07-29-2020, 03:55 AM | #1 |
164
Rep 598
Problem retrofitting crystal shift knob
Ordered genuine bmw crystal shift knob part#61319475056 and crystal start stop button part#61319475063 and tried to fit it on my G05 X5. Couldnt put the car into gear afterwards and the start stop button wont fit too, anyone experienced this situation too?
07-29-2020, 05:50 AM | #2 |
267
Rep 345
Drives: 2019 X5 40i M
The shifter should work but you will need to VO Code 4A2 to get the lights to work. The start/stop button will not fit your controller. Car Analysis Inc makes one that fits well. They have a cheap way to change your idrive controller as well
https://www.car-analysis.com/BMW-Cry...5-X6-X7-Z4.htm When my dealer installed my shifter they nicked the cable and ended up having to change the entire control unit.
2019 X5 X40iM
07-29-2020, 07:07 AM | #3 |
185
Rep 303
It sounds like the ribbon cable isn't lined up correctly. Double check that the cable is laying flat and that the cable stay is snapped in correctly. It's delicate and finicky.
I had the same issue with the start/stop. The design is different. I ordered from car analysis rather then trying to get the entire start/stop mechanism out and installed into my X5. Good luck!
Shawzy44
2024 BMW X1 28i 2023 BMW X3 M40i 2019 BMW 440iX M Performance Cabriolet |
07-29-2020, 09:26 AM | #6 |
267
Rep 345
He means the ribbon cable that you have to attach to the shifter coming out of the control unit. If that is not lined up perfectly then the shifter will not operate as intended.
2019 X5 X40iM
07-29-2020, 10:13 AM | #8 | |
185
Rep 303
Shawzy44
Mattnet0.00 |
07-29-2020, 11:03 AM | #10 |
ghey
484
Rep 2,041
Are you getting any alerts when you try to change gears? I didn't disconnect my battery and I killed the entire center controller.
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
04-06-2021, 07:29 AM | #12 |
185
Rep 303
Has anyone who's retrofitted and VA programed the crystal controls received an OTA update?
I am looking to prove it disprove my theory that VA coding and it retrofitting prevents OTA updates. I can't figure out why my X5 hasn't had a single update OTA.
Shawzy44
12-28-2021, 06:57 PM | #14 |
185
Rep 303
No answer and still not one update ota. But dealer has successfully updated.
Shawzy44
06-28-2022, 01:34 PM | #15 |
Rep 60
Does anyone know if you can replace the entire shifter module with an M version module? I understand the shifter itself is not compatible, but what about the whole thing?
11-30-2022, 08:30 PM | #16 | |
Rep 8
Jim |
02-09-2023, 07:40 AM | #17 | |
Rep 1
What was the end result to retrofitting the glass shifter knob
Did you have a successful end result with everything working? I ask because I just purchased an OEM glass shifter for my 2020 BMW X6 M50i online from an official BMW parts store and I had my local BMW dealer do the install. They also encountered a similar issue that was mentioned in this post where the car wouldn’t go into park. According to my service advisor the techs there never did that job before and that during the installation part of the shifter’s control panel had been fried/shorted and that they had to replace the control panel part that was fried and they did cover that. The end result was that they successfully installed the glass shifter knob I purchased but the only thing not working is the “X” symbol, it will not light up. They eventually told me that to get the “X” symbol to light up I needed to buy an additional 4 parts attached to the shifter panel, the parts came out to approximately $3,700 not including labor So for now I’m stuck driving it without the “X” light symbol feature not working until I can solidify what’s needed to make it work I honestly don’t feel totally convinced that I need all those other parts just to make the “X” symbol light up. So I’m curious to know if at the end you were successfully able to have your glass upgrade installed and if so did you need to buy additional parts to make it work? Last edited by Titoconga; 02-10-2023 at 11:17 AM.. |
05-23-2023, 09:40 PM | #18 |
Rep 870
I didn’t disconnect my front battery and am having the same issue now but all the buttons work on the center controller only thing that doesn’t is the park button malfunction is this the same you had? Did you replace the whole thing?
05-23-2023, 10:52 PM | #19 | |
Rep 1
06-08-2023, 03:11 PM | #20 |
Rep 12
Although I do not have personal experience with it, I’ve done extensive research on the offerings. It appears that the iDrive controller and the start/stop button will sit slightly taller. Make sure to disconnect both of the batteries if you decide on this mod as there have been many posts about fried center consoles.
06-20-2023, 04:22 PM | #21 |
Rep 1
Hi there. It happened the same to me today. How did you resolve the issue? Cheers, Jef.
