03-01-2024, 08:26 PM | #45 | ||
185
Rep 355
To be fair, it's perfectly fine roughly 99% of the time or more, I would say. As long as you an tolerate a terrifying, unexpected, and potentially life-threatening false-positive intervention every month or so, where the vehicle will try to kill you and/or someone else, and you are sure you will be gripping the steering wheel with enough force to react and overcome it whenever it randomly occurs, then this system is fine to use as-is.
eluded3041.50 |
03-02-2024, 09:01 AM | #46 | |
Rep 4,333
When I first got behind the wheel of mine, I cautiously went about testing the driver assist features to see how they worked, I read the manual but you have to do it yourself and experiment. I already had some experience with my wife's car which has lane assist features but they were quite limited compared to the X5. Now that I've driven it a couple of years and have seen all sorts of good and bad road markings, I pretty much know its limitations and sometimes odd behavior and have found it very easy to manually overcome its limitations. I now "understand" the car and find it quite good at the far majority of road hazards one normally encounters. The way I see it is it's one step closer to the world where we have fully autonomous vehicles and we literally sit in the back reading our tablets. Not saying I would like that world but I can see it coming. When it does, these autonomous cars will be programmed to follow road rules, they won't have the ability to ignore them as we humans choose to do at times. So the X5 is partially on its way there and if we allow it to do as its programmed, and make the slight corrections when needed, it is helping to create a safer mode of transportation which is better for all who share the road. |
tooloud10766.50 |
03-02-2024, 03:26 PM | #47 |
Rep 415
I may have posted this before:
Personal transportation is at the Vanguard of freedom. Cars aren't just practical tools, but manifestations of liberty. Driving isn't a chore crying out to be automated. It is the greatest spiritual innovation of the last 200 years. - John Pearley Huffman, in Car and Driver I sure am glad I had lane change, or MCAS, or whatever they call it turned off when the hot shot trailer tire exploded in front of me this week. I had enough going on without having to wrestle the car. Mark
2022 X5 45e - Wife's daily driver
2023 GX460 - My daily driver 1988 4Runner on 40's - Off-road trailer queen 2001 PSD Excursion - The slave that drags the queen |
03-03-2024, 09:30 AM | #48 |
Rep 4,333
Something similar happened to me on my way down to Florida recently on I75. There was debris from a semi tire in the lane next to mine, I was using DAP and had my hand on the wheel like you're supposed to. A small truck ahead of me in the right lane hit the shredded tire part and it flew into my lane in front of me. I simply turned my wheel and avoided it. Using DAP doesn't mean you can sleep at the wheel, it's only an assist. Turning the wheel while on DAP is easy.
It's very easy to manually overcome any of the driver assist features. Plus you get to select how aggressive you want some of them in the first place. I don't understand why people cannot figure out how to use them and simply turn them off. I use it all the time and have come across many unpredictable situations on the road, DAP has never gotten in the way or caused issues for me. I do turn it off when in messed up construction zones where they attempt to paint new temporary lines but don't adequately cover up the old ones. To me this is just using common sense. I think if people learned how to use the DAP features and not try to interject their bad driving habits, they could get along with it just fine. |
03-03-2024, 10:40 AM | #49 |
Rep 415
LOL!
03-03-2024, 11:00 AM | #50 |
Rep 80
Without DAP you are required to go through a bunch of menus to turn lane keeping / steering intervention on and off.
I find the front end collision avoidance to work reliably. There is no babysitting and trying to read the mind of driver assistance features required. Because the problems tend to show up in already challenging driving situations it can make things more stressful. If I get a tug on my steering wheel my first thought is "it is making a mistake again". The impulse is to always fight it. It grabs your attention and that might be useful sometimes, but not so far for me. Too bad you can't automate a recording for faulty driving intervention so BMW might be able to improve results. If a safety feature is avoiding danger much more often than it is potentially inserting danger then it will be useful and more importantly trustworthy. We had "stay in lane" warnings beeping for 15 seconds straight on a straight highway a couple times on the last trip for no known reason, driver assistance was just lost. Working 99% of the time is not good enough when the driver works 99.9% of the time. A 10X false positive rate is not usable, a 0.1X is very usable. Generalized driving assistance is magnitudes harder in software than avoiding rear end collisions and it shows. My guess is DAP equipped cars perform better. |
03-03-2024, 11:41 AM | #51 | ||
185
Rep 355
The better of a driver you are in general, the higher the quality the assistance needs to be to be net positive. For me, I find the software to be a significant net negative in overall safety and dangerous incidents. I freely admit that for others on this forum and in the real world, that experience and result may be inverted, and for people for whom it is, I would probably recommend using the system. Notably, this is also a large part of why people might have vastly different perspectives about how "good" BMW's systems are. For people who are otherwise good drivers, the systems may seem very bad (based on increases of dangerous incidence rates). For people who are otherwise bad drivers, the systems may seem good (or even very good, if one is a very bad driver normally). It's all subjective, based on how one operates a vehicle without such systems.
03-04-2024, 09:09 AM | #52 | |
Rep 4,333
I consider myself a good driver and can certainly get where I'm going without any assist features.. .. but, using DAP over long drives has completely and repeatedly prevented arm and shoulder fatigue pain and has never caused an unsafe situation for me. I have fine tuned its assertions to my liking and it's very easy to manually overcome them. Do I completely trust them? Hell no, my hand is alway on the wheel somewhere |
LDT1539.50 |
03-04-2024, 12:24 PM | #53 | |
Rep 849
The value for me isn't that I can pay less attention to driving, it's that you can relax a bit and not have to constantly provide steering input the entire time. I just keep a hand on the wheel and if it tugs a bit I already know exactly what's going on and correct if necessary. It's always in the back of my head how the system is likely reading the road--if I see one of those odd entrance ramps that were mentioned, I'm ready for it. If it's raining or snowing, I know the system won't work as well. If I see the highway markings are missing, I already know it's going to have trouble. If any of us had seen this technology in the 80s we'd have been astounded but instead a lot of people dismiss it for not being completely perfect right out of the box.
M3 - X5 - 911 - Miata - Raptor - Edge
Marty in NY2718.50 LDT1539.50 |
03-04-2024, 03:17 PM | #54 | |
Rep 4,333
LDT1539.50 |
