Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > JB Diesel Tuner 335D WOW
      08-08-2011, 08:09 AM   #67
cssnms
cssnms's Avatar
Drives: 2011 BMW 335d
Originally Posted by nhinnhuckyduc View Post
I have been running it at around 85% for the past few week and today i chose to run it at 90 and the power is noticeable but i the check engine light kick in right away and i was driving a tank after that. so anything over 85% is bad for my car. This is also the newer JBD to i guess cause i only ordered about 3 week ago. car has about 1500 may that be the problem why i cant run it any higher then 85%.
My butt dyno hasn't registered much if any difference running it at either 85% or 100%. According to the dyno graph it's only a 4hp difference between the two settings.
      08-15-2011, 07:34 PM   #68
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Originally Posted by Rambler View Post
Hey jaybird, I could be mistaken on this but I thought the 335d carried the ZF 6hp28 which is rated to 700Nm (approx. 515 lb-ft)... and that the 335i had the 6hp26 rated at 443. It was my understanding that we shared the same tranny as the 550i and 750i which come stock at 450 lb-ft.
If somebody knows for sure, please chime in. I'll try to dig a little more later.
True statement.
      08-15-2011, 07:52 PM   #69
Coolieman1220
Trinidad_and_tobago
73
Drives: 2010 335d
Originally Posted by Ron1n View Post
True statement.
I think pre-lci had the 26 while lci's have 28
      08-15-2011, 08:17 PM   #70
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
US never had pre LCI, though. First model year was 2009.
      08-15-2011, 08:32 PM   #71
Coolieman1220
Trinidad_and_tobago
73
Drives: 2010 335d
yes but everywhere else in the world did. what difference would that make?
Besides in 2009 is when BMW V8's became turbo'd and started making 450ftlb of torque as well.
i could be wrong, just my guess...didn't the 335d get a bit of a power bump prelci to lci? not too sure, maybe someone over sea's may know better
      08-15-2011, 08:35 PM   #72
DnA Diesel
27
Drives: 09 335d Sport SGrey/Blk/Blk
Early 2009 335d's had the 6HP26TU (technical upgrade - equivalent to a 28 production - I'm a 3/09 build and I think I have the 26TU). Not sure where the cut-off point from 26TU to 28 was, but the only substantive difference between the two, was that the 26TU was an interim upgraded transmission to the same rating as the 28, just not the full production model that the 28 was.
Cheers
D.
2016 GLE 350d - White on Black
      08-15-2011, 10:32 PM   #73
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
The difference it makes is that it depends on where you're from.
      08-16-2011, 08:18 PM   #74
norcal_cyclist
Drives: 2006 Z4 3.0si
1999 BMW 323i  [0.00]
Trimmed mine to about 80% based on the original setting and where I turned the dial anyway. I'm going to leave it as is... no CEL's and it will outrun just about anything I choose to run from 'cept maybe, Motorola
      09-17-2011, 06:46 AM   #75
Dust
Drives: Daihatsu Move
Originally Posted by hotrod182 View Post
Still curious if anyone has tried Meth Injection on their Diesel?
Water meth injection works better for diesel than it does for gasoline. Using it to it's fullest in the 335D would be a different discussion.
      09-17-2011, 09:50 AM   #76
Messiah62
Drives: 2011 335D
So what kind of fuel economy differences does this thing do? Much worse/better?
      09-18-2011, 08:01 AM   #77
cssnms
cssnms's Avatar
My mileage is worse, but then again that could be due to how I am driving now. I tend to put the pedal to the metal more often.
      09-18-2011, 01:27 PM   #78
335dM
Drives: 335d m package
i'm set at 80% with jbd, 65/35 highway/city, my foot is heavy and i'm getting 28 mpg average. i recently went in vacation to wildwood nj and i was able to hit 45 mpg on the highway with my jbd, 2 person, 3 luggages and a cooler in the trunk
      09-18-2011, 03:59 PM   #79
duramax
Drives: 2011 335D
Is that calculated MPG or your what your dash is telling you? Just curious as I hear the with the JBD will show much better than actual.
      09-18-2011, 05:53 PM   #80
335dM
dash
      09-20-2011, 02:01 PM   #81
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Initial install of the JBD will reflect incorrect MPG until the car becomes accustomed to what the JBD is doing. Give it some time to settle, and then you'll get an accurate readout. The best way to determine your actual gas mileage is to track from tank to tank.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
      09-30-2011, 07:26 PM   #82
duramax
Drives: 2011 335D
I've got 800 miles on mine and can't wait to chip it. For the cost and what I have read on the forum, you can't beat the JB. I have been chipping diesels since my 95 Ford Powerstroke and never had an issue doing it. I enjoy the passing power, as long as you don't beat on it, your fine. It's the most expensive car I have owned and don't plan on beating on it....too much
      12-12-2011, 05:10 PM   #83
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Messiah, did you end up pulling the trigger? I am highly tempted, but I definitely have some questions about it....
      12-13-2011, 07:34 PM   #84
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
Just install it already!!!!!
And please beat on it. It begs for it. You'll see.
      12-31-2011, 02:04 PM   #85
WEEZAR
WEEZAR's Avatar
Drives: 2010 335D
Tuner Info
Hello, I am new here and have been doing a lot of research and I am trying to figure out which is the best Tuner to buy and where the best place to buy it is?
I thank you for any and all the info and help.
WS
      12-31-2011, 02:15 PM   #86
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
WS
If you can find someone to help you with the language barrier, Germany is a hotbed of tuners for the d. You don't need to look outside the country you're in!
Edit: More info: try www.pp-performance.de
-and-
look at the second dyno sheet in the first post of this thread for their phone number: http://www.e90post.com/forums/showth...orming+imports
      01-23-2012, 10:07 AM   #87
Alex@Helix
Drives: e92 335i
Hey Guys,
If anyone is in the Philadelphia area and would be kind enough to bring your car over for a test fitment we would be thrilled to have you. Please contact me via PM and we can set up a day and time.
Alex
      01-23-2012, 10:19 AM   #88
cssnms
cssnms's Avatar
Originally Posted by Alex@Helix View Post
Hey Guys,
Alex
