08-02-2008, 08:35 PM | #23 | |
Rep 5,623
PS: the hunter is great. im trying to get that bow you couldn't but damn it still takes soooo long haha.
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
08-02-2008, 10:14 PM | #24 | |
Careful, I Bite.....
153
Rep 504
WTF are you talking about ??? |
08-05-2008, 07:01 PM | #25 |
Rep 5,623
well i mailed out the ram sticks to corsair today but now today my desktop is having problems now .
when i boot up i get a mobo message saying im in single channel ram (512mb vs. full 1gb) and i have to press f4 to confirm. shit so a ram stick in my desktop is busted too also corsair. corsair is like the best ram company why am i having problems? the ram in this computer has been in there for about 4+ years compared to just two on the other ones i just shipped to them.
08-05-2008, 11:36 PM | #26 |
Rep 3,288
If you had 2 sticks in your computer, and then took 1 out and are only running off one stick now. That is why you are being prompted. Because you are only using 1 channel, vs your previous 2.
You can fix this by going into your BIOS setting and making the appropriet alteration. But without knowing your motherboard or brand of BIOS, I can't really help you much from here. My advice would be to not change any settings and just wait for your new stick to arrive and install it. Also, when installing ram you want to install it in dual channel mode. Basically it boils down to this: There are 4 slots for ram. 1 2 3 4 (arbitrarily numbered from left to right in this example) Slots 1 and 2 are on one channel, and 3 and 4 are on another. So if you have only 2 sticks of ram you want to install them in 1 and 3, or in 2 and 4 (1 stick using each channel). This way you get the benefit of the dual channel ram configuration. And you can tweak your BIOS to best make use of this increase in bandwidth. I would read up in your motherboard's manual if you really want to get into it and learn what your particular BIOS has to offer. But honestly it sounds like you just want it to work again, so my suggestion is to just leave it alone and bare with the prompt at boot up until you get your replacement sticks in. Then install them in the same manner you had them installed before and it should all return to normal. (Assuming your replacement ram is the same size, type, speed, and requires the same voltage to run.) BTW, if you are building a new computer ever and are looking at ram. Not all ram runs at the same default voltage. I am using a set of Crucial Ballistix, 4 sticks at 1gb each. They run at around 2.2V which is nearing the upper limit for how much voltage ram can safely run on. So make sure you pay attention to all the statics if you ever buy a new different style or brand of ram. My short answer is: don't worry about it.
08-05-2008, 11:41 PM | #27 |
Rep 5,623
^ thanks man but this is for my other computer. both sticks are still in there and one day i turn on the computer and i get the prompt saying im running single channel. so one of my ram stick basically died on this computer right?
so i need to get my other computer's ram back from corsair before i can send this one back cause if i do this one i have no computer to use in the house lol.
08-06-2008, 10:25 AM | #28 |
Rep 3,288
Wow, 2 seperate computers had ram issues at the same time?
Please tell me your computers are plugged into a surge protector. For the 2nd computer, that just randomly decided that it was only running on single channel. Do the same tests for how much ram it is detecting and compare that to how much you know it should be seeing. This will tell you with the most clarity if a stick of ram is burnt out or not. Another option is that you just moved the tower(physically) to a new location and that somehow you banged it or set it down hard and the ram jogged loose from its socket. I'll say I doubt this is the case, ram sockets are pretty snug, but it is possible. So you should check to make sure they are both plugged in all the way. So to recap, check the POST for the ram count up, or check in device Manager to see how much the system is detecting to determine beyond any doubt if a stick has died. If the system recognizes all of the ram and you have a stick of ram installed in each channel then this is quite a wierd error. How old is this 2nd computer we are talking about now?
08-06-2008, 10:27 AM | #29 | |
Rep 3,288
08-06-2008, 11:41 AM | #30 |
Rep 5,623
both computers are desktops and they are both on surge protectors. the original problem PC, i mailed the corsair sticks to them for replacement so i believe that is settled for now until i get them.
now my desktop (3-4+ years) today when i turned it on i didn't get the prompt and when i check the device manager i have 1gb again LOL. if problems persist on this computer i will get another RMA with corsair for replacement but right now this computer ain't a biggie. i will make an update when i get the ram sticks back from corsair. once again thanks for the help
08-06-2008, 11:59 AM | #31 | |
Rep 3,288
08-06-2008, 12:18 PM | #32 |
Rep 5,623
lol yea it's funny to me also. if problems persist corsair has lifetime warranty so all i need to do is ship it back.
btw do you know what temperature a cpu normally operates? i have a koolance exos on my old desktop and when running non games its constantly at 80-100 (depending on winter/summer) and gaming its at 100-120 max (depending on winter/summer). im asking about just a normal cpu with cooling fan. 150?
08-06-2008, 01:31 PM | #33 | |
Rep 3,288
08-06-2008, 02:03 PM | #34 | |
153
Rep 504
08-06-2008, 04:39 PM | #35 | |
Rep 3,288
This excerpt is for AMD processors. But its roughly applicable to all CPUs. Here is the source site.
http://forums.amd.com/forum/messagev...&enterthread=y Quote:
08-06-2008, 04:46 PM | #36 | ||
Rep 3,288
Here are some more credible sources.
http://www.computerbob.com/guides/guide_cpu_cooling.php Quote:
http://www.tomshardware.com/forum/22...perature-guide Quote:
08-06-2008, 05:36 PM | #37 |
17998
Rep 9,378
On the second one that you haven't replaced teh RAM on, open it up, take out the RAM, blow out the sockets and the RAM (compressed air or just a good strong breath) then reseat and see. A dust bunny can short a contact. If the fan openings and such are really dirty, get a vacuum and suck teh case clean.
08-06-2008, 09:21 PM | #38 | |
Rep 3,288
08-22-2008, 07:24 PM | #39 |
Rep 5,623
well i got replacement ram sticks back from corsair and tried to fit them in and what happens it doesn't fit. i looked up the model and find it is server memory . i am happy they sent me x2 1gb sticks (compared to my x5 512mb sticks) but they sent me http://www.newegg.com/Product/Produc...sd1024rlp-3200 (server memory) for my desktop. the gap on the ram sticks don't match up with the mobo gaps (the part that is open on the ram stick).
or maybe i am wrong and desktops can use server memory? but they don't fit. before i write an e-mail to corsair am i right?
08-23-2008, 01:50 AM | #40 |
Rep 3,288
Is the actual length of the sticks wrong? or is the slot just not fitting right. If the latter is the case, keep reading.
The slot in the contacts at the bottom is never right in the middle. This is done on purpose to make sure you put the ram in the right way. Did you try facing the ram the other way to plug it in? I'm pretty sure you did, but thats all I can really though of. I'm not familiar with ram that is labelled as "server" specific. The picture from newegg.com looks like a normal stick of ram though. I'd say try to line up the slot and try once more.
08-23-2008, 03:10 AM | #41 |
Rep 5,623
thanks for answering made another thread here: http://e90post.com/forums/showthread.php?t=165716
to keep it short, i double checked the ram sticks and corsair def sent me the wrong ones right? original: http://www.newegg.com/Product/Produc...82E16820145548 Type: 240-Pin DDR2 SDRAM Capacity 512MB Speed DDR2 533 (PC2 4300) Cas Latency 3 Timing 3-3-3-8 Voltage 1.8V ECC No Buffered/Registered Unbuffered Heat Spreader Yes Replacement: http://www.newegg.com/Product/Produc...sd1024rlp-3200 Type 184-Pin DDR SDRAM Capacity 1GB Speed DDR 400 (PC 3200) Cas Latency 3 Voltage 2.5V ECC Yes Buffered/Registered Registered Heat Spreader No
08-24-2008, 08:12 AM | #42 |
539
Rep 18,123
Yes, they definitely sent you the wrong ones.
Check your other thread. You don't want to mix ecc and non-ecc memory as well as it won't physically fit due to the # of pins.
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
08-24-2008, 01:12 PM | #43 |
Rep 5,623
does the "PC" part matter? for example PC6400, PC3200, etc? if i need ram sticks for example ddr2 800 i can get ddr2 800 pc6400, pc3200, etc and they will all work?
also for these two ram sticks below can i put them in all 4 ram slots and they would all work in dual channel? the timing, latency, and voltage are different between the two. current: http://www.newegg.com/Product/Produc...82E16820145454 want to add: http://www.newegg.com/Product/Produc...ir%20ddr%20500
