05-06-2021, 10:55 PM | #1 |
Rep 56
Digital key and driver profiles
I’ve been using the digital key through my apple watch. Super convenient so I don’t have to carry a physical key, specially when going out for outdoor activities.
Whenever I use the digital key though, the driver profile resets to Guest. I need to go into the menu to change it every time. BMW confirms everything to make the manual switch even more annoying. The digital key is associated with the driver profile but it doesn’t make the switch automatically, and it changes back to Guest when I lock the car. Anyone else seen this happen? Any suggestions? Last edited by jc.bmw; 05-07-2021 at 12:55 AM.. |
05-06-2021, 11:52 PM | #2 |
Rep 581
Sorry off topic question, how do you setup apple watch digital key? I only saw option to set it up on my phone.
Also, the phone digital key is not linked to the driver profile, I dont think there is a way to link driver profile to the phone’s digital key. I have to manually login as well. It is only linked to the BMW key card and the physical key |
05-07-2021, 12:09 AM | #3 |
Rep 15
To link the Driver Profile:
So here is what you do. Step 1: Go to the Driver profile Screen in iDrive. Step 2: Make sure you are logged into the profile you want to link. Step 3: Select Driver recognition from the sidebar on the right of the control display. This will open a menu with three options:
Step 4: Select with Digital Key. In this screen you will see a checkbox that says Link driver profile to key. You are only able to link one Smartphone/Apple Watch to the Digital Key driver recognition so if you choose to use your Apple Watch you will not be able to have your iPhone activate your driver profile when placed in the smartphone tray. The BMW Digital Key will still work though. So if you want to use your Apple Watch you will have to maneuver your wrist into the smartphone tray to link it. In the future BMW will support UWB and Bluetooth LE which will allow the vehicle and the device to communicate wirelessly instead of in close proximity using NFC. Hope this helps! As for setting up Apple Watch Digital Key. You need to go into the Watch App on your iPhone. Step 1: Click the My Watch tab in the bottom left of your iPhone Screen and scroll to Wallet & Apple Pay. Step 2: You should see a somewhere that says BMW X6M or X7 or whichever BMW you have. Step 3: You should also see a button that says ADD. From there you just have to follow the instructions on your phone. Last edited by unsubtleNinja; 05-07-2021 at 12:20 AM.. Reason: Clarification |
05-07-2021, 07:56 AM | #4 |
Bimmer without rage
189
Rep 87
Drives: 2022 X3 M40i | 2020 X5 M50i
First world problems… when will Apple car key come to the US?
Why can't US folks use Alexa?
05-07-2021, 08:08 AM | #5 |
Rep 426
West Austin38.00 |
05-07-2021, 08:47 AM | #6 | |
Rep 8,864
Drives: eVeRyOnE mAD!
Amazon Alexa in-car integration isn't supported in the U.S. yet. rumor is it's coming in July. currently, U.S. owners can use Alexa to operate the BMW Connected skill through an in-home Echo device. |
West Austin38.00 |
05-08-2021, 12:16 AM | #7 | |
Rep 581
05-08-2021, 06:54 AM | #8 | ||
BMW Junkie
176
Rep 306
Current Stable: 2021 BMW X7 xdrive40i, 2020 BMW X3 xdrive30i, 2017 Toyota Tacoma TRD-OR
Retired BMWs: 1999 BMW 328i, 2005 BMW M3 ZCP |
05-08-2021, 12:19 PM | #9 |
Rep 56
Are you saying that when you put your phone on the charging tray your X5 automatically switches driver profiles?
I did it when setting up the key. You have to. I also do it so I can turn on the vehicle. It’s just that I need to switch driver profiles every time manually. It reverts to Guest when I turn off and lock the car. re: “first world problems” Yes, please help me overcome this terrible ordeal |
05-08-2021, 12:43 PM | #10 |
Rep 581
of course, that is the only place to link digital key and it explicitly says that on the screen. For me, phone never worked, only the BMW key card worked attaching the profile. So I thought profiles can not be attached to phones/watches
05-08-2021, 12:46 PM | #11 | |
Rep 581
05-08-2021, 01:38 PM | #12 |
Rep 157
My digital key card worked when I picked up the car at the dealership. However, since I created and configured the digital key on my phone, the card no longer works. Is this the intended/expected behavior?
05-08-2021, 02:05 PM | #13 |
Rep 8,864
both my key card and Apple Wallet digital key work properly.
05-08-2021, 02:09 PM | #14 |
Rep 56
Same here. I’m able to use either. Normally use the Watch/Phone but keep the card key in my wallet as a backup.
What about driver profiles? Everyone needs to keep switching them as well when using digital keys? |
05-08-2021, 02:42 PM | #15 |
Rep 8,864
05-08-2021, 04:30 PM | #16 | |
BMW Junkie
176
Rep 306
05-08-2021, 05:18 PM | #17 |
Rep 581
05-08-2021, 05:35 PM | #18 | |
BMW Junkie
176
Rep 306
jonatious251.50 bloozemanAZ4326.50 |
05-09-2021, 12:33 AM | #19 | |
Rep 102
The following devices are compatible with BMW Digital Key: iPhone XR, iPhone XS, iPhone XS Max or later, and Apple Watch Series 5 or later. |
05-09-2021, 12:44 AM | #20 |
Rep 581
05-09-2021, 12:45 AM | #21 |
Rep 581
05-10-2021, 01:54 AM | #22 | |
Rep 56
There’s a sub-menu “active link” that only shows up for the card key and fob key, but doesn’t show for the digital key menu option, at least in the software version I’m using, which should be the latest in the US. |
