01-12-2024, 03:34 PM | #45 |
13266
Rep 19,785
That is what it seems like. What we need is someone with the M60i and the Adaptive M Professional Suspension option to check and see how many batteries they have. Since that has now gone to the 48v MH the AGM under the hood may be also.
01-12-2024, 07:16 PM | #46 |
Rep 70
Got my car back. I was told all is well. I have now plugged in the CTEK and it's been an hour and it's at Stage 4.
Does it make sense to use the eyelets and have them permanently mounted to the posts? This way, it's easier to plug and unplug the CTEK. Mind you since we have to open the hood anyway, maybe it makes less of a difference than if we can plug and unplug from the outside so to speak. https://smartercharger.ca/products/c...31726989967463 BTW, what's under my hood looks same as what's under Marty's I don't see 12V batteries (Li-ion or AGM) near the Positive battery post. And the 48v battery is underneath/closer to the windshield - LG Chem 10Ah 440Wh 44V battery. |
01-12-2024, 07:31 PM | #47 | |
13266
Rep 19,785
01-12-2024, 07:33 PM | #48 |
Rep 6,805
It looks like three batteries in this diagram, but it's for the 50i, not 40i. https://www.realoem.com/bmw/enUS/sho...16#61128797706
01-12-2024, 07:40 PM | #49 | |
13266
Rep 19,785
01-13-2024, 07:14 AM | #50 |
Rep 70
Looks like I might be ok…. Checked this morning and CTEK was at Stage 7.
It’s so easy to plug and unplug at the posts and hopefully this is something I only need to do once a month, I’m not going to make things more complicated by attaching the eyelets. Thank you both TurtleBoy and Marty in NY for your patience and responses. |
Marty in NY2718.50 |
01-13-2024, 08:05 AM | #51 | |
13266
Rep 19,785
01-13-2024, 09:44 AM | #52 | |
Rep 4,333
01-13-2024, 10:36 AM | #53 | |
Rep 70
Had he said it's the battery in the trunk, then at least it makes more sense. |
01-13-2024, 11:00 AM | #54 | |
Rep 4,333
You said you picked up the car last week, right? I take this to mean you just bought the car and therefore it could have sat on the lot and little by little the battery drained cause they didn't have a charger on it. In any event, if they did not replace either one and simply put a charger on the charge terminals in the engine bay, you better keep a close eye on the state of charge on your 12v starter battery. Providing you're driving the car on a regular basis, you should not need to put your CTEK on it for it to hold a proper charge but if it doesn't, then you'll be looking at a replacement in the near future. |
01-14-2024, 09:05 AM | #55 |
Rep 70
It was the sales person whom I spoke with, the Service Advisor was there as well but didn't say anything or disagree with the sales person.
I was told the car was delivered with over 80% SOC but that's because the car was plugged in while its PDI was being done. Which I guess was their way of saying it was fine when we delivered it and it's something I did that drained it - which I suppose is possible. It's a new car to us and I was definitely checking out the various settings and features and not always with the engine running. I will definitely continue to monitor the car and the battery condition. In the meantime I have done two charging cycles with two different chargers (the CTEK MXS 5.0 and the BMW OEM one) and twice it went from stage 3 to Stage 7. And also, since I brought it in to the dealership, at least the issue has been "documented". |
01-15-2024, 12:35 AM | #56 |
Rep 6,805
BMW doesn't try to keep the 12vdc battery fully charged, although in some use cases, that can happen. That's one reason why they use an AGM battery which is longer lasting if it is discharged more than a regular lead-acid battery.
02-16-2024, 09:21 PM | #57 | |
Rep 1,143
Drives: 2022 x5 40!
02-18-2024, 10:06 AM | #59 |
Rep 48
I have 2023 model with mild hybrid system and CTEK 5.0 charger always got stuck at stage 3.
Then I use Schumacher SC1281. It is finally charged and is very quick. It is with 30A boost so I guess it also charges the 48v’s battery. |
02-18-2024, 10:45 AM | #60 |
13266
Rep 19,785
That is what I use and have been successful. I have only done the 30A boost once, other times just used the charge/maintain mode.
02-18-2024, 01:44 PM | #61 |
Rep 264
I am always fascinated by what the 12/48 volt system does. On cold starts the 12 volt is the starter battery. When ICE is at or above 140F the 48 volt is the starter battery
02-24-2024, 11:20 PM | #62 |
Rep 1,143
Drives: 2022 x5 40!
[QUOTE=MattAu;30812502]It was the sales person whom I spoke with, the Service Advisor was there as well but didn't say anything or disagree with the sales person.
I was told the car was delivered with over 80% SOC but that's because the car was plugged in while its PDI was being done. Which I guess was their way of saying it was fine when we delivered it and it's something I did that drained it - which I suppose is possible. It's a new car to us and I was definitely checking out the various settings and features and not always with the engine running. I will definitely continue to monitor the car and the battery condition. In the meantime I have done two charging cycles with two different chargers (the CTEK MXS 5.0 and the BMW OEM one) and twice it went from stage 3 to Stage 7. And also, since I brought it in to the dealership, at least the issue has been "documented". I did the same I used the ctek and after about three days, it charged the battery took it off ordered the BMW charger and now the BMW charger won’t charge it at all. It just stays at level 3️⃣so I took it off Decided to let it sit for a week and I’ll try again |
02-25-2024, 08:43 AM | #63 | |
Rep 4,333
[QUOTE=swainbmw;30932901]
02-25-2024, 08:59 AM | #64 | |
BMW CCA 69606
86
Rep 227
Are you saying that if I park, lock and then restart while engine temp is above 140F, the 48v system used? |
02-25-2024, 10:11 AM | #65 |
817
Rep 1,785
A bit off topic but related. I have a 2019 40i and also use a CTEK occasionally but my CTEK is an older model and instead of an AGM setting it has a snowflake symbol. A friend told me this is the same as the AGM setting and I should use it for maintaining AGM batteries. Is this correct? Thanks and pardon for going a bit off topic.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
02-25-2024, 10:23 AM | #66 | |
Rep 4,333
