08-27-2023, 08:32 AM | #45 |
Rep 159
This shows that its not really an orientation issue as both ends are "sealed". Whether or not they are water proof remains the question, but its not some open-ended breather tube.
08-27-2023, 08:48 AM | #46 | |
Rep 4,333
Since at this point I have not read a statement by your dealer as to how water got into the Xfer case, my assumption is that either the factory did not properly seat that vent tube or someone pulled it out and did not properly snap it back in. It might also be possible that the factory did not install the o-ring on the end of the vent tube...only your dealer has these answers. You can see in these pix how it attaches and if you are familiar with the type of latching mechanism that is molded onto the end of the vent tube, you will know how hard it is to remove, I mean you really have to yank it. . Last edited by Marty in NY; 08-27-2023 at 01:21 PM.. |
08-27-2023, 02:24 PM | #47 |
Rep 1,078
Maybe the problem is not a leaky breather hose, but one that's clogged or not functioning as intended. Transfer cases and fluids get hot when used, and internal pressure needs to be equalized so that fluid doesn't blow out through the shaft seals when hot. Sudden cooling of the transfer case by a couple inches of cold rain would create negative pressure inside if the vent tube was not working, and water could have been sucked in through the shaft seals. This is at least consistent with the laws of physics, and doesn't require water to acquire anti-gravity properties so that it can leap in mass quantity into a small diameter tube.
08-27-2023, 02:35 PM | #48 | |
Rep 3,681
08-29-2023, 06:30 PM | #49 |
Rep 159
I have driven over 125 miles since picking up the car after the fluid change and calibration, and not surprisingly there isn't much of an improvement in driveability.
It seemed like maybe there has been some mild improvement, but it could be that the only time it feels smoother is possibly related to the most recent sharp steering angle in the same direction. Example, if the last time I turned sharply was towards the left direction and then my next sharp turn was also left then it feels less 'locked up' on this second attempt. I think some apparent smoothness improvement may also be related to the pavement I'm on as smooth-ish asphalt seems the worst. So if there is more friction on the tires, then the more locked it feels. This is all conjecture and assumption at this point. |
08-30-2023, 08:27 AM | #51 | |
Rep 1,078
08-30-2023, 11:13 AM | #53 | |
Rep 4,333
08-30-2023, 11:22 AM | #54 | |
Rep 3,681
But perf center experience is different, what is the worst that can happen? transfer case fail binding? they take it in for maintenance, either replace fluid or the entire thing. We don't know what extenses of maintenance those demo cars go through
2022 G05 B58/PHEV
+ a few very old BMWs |
08-30-2023, 11:51 AM | #55 |
Rep 3,681
Looking at picture of @marty in ny, this should be the orientation of the transfer case. The "vent" tube and hot is above the rear drive shift. It is well hidden and protected. Even if you wade through water puddle, I doubt water will rush into that area, and push the tube off the hole.
Also, i wonder how much water it takes to get the fluid looks like a milk shake. I cannot be a few drops, right? must be a good volume. To get good amount of water in to the vent hole, the water need to be very high, above drive shift. I would even say water cover 80% of the transmission housing
2022 G05 B58/PHEV
08-30-2023, 12:11 PM | #56 | |
Rep 4,333
08-30-2023, 12:19 PM | #57 | |
Rep 3,681
I would do another fluid change as well. With the BMW transfer case fill/drain plug design, you really cannot get everything out at one go.
2022 G05 B58/PHEV
08-30-2023, 01:07 PM | #58 | |
Rep 159
This is my biggest beef with how BMW has treated my issue in that they are stating "outside influence" of water. While that may be true, if they advertise the car to be driven in adverse conditions without issue, and they show cars being used in that manner, and offer paid experience opportunities for people to use them in the manner that they suggest, I as a consumer would imagine if I did the same thing as they do and the car then malfunctioned, that is BMW's fault. |
08-30-2023, 01:46 PM | #59 | |
Rep 3,681
As for the performance center experience, it is certainly true what you see in perf center, the car actually have that capability. But that shouldn't surprised at all. What people don't see is what kind of maintenance it takes for car to live on those usage. A few times is OK. If that level of usage becomes often, the maintenance bill will there as well
2022 G05 B58/PHEV
08-30-2023, 10:08 PM | #60 | |
Rep 1,204
Drives: 2022 BMW X5 45e M-Sport
09-14-2023, 11:15 PM | #61 |
Rep 159
So something crazy happened this week.
As previously reported, I had driven it about 150 miles after the fluid change without much of a noticeable improvement. Sometimes it felt like there was a minor improvement, but there wasn't really any extreme improvement. I got busy and didn't feel like putting a lot more effort into pushing BMW to do more, so I just kept driving it. I had put on about 300 miles total since the fluid change before this week without any noticeable improvement since the first 150 miles. All of these 300 miles were in town short commutes at speeds below 55mph or so. Yesterday I had to drive to another city and I ended up puting on about 250 miles at interstate speeds. So for about 3 hours of my commute I was cruising at around 85mph. I got home late and didn't think much about it whether the car pulled into the driveway smoothly or not. Then this morning, backing out, there was no more binding or jittering. I kind of thought it was a fluke. So on my commute to the office this morning (about 4 miles drive) I made sure I did 2 u-turns and other slow, sharp turning maneuvers and lo and behold, it performed flawlessly! I was kind of shocked, to be honest. I have no idea if this is a mechanical/fluid learning that needed to happen with time and/or the right conditions (like higher speed), or if some sensor needed some specific conditions (speed, duration, temperature) to complete some kind of calibration that made it behave better. This is all speculation, but, remarkably, the binding seems to have gone away and it basically feels normal! What is ironic is that at the start of my drive yesterday, it was raining pretty good and I was thinking to myself "oh boy, lets see what else is going to break by driving in the rain!" lol I'll give it a few more days, but this is definitely not just some wishful thinking. I was mentally preparing to call BMW and get insurance involved so I think I just saved myself the $1000 insurance deductible! |
09-14-2023, 11:45 PM | #62 | |
42
Rep 33
09-15-2023, 02:34 AM | #63 | |
Insta~ f10_sapphire
158
Rep 412
I don't trust the bmw dealership with my vehicles. I only use a Indy shop I trust and use the best quality oil and OEM parts if needed. The dealership is nothing more than a stealership with kids doing your oil changes. Especially if your out of warranty. |
09-22-2023, 06:23 PM | #64 | |
42
Rep 33
My dealership has already told me that if i drive in any water and something happens to any of the mechanics under the car, my warranty will be voided. I’m guessing they are talking about the transfer case.. idk. But not very encouranging to buy another bmw in my opinion. This will probably be my first and last bmw. I wish all future bmw owners luck! |
09-22-2023, 06:31 PM | #65 | |
Rep 3,681
I think the C63 was not only driving in rain, it was driven through a deeper puddle that the car should be driving on. If ground doesn't have puddle, I highly doubt driving fast will cause hydrolock. The intake is well hidden that rain cannot get in. OR, early C63 is known to have injector stuck open issue. so fuel fills the cylinda when the car is off. The next time the car is turn on => hydrolock.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 09-22-2023 at 06:39 PM.. |
09-22-2023, 07:30 PM | #66 |
Rep 2,633
[QUOTE=fstezaws;30420675]I'm creating a new thread even though I had posted a few comments in another thread that was related to issues with the transfer case "binding" or "grinding" while driving at low speeds and sharp turning angles. I thought it would be better to make this a separate thread in case others have similar problems (whether in the past or in the future).
Brought in my 22 X5 M50i (about 17k mile so far, never missed any service intervals) into the local dealer for an issue I was experiencing: at low-speeds and sharp steering angles, there is very extreme binding/stuttering on the front drivetrain. It seemed obvious to me that it was a transfer case issue. I did some searching and found multiple threads related to transfer case problems with the current X5 and previous generations. My issue started immediately after driving in the first heavy rain of the summer (southern AZ monsoons). I didn't drive off-road and was only driving on a major road that had maybe 3-5" of water in some areas due to the intense rain. I had actually taken a video in my office parking lot of the intense rain minutes before heading home because it was 119° outside and there was incredible hail coming down. I noticed the binding when I was pulling into my driveway at home. This is a 2-3 mile drive at most. I thought maybe the rotors were wet, or some leaves or twigs got into some sensor, and that after everything dried out the issue would likely go away. It never did. After about 4-5 days of experiencing this [...] Clearly BMW did not intend the X5 to be an actual SUV. It’s a luxury car with SUV styling I suppose if they won’t cover 3-5 inches of water! Seems unfortunate, but I guess that is the difference between an SAV and an SUV 🤷🏻‍♂️ |
