01-24-2023, 11:32 PM | #1 |
Rep 445
Tire Chains 2023 X5 45e
Planning a quick snow trip and would like to know what tire chains folks are using. I believe in CA it is mandatory to carry them with you.
The truck has Pirelli P Zero run flat tires. Rears are 335/35/R21. I assume only rear axe is required? For anyone who has these tires how do they do on their own in the snow. Anything special required to set drive mode etc? |
01-25-2023, 12:01 AM | #2 |
Rep 6,805
Sorry, if you believe the manufacturer, you should NOT use chains on your wheels. Here's what the user's manual says about it...
Use only in pairs on the rear wheels, equipped with the tires of the following size: ▷ 265/50 R19. ▷ 275/45 R20. Does nobody ever read their manual? |
comebackidlci32.50 |
01-25-2023, 06:54 AM | #3 |
13266
Rep 19,785
Those are summer tires. Don't go anywhere near cold, let alone snow, with those. They shouldn't be used below 40 degrees.
sygazelle11413.50 |
01-25-2023, 08:16 AM | #4 | |
Rep 538
HOWEVER, I don't have 21" wheels, only the 19 all-season RFT. If I had a car set up for performance, I'd probably just avoid winter driving entirely. |
01-25-2023, 11:39 AM | #5 |
Rep 3,681
You probably have same winter usage as me. The big issue is summer tires. You can put chains in the rears and get traction, but your front is responsible for turning and 80% of braking. With summer tires, you will have tough time to remain safe, especially in current state of Cali snow belt. My suggestion is to replace with a set of all season and bring chains.
01-25-2023, 01:54 PM | #7 |
Rep 1,075
I haven't used it on mine, but my buddy took his 45e up to Mammoth Mountain a couple of weeks ago when they had that insane winter storm. He used textile snow chains and said it worked great. No damage on his OEM 21" 741M's either. I'll ask him for the exact product he ordered and get back to everyone that's interested.
01-25-2023, 03:22 PM | #8 | |
Rep 445
XMan9.00 |
01-25-2023, 08:30 PM | #9 |
Rep 6,805
In both the app supported user's manual, the printed one, and the .PDF, just search for tire chains...it pops up quickly...the user's manual is useful, and because it's so big, search is your friend!
01-26-2023, 08:05 AM | #10 | |
Rep 538
01-26-2023, 11:17 AM | #11 | |
Rep 3,681
The big question is do you put them on all 4, or follow the manual just to put on rear. If you follow manual, then the summer tires in front are very ineffective on braking or turning. Will you take that risk?
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 01-26-2023 at 11:24 AM.. |
01-26-2023, 11:20 AM | #12 |
13266
Rep 19,785
I don't about that, that traction looks good enough to hold the vehicle upside down.
eelnoraa2032.50 |
01-26-2023, 11:25 AM | #13 |
Rep 3,681
fixed fixed.
2022 G05 B58/PHEV
+ a few very old BMWs |
01-26-2023, 12:51 PM | #14 | |
Rep 6,805
If you don't, that menu won't appear. THe issue is, if you DO have rear wheel steering AND you put chains on, you must turn off the rear wheel steering, or you can damage things as the clearance won't be sufficient. If you DON'T have rear wheel steering, there's no reason to have that menu item. Note, the printed version of the manual has stuff you may not have in your vehicle...the one IN the vehicle is at least supposed to be customized for your delivered options. If you search on "chain" versus "snow chain", you'll get to the needed info (in my copy, it's on page 368, but that can vary year-to-year). |
01-26-2023, 04:38 PM | #15 | |
Rep 1,075
https://www.amazon.com/dp/B008RWU8CI...hk_typ_imgToDp |
01-27-2023, 09:42 AM | #16 | |
Rep 538
I thought maybe the app could access the car-specific version remotely but the pdf is just like the printed version. It doesn't seem that it would be that hard to do since the app has access to so much other data in the vehicle. |
01-27-2023, 11:47 AM | #17 | |
Rep 3,406
If you do rent, make sure the vehicle you rent has All Season tires. There is something I didn't know for the longest time and it's info on this forum that brought it to my attention. Summer tires are bad news in winter not due to snow. They also fail miserably even without snow when the temperature is cold. The rubber compound used in summer tires becomes useless grip-wise when the temperature falls below 40 degrees or so. Good luck. Have fun on your trip. |
01-27-2023, 01:04 PM | #18 | |
Rep 262
I'm in Norcal with a 45e; we go skiing a ton in Tahoe, so for us it made sense to swap my summer 741m (21") tires/wheels for the 740m all seasons for the winter then back in the summer (which is what we do). BUT, I realize that's a big pain the butt if you only drive to the mountains a few weekends a winter.
If the weather looks 100% clear (like today) for your trip, AND, once in your destination you don't drive much, you might be fine with your set-up as there is no chain control (but you'd want to minimize driving and drive very careful in the mountain). Otherwise, the tire socks mentioned will NOT get a pass through CalTrans, you will need tire chains or cables. SO the question is all 4 or only rear; I think all 4 while a pain is the gold standard for awd vehicles that need chains/cables (PRO TIP: spend the extra few minutes to make sure they are tight! Then after 10 mins of driving; pull over and retighten real quick). Yes Quote:
01-27-2023, 01:17 PM | #19 |
MGySgt
637
Rep 1,256
Drives: See Garage List! ;-)
Garage List 2010 M5 [10.00]
2016 BMW 340xi M Sport [9.00] 2019 X5 50i M Sport [5.50] 2010 535xi [0.00] 2013 M5 [0.00] 2012 X5 M [0.00] |
When I was stationed in Bridgeport, CA area,...I found "Tire Cables" to be more favored over "Tire Chains"! Safe travels out there...
JMD
01-27-2023, 03:29 PM | #20 |
Rep 445
Thank you all for the candid feedback! I think we have decided to just rent a Tahoe or Suburban with 4WD. It’s just not worth all the effort to swap tires etc for a once a year trip. Was really looking forward to taking the 45e to the snow but oh well!
Told my wife we could take the X5M instead and she vetoed that idea. |
01-27-2023, 03:36 PM | #21 | |
Rep 262
Prob a good call; though you could buy a 4 pack of cables and have them in case chain control comes on and you'd be good to go.
Bonus for taking rental is your new X5(s) will stay rock chip free and clean (the mountain roads are ruthless given the grime and gravel that spread everywhere...!) Quote:
01-27-2023, 05:28 PM | #22 | |
Rep 3,681
Summer pattern on snow/ice is bad. shallowest ramp, I will have issue going up. Braking distant is super long
2022 G05 B58/PHEV
