02-09-2022, 09:59 AM | #67 |
BMW Enthusiast
25
Rep 303
This is awesome, thank you imdiekeb for the coding instructions. This issue was driving me crazy. Now I just need to figure out how to stop the seatbelt tug and I’ll be set.
02-09-2022, 11:41 AM | #68 |
Rep 692
@imdiekieb
This is great thanks so much I know people in the g20 forums will try to apply and see if it works too. Can you briefly explain what each of these changes do? That would help me immensely.
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
02-09-2022, 01:03 PM | #69 |
237
Rep 372
I can confirm that these BimmerCode changes work on mine
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone) |
gnolivos319.00 |
02-09-2022, 02:40 PM | #70 |
Rep 692
Only thing I don't like is having to set night brightness to minimum in iDrive. Seems weird step to take. What happens if set to mid or max?
02-09-2022, 04:45 PM | #71 | |
Rep 83
When you set it to min, you still have full dimming of the center display and instrument cluster, they can be adjusted to brighter/dimmer via the wheel on the side of the dash next to the headlight controls. If you DONT set it to min, (I tried it both ways and left it in the middle setting where I Had it before)... the center control display seems to be a bit brighter than the instrument cluster at night. It was a subtle difference honestly, but without it set to min, the center display seemed more "out of sync" with the instrument cluster, meaning it was brighter than the instrument cluster. Dimming with the wheel still works, but as you dim for nighttime the control display is still brighter than the IC. When you set it to min as described, they are more in sync to me with equal brightness levels on both screens and you can still have full dimming control with the little whee. You have plenty of range from very dim to very bright which to me seems more than enough for those who like it very bright at night (it was still painfully bright at the brightest setting). I found the sweet spot to have the wheel somewhere in the middle of the range and the control display setting to be at the minimum as described (although it's not a required step, the IC daytime brightness issue is resolved whether you do that step or not). |
02-09-2022, 05:58 PM | #72 | ||
Rep 692
02-09-2022, 06:53 PM | #73 | |
Rep 130
22 BMW X7 M50i
24 Porsche Macan GTS 24 MB GLS 580 (wifey) 23 Countryman JW Cooper (wifey) |
02-09-2022, 08:01 PM | #74 |
Rep 508
Drives: 2022 X5 xdrive40i msport
02-10-2022, 05:11 AM | #75 | |
Rep 2,072
For cars that don't have this dimming issue (often its tinted windows that do it), their dash is naturally this bright anyway. All this coding does is stop the dash from dimming when it would normally not dim in other cars. |
02-10-2022, 06:13 AM | #76 |
Rep 101
02-10-2022, 08:40 AM | #77 |
Rep 8,700
Drives: eVeRyOnE mAD!
the infotainment screen (control display) is LCD. that being said, modern LCD isn't susceptible to burn-in, though i believe it isn't 100% free from image retention (likely negligible)
02-10-2022, 08:48 AM | #78 |
Rep 692
Personally I do like that the screens adapt to lighting conditions by dimming. I don't want it full brightness at all times of the day regardless of how sunny or cloudy it may be out there. On a cloudy stormy day the full brightness is a little too much in my opinion.
I do agree that if you have tinted window s and the sensor goes out of whack then that is a problem that needs to be addressed for those affected. I just think maybe finding a way to code it to be less sensitive would be better for those people, rather than full brightness at all conditions. Maybe tweaking the curve levels in the coding entries provided will get to a compromise level that is more suitable for tinted/affected vehicles?
02-10-2022, 09:03 AM | #79 |
Rep 8,700
i have seen how some folks' ICs get really dim in bright conditions. even with XPEL ceramic tint, my IC doesn't get that dim. it does dim in bright conditions but to a very acceptable level that doesn't require any external light source or coding, even when wearing polarized sunglasses (though I just changed to non-polarized to see the HUD better).
02-10-2022, 09:33 AM | #80 | |
Rep 2,072
This particular bit of coding: Instrument cluster - 3005 FuBi_Parameter – DIM_DTN – change value to 0x7F (from 0x3F) I reverted back to 0x3F. So far, it looks like that number byte controls the peak brightness of the instrument cluster. While the remaining coding makes it less susceptible to dimming in dark conditions. I haven't tested this extensively enough to confirm my findings, but in a few days I should be able to confirm. But I think that by leaving out this change, my IC's max brightness is the same, but its 'dimmed' brightness is brighter. When I changed that byte to 0x7F, the IC was really really bright, even in dim conditions. |
02-10-2022, 10:50 AM | #81 | ||
Rep 692
02-10-2022, 11:34 AM | #82 |
Rep 692
DIM_DTN is the Day to Night time threshold value. Whatever that means!
mobilejo1114.50 |
02-10-2022, 07:54 PM | #83 | |
Rep 130
22 BMW X7 M50i
mobilejo1114.50 |
02-10-2022, 08:09 PM | #84 | ||
Rep 692
Surely you can set it to any reasonable hex number within the "allowed" range, whatever that may be. I suspect 0-127 decimal. Which is a maximum of 7F in hex (127 decimal). For perspective, 3F happens to be 63 decimal. Which is about half of 7F (half of 127).
02-10-2022, 08:35 PM | #85 |
Rep 130
I coded it multiple times, simply changing the integer followed by F, with 7F being the maximum allowed value when I was coding.
22 BMW X7 M50i
gnolivos319.00 |
02-10-2022, 08:51 PM | #86 |
Rep 692
Right I'm just saying you likely could have used any hex up to 7F without necessarily ending in F. For example value HEX 1A would have worked.
TestnDoc91.00 |
02-11-2022, 12:14 AM | #87 |
Rep 842
We don't actually know if values above 7F are permitted. 80 through FF are theoretically possible but maybe values higher than 7F could cause issues or even damage.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
02-11-2022, 05:47 AM | #88 | ||
Rep 692
