08-29-2022, 01:52 PM | #23 | |
13266
Rep 19,789
Cruise Mode 2 (Cruise with steering/lane control/Assisted Driving) is the feature that keeps the vehicle centered in the lane.
08-29-2022, 01:53 PM | #24 | |
Rep 2,946
Drives: 2020 BMW 530xe
On my G30 w/ SP15A it will first go red, then start beeping, then pump the brakes a couple of times with a small gap between of maybe a second or two, and finally it will disengage and fallback to lane keeping assistant. I believe on the SP18 cars, like the X5, it will try to pull you onto the shoulder automatically and stop the car. But I haven’t tested a SP18 car to confirm. |
08-29-2022, 02:08 PM | #25 | |
Rep 4,333
In terms of Cruise Mode 2 ((Cruise with steering/lane control/Assisted Driving) is the feature that keeps the vehicle centered in the lane)....that seems to work very very well on my car with 3/2022.52 with little to no ping ponging. |
08-29-2022, 02:16 PM | #26 | |
13266
Rep 19,789
08-29-2022, 02:27 PM | #27 | |
185
Rep 355
FWIW, in my experience:
Lane departure with steering assistance, when active, would aggressively steer the vehicle when "close" to the lane marker, and/or when the system got confused. Usually this was not noticeable, as desired; exceptions were when exiting freeways and drifting over painted lines to smooth the exit line (when the system could jerk the car back into the "lane", since the exit was not a smooth curve), and when a lane you're in splits into two (eg: when a turn lane split the current lane, and the system would sometimes jerk the vehicle to one side). For cruise control with lane assist, there is much more ping-ponging, as the vehicle makes regular "corrections" toward the center of the lane, and almost always overshoots (and corrects the other way, and repeats), rather than "aiming" for a spot further down the road as a normal driver would do. This is probably okay for some drivers (ie: I've been in vehicles with people who drive like this anyway); for me, it's very distracting and off-putting (I'm used to driving more smoothly and with less small swerves). It also can disengage unexpectedly if the light level changes dramatically (eg: going under a bridge), and can get confused by temporary barriers next to the roadway, and/or unclear lane markings. Hopefully that helps clarify my personal experience with the systems.
08-29-2022, 02:58 PM | #28 |
Rep 792
Lane Keep Assist is separated from Steering Intervention. I think it's the latter that bothers some me included. Keeping LKA on only should not turn on SI but sometimes it does. You could reset the iDrive and it most likely will fix it. For those folks that noticed some features turning back on/off even after setting the other way, did you use different key fob? When you make changes, they will be assigned to the key fob you have at time. If you grab the other key fob, you won't see those changes that you made. It happened to me before and I b***ching about the system not working but it turned out it was me. I have one fob attached with office keys that I use on weekday and one without anything that I would use on weekends. That was what happened to me.
Marty in NY2718.50 |
08-29-2022, 03:00 PM | #29 | |
Rep 4,333
08-29-2022, 03:02 PM | #30 | |
Rep 4,333
08-29-2022, 03:21 PM | #31 |
13266
Rep 19,789
I think what you mean to say is Lane Departure Warning is separate from Lane Keeping Assist/Steering Intervention. BMW calls their Lane Keeping Assist - Steering Intervention.
08-29-2022, 03:35 PM | #32 | |
Rep 766
MJBradley1967192.00 |
08-29-2022, 03:41 PM | #33 | |
Rep 766
It is also a helpful nudge re: using the turn signal when changing labes |
08-29-2022, 08:58 PM | #34 | |
Rep 156
Around town the lanes are narrow, and while I keep lane departure on (lowest intensity), I find any steering intervention totally annoying, so I turn it off. |
08-30-2022, 09:02 AM | #35 |
Rep 538
I discovered this through trial and error. My wife keeps a fob in her purse but never drives the car so hasn't set up a profile. If she gets in the car first, the iDrive display is different and some of my defaults aren't activated. I have to manually change the driver profile.
09-10-2022, 02:56 PM | #36 | |
106
Rep 381
I’m actually a good driver with speeding tickets back in 1982! Also lucky lol. Got sideswiped by a turning semi in 2012 and that’s it. Put a lot of miles on when I was a traveling sales rep. Just don’t like the lane thing. My GF however loves it in her Audi A6 Last edited by Keithwand; 09-13-2022 at 10:07 AM.. |
cellarrat517.00 |
02-27-2024, 11:39 PM | #37 |
Rep 10
x5 lane departure with steering intervention
I know this topic has been slow for a while, but I had an unusual experience driving tonight. My car is an X5 50e with the latest firmware/software (11/2023.58). My settings as it relates to lane departure warning were "early" with steering intervention "on". I was not using any assisted driving modes (ie no cruise control of any sort). Driving at highway speeds, a lane entered the highway from the LEFT. The lane markings for that lane ended early. What I think happened is that my car detected the end of my lane marking and picked up the solid white line lane marking the entering lane and because of steering intervention it pulled my car quite dramatically to the left to keep me in the lane and then pulled me back quickly to the right as the left entering lane was rapidly merged into my original lane. I was fortunate that my hands were on the steering wheel and I tried my best to resist the cars decision, but the steering intervention can be quite forceful. I had 3 passengers in the car who were questioning my driving ability. Anyway, I have turned off the steering intervention now and may try that same route again to see if it repeats and/or generates a warning. It is a shame because I generally think the steering intervention could be life saving but this type of "false positive" as another posted mentioned earlier is a problem. If any of you see any other explanation for this, I would be happy to hear it. Thanks.
02-29-2024, 06:05 PM | #38 | |
Rep 80
You are passing bikers in your lane by crossing the centerline and the lane assistance with steering intervention "feature" jerks your car back towards the bikers. I have had this happen several times. Yes, I could have signaled to avoid this but that is not my normal behavior in that situation. I turned it off. I have also had several other false positives where it intervened because it got confused by lane marking patterns. Not ready for prime time IMO. |
02-29-2024, 09:17 PM | #39 | |
Rep 2,614
Drives: 2024 M4 Convertible
I never have it get confused on lines as mine only interferes when it's actually going over a line, weird lines on the road don't affect it, and strangely painted ones are never an issue enough that it falses on me. |
03-01-2024, 07:57 AM | #40 |
Rep 849
I've experienced the issue with the lines for the merging entrance lanes, but it's easily corrected. IMO turning it off would be an example of the solution being much worse than the problem.
M3 - X5 - 911 - Miata - Raptor - Edge
03-01-2024, 09:12 AM | #41 | |
Rep 4,333
I use mine and the car has never tried pulling me back into the lane, the lane assist works quite well. |
03-01-2024, 09:36 AM | #42 |
Rep 8,694
Drives: eVeRyOnE mAD!
I don’t like the steering intervention. I’ll use it on occasion but rarely
03-01-2024, 10:24 AM | #43 |
Rep 80
It is very common for people to not use their turn indicators when passing bikers. When the lane indicators expand to an island of double yellow area (a Y-type expansion) the system sometimes wants to follow the line towards the center right into the do not enter island. I can only tell you that this happens and it wasn't a one-off. Perhaps my system is defective or it is in a different configuration, but it causes more danger than safety. I don't have DAP and possibly that makes the intervention smarter.
03-01-2024, 10:40 AM | #44 | |
13266
Rep 19,789
I would suggest making sure you have it set to Early and give it some time.
