01-12-2024, 11:53 AM | #23 | |
13597
Rep 20,236
No, that is incorrect. No one has a Li-ion starter battery. All starter batteries are AGM. You will be fine using that charger.
01-12-2024, 12:06 PM | #24 | |
Rep 70
What about the battery under the hood? I see it could be either a 60Ah AGM or a 10Ah Li-ion. If I have the 10Ah Li-ion one, will the CTEK charge it as well? |
01-12-2024, 12:09 PM | #25 | |
13597
Rep 20,236
01-12-2024, 12:10 PM | #26 | |
Rep 4,421
This is the one I use on my X5, works great. Press the Mode button to select the battery type and like Turtleboy said, you will use AGM as that is the 12 battery under the cargo area in your car. If you received a severely drained message, there's no way to know if your battery will be able to be saved. It may indeed take a charge but it may not last, you won't know till trying it so go ahead, put the CTEK on it, select the right mode and connect it to the charging terminals in the engine bay, leave the hood open a bit and be prepared to wait up to three or four days of charging before the CTEK gets to the float stage. If it never does, you may need to replace the battery. |
01-12-2024, 12:12 PM | #27 |
Rep 70
So sorry, mine is a 2021 xDrive40i. AFAIK it has the 48v Mild Hybrid. And mine has 2VR 2-axle air suspension so I think that means it doesn't have ASR and therefore it doesn't have the Li-ion battery under the hood. Am I right?
01-12-2024, 12:15 PM | #28 | |
Rep 70
01-12-2024, 12:21 PM | #29 | |
13597
Rep 20,236
The 10aH Li-Ion battery in the dual storage system were in vehicles that didn't have the active roll stabilization. For vehicles that did they had an AGM battery under the hood. I have not seen the LCI technical docs but my understanding is the dual storage system goes away when the vehicle goes to the mild hybrid system so even those with ARS do not have another AGM All that said, just charge your 12v on the AGM setting with the hood open and you should be fine assuming your battery is not shot.
01-12-2024, 12:24 PM | #30 |
Rep 6,893
Depending on the model and options, you could have up to three batteries, but you should always use the charging terminals under the hood. IF you have a 48vdc battery, it will only be recharged manually if your battery charger can output more than 20A, which a battery tender generally cannot reach. When the 12vdc batteries are properly maintained, the system should be able to keep the 48vdc one charged. If you let them get too low, you may never get to recharge the 48vdc one adequately.
01-12-2024, 12:25 PM | #31 | |
13597
Rep 20,236
01-12-2024, 12:28 PM | #32 | |
Rep 70
From what you are saying, assuming they return the car back to me telling me all is good, then I should just start using the CTEK in AGM mode and need not worry anymore. |
01-12-2024, 12:32 PM | #33 | |
13597
Rep 20,236
Yes, that is all you need to do. I guess given the post above, the question is if the 48v hybrid system supplanted the dual storage system or is in addition to it. Edit; I just looked up the 12v Li-ion battery (Part# 61215A4AF23) and it says it fits X5 40i up through 2023 (like wasn't updated for 24 yet) so given that it seems like there would be three batteries in all mild-hybrids.
01-12-2024, 12:43 PM | #35 |
13597
Rep 20,236
The batteries under the hood, no matter what they are, are not intended to be, nor need to be, charged separately by outside sources. Those are taken care of by the battery management system.
01-12-2024, 01:35 PM | #36 | |
Rep 4,421
Now lets see if I have learned something here via this thread and those who have pitched in to help.. .. .. The 12V AGM (under the rear cargo area) is responsible, via the battery management system electronics, to keep the 48V properly charged. It does this via a DC-DC converter to increase the voltage from 12 to 48. When you connect your CTEK to the charge terminals in the engine bay, it will charge the 12V AGM. If the 12V AGM is not properly charged, goes bad, etc., it will no longer be able to properly charge the 48V battery. Basically, if you have good batteries and drive the car on a regular basis you won't have anything to worry about. I do put the CTEK on mine once in a while but that's because it's a trip car and can sit idle for months at a time. Have your dealer give you a good tour of the car and the battery system, pointing out where the batteries are and what they are responsible for, ask questions and be sure to pose the question about which battery they believed was losing charge, what they did to charge it and their thoughts on its ability to continue to hold a charge cause like I said, once a battery starts its decline to such low levels it can have irreparable damage and never hold a full charge again or not for very long. |
01-12-2024, 01:44 PM | #37 | |
13597
Rep 20,236
I think the way the 48v battery is charged is using the alternator. It may also be charged with the 12v AGM but have not seen anything on that.
01-12-2024, 01:48 PM | #38 | |
Rep 4,421
01-12-2024, 01:50 PM | #39 | |
13597
Rep 20,236
My M430i is a mild-hybrid and never noticed a third one but never looked for it.
01-12-2024, 02:22 PM | #40 | |
Rep 4,421
I only found two, the 12v AGM in the back and the 48v Li-ion in the engine bay. I also looked for that missing ASS button, but still to this day cannot find it ... dang! |
aMIC31.00 |
01-12-2024, 02:28 PM | #41 | |
13597
Rep 20,236
The interesting thing is that on multiple sites it says the 12v Li-ion battery for the dual storage is for the 2021 40i.
01-12-2024, 02:57 PM | #42 | |
Rep 4,421
Here's some related stuff.. .. |
01-12-2024, 03:12 PM | #43 | |
13597
Rep 20,236
Version 1 of the dual storage is when the AGM battery is under the hood.
01-12-2024, 03:28 PM | #44 | |
Rep 4,421
