335d about a week ago
thanks
      07-24-2011, 12:01 AM   #47
///V\3Dude
I Drive Slow To Save Gas :D
///V\3Dude's Avatar
Drives: 08 M3, MY11 STi
thanks
I've seen many guys running their JBD at 85% without any issues. Im pretty sure everyone running at 100% are throwing codes
      08-01-2011, 04:35 PM   #48
cssnms
cssnms's Avatar
Drives: 2011 BMW 335d
My car not only threw a code/SES light at 100% it went into limp mode. I have the new version of the JBD too, Terry claimed the new version eliminated SES lights... Not so...
      08-01-2011, 09:31 PM   #49
naamanf
Drives: '14 550i '10 MDX '79 TA OH-58D
I also have a new one and need it turned down a bit.
335d M-Sport/Everything + Individual, 550i M-Sport ED APR 2014
      08-03-2011, 05:51 PM   #50
335dM
Drives: 335d m package
mine is at 85% no codes
      08-03-2011, 07:31 PM   #51
cssnms
cssnms's Avatar
Yea I have it turned down to like 90% now, no codes so far...
      08-03-2011, 07:55 PM   #52
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
Drives: Audi SQ5
90% - limp mode, but it cleared itself after shutdown and restart (new chip too).
Anybody clear the shadow codes, leave the unit intact and bring in for annual service? Seems like a pain to remove the engine cover, undo all the zip ties and replace it...
      08-03-2011, 08:31 PM   #53
cssnms
cssnms's Avatar
I cleared codes just this past Monday before I went in for my first oil change. No shadow codes, just a fuel pressure fault code as a result of going into limp mode when I was running at 100%. It is a kind of a PIA esp since the frick'n engine cover is attached with allen bolts, one of which is a little difficult to access. Why couldn't BMW make it as easy as the x5d? I will tell you that the little white clip that you remove from the fuel pump connector so you can plug in the JBD is very fragile and I don't see it lasting through many disconnects and reconnects. Would like to get my hands on a few extra.
FWIW, if your car went into limp mode the code is stored, it doesn't clear itself. Hook up your BT cable and clear it before your next dealer visit.
      08-03-2011, 08:50 PM   #54
szhark
Drives: 335D
Hey all.. first time poster, and first time BMW owner..
I just got the JBD box in the mail and plan to install it this weekend. Any tips/precautions I need to know? I've done a ton of research, so I believe i'm ready to take the plunge I'm conservative, so i'll start with the default setting. I'd also like to get a few runs in using the android app 'torque', and compare after the install.
This forum is a wealth of info, thanks for everything so far.
-sz
      08-03-2011, 10:35 PM   #55
Coolieman1220
Trinidad_and_tobago
73
Drives: 2010 335d
I want to feel the power of a JBD, not that i need it since my Bimmer is already fast enough but I can't see the effects of the JBD being great for my car...
      08-04-2011, 08:14 AM   #56
cssnms
cssnms's Avatar
-sz
Start at the default setting and leave it there for a week or two and slowly turn it up over the next couple of weeks. If you go to 100% you will likely at some point experience an SES light/limp mode. Last but not least, make sure you remove it and clear codes before taking your car into the dealer for service. Other than that, enjoy.
      08-04-2011, 08:15 AM   #57
cssnms
cssnms's Avatar
If you're coming down for bimmberfest you can go for a spin in my car before I leave. Weather is looking iffy though, so if it's pouring I won't be there.
      08-04-2011, 08:24 AM   #58
Coolieman1220
Trinidad_and_tobago
73
Drives: 2010 335d
considering the drive actually....that or an autox. but yeah the weather isn't looking great for us....
we'll see
      08-05-2011, 01:02 PM   #59
Thud
Throbbing Member
43
Drives:
You folks with JBD-- does your DPF regenerate more frequently now?
2014 Tesla Model S 85kwh
Previous cars:
2011 335d / Deep Sea Blue / Saddle brown / sport / premium
2008 BMW 135i / 6MT
2002 Z06 Corvette
      08-05-2011, 01:20 PM   #60
cssnms
cssnms's Avatar
Can't say that I have noticed it does.
      08-06-2011, 12:19 AM   #61
nhinnhuckyduc
Drives: F30 328D
I have been running it at around 85% for the past few week and today i chose to run it at 90 and the power is noticeable but i the check engine light kick in right away and i was driving a tank after that. so anything over 85% is bad for my car. This is also the newer JBD to i guess cause i only ordered about 3 week ago. car has about 1500 may that be the problem why i cant run it any higher then 85%.
      08-06-2011, 02:24 PM   #62
nhinnhuckyduc
Drives: F30 328D
I dont think there is anything different in the newer version and older one. Some of the guys are saying there something in the tune that isnt suppose to trigger a code but for fuel economy i cant tell because all the miles on the car have been highway miles and i was getting 540 to a tank and notices a big different since i been here in NC compare to NY where it is higher and most of the driving is down on city street with an avg of 25MPG and Very high outside Temp of 95 or more.
      08-07-2011, 06:19 PM   #63
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
The adjustment range is just to allow for car to car variance. Most cars will throw a tuner code / check engine light somewhere between 70-100%, which is why the default is 65%.
Mike
      08-07-2011, 06:36 PM   #64
szhark
Drives: 335D
Mike,
When you say car variance, is that a static variable? ie: if my car can't handle 100% currently, could it change if i 'ease' up the percentage over a period of time? or is it pretty much, "if your car can't handle 90%, it never will"..
Thanks,
-sz
ps. Smile on my face hasn't left since installation
      08-08-2011, 08:01 AM   #65
cssnms
cssnms's Avatar
Mike
I wouldn't mind if it were just an SES light, but it sucks when the car goes into limp mode, which is what happened to me on the way to Bimmerfest running the JBD at about 90%.
      08-08-2011, 08:04 AM   #66
cssnms
cssnms's Avatar
Originally Posted by MrClean View Post
Any difference in fuel economy with the new version?
There is no difference. The newer version is just an updated firmware, which at the time it came out the claim was it was to eliminate triggering SES lights even at 100%, not so...
