05-10-2021, 01:58 PM | #23 | |
Rep 133
05-10-2021, 02:01 PM | #24 | |
Rep 8,863
Drives: eVeRyOnE mAD!
it was officially stated in Feb '21 that US vehicles do not have in-car Alexa support yet. (are you referring to the BMW Connected skill in the Amazon Alexa app? if so, that's not the same thing.) Last edited by nZtiZia; 05-10-2021 at 02:18 PM.. |
05-10-2021, 02:15 PM | #25 |
Rep 133
I downloaded the app on my iPhone and then signed in using my connected drive app. It linked immediately to my vehicle. After that I selected the profile icon on the bottom of the MyBMW app and linked Amazon Alexa to my connected drive account.
There's a video on the app that shows you exactly how to do it. My vehicle is on iStep 03/2021.57 |
05-10-2021, 02:23 PM | #26 | |
Rep 8,863
i-Step 03/2021 is not readily available as an OTA or otherwise. it's mentioned in the following thread how users can download this version and flash/program it using ISTA, which is a skill not all of us have. you posted once in this thread asking if coding is one way to get it, so you sound like someone who knows his way around software, but at this moment for us non-software engineer-types with i-Step 11/2020 in the US, we do not have in-car Alexa support yet. New i-step: 03/2021.525 https://g05.bimmerpost.com/forums/sh....php?t=1804640 if you are in the US and this is the way you did it, please don't mislead because you make it sound all simple but initially left out that critical detail about how you had to download, flash, code, and program 03/2021. if it were as simple as you make it sound, many of us would have already done it, but AFAIK, you're the only US vehicle owner on this forum with this feature...and on an older G05, making your "easy" procurement all the more suspicious. my wife's G30 is 2020 and my G05 is 2021, both US models. Below is a screenshot from the MyBMW app showing how both our vehicles (that are newer than yours) aren't supported. Even though I'm connected, in-car Alexa doesn't work because we're on i-Step 11/2020 in the US. please feel free to clarify any details. i don't claim to be an expert on ISTA programming. Last edited by nZtiZia; 05-10-2021 at 06:14 PM.. |
05-10-2021, 07:12 PM | #27 | |
Rep 133
I didn't flash/load my vehicle to the latest i-step. my X5's DKombi died on me and I took it in as part of the warranty. They replaced it, and found that there were more problems than they thought (Kafas camera was inop, and the windshield was replaced because the warming elements for the Kafas camera were shorted out). I in no way was being cryptic. But because I was upgraded to the new i-step, alexa was made available on the BMW Connected app. |
05-10-2021, 07:54 PM | #28 | |
Rep 8,863
I was just in for service a few weeks ago with 11/2020.38 and the dealership only updated me to 11/2020.64, nowhere near 03/2021 from them. Just understand that getting version 03/2021 isn't something that'll come easy peasy to most of us, and that your initial comment can kinda mislead others to thinking that getting in-car Alexa support is as simple as following a YT video. there's more to it than that for the U.S. market. |
05-11-2021, 09:16 AM | #29 | |
Rep 133
This was done in late march, and they kept my vehicle for almost 6 weeks cause they couldn't fix the driver assistance error. BMW Engineers from Germany were in finding the problem. At the end, it turned out to be the Short and Long Range Sensors were not programmed correctly when the update was done. To me, getting Alexa set up was really simple, followed the guide on the MyConnected app, linked my account to Alexa, configured the idrive system, and it worked. I guess I was lucky. Armando Last edited by mandomedic122; 05-11-2021 at 09:20 AM.. Reason: Answering the complete post |
04-16-2022, 11:17 AM | #30 | |
25
Rep 30
04-16-2022, 12:31 PM | #31 | |
Rep 8,863
if those don't work, try removing and reconnecting your iPhone. after that, try removing and re-adding the Digital Key. i used the Digital Key a couple weeks ago while on vacation. went for a morning Starbucks run and realized i forgot my key fob as i walked out of the resort to my car but remembered the Digital Key. it worked as intended, and my driver profile was loaded, not Guest. Last edited by nZtiZia; 04-16-2022 at 12:42 PM.. |
04-16-2022, 08:57 PM | #32 | |
25
Rep 30
Thanks for the hint. I will try that and let you know. |
04-16-2022, 11:02 PM | #33 |
25
Rep 30
04-21-2022, 12:27 PM | #34 | |
25
Rep 30
Finally, a solution. So BMW did a new firmware update. And now, I can use the digital key that store my driver profile. However, I can only use one non-key solution. Either i go with the digital key on the phone to the key card. I can still use both to open and look at the car, but only one will have my driver's profile. |
09-26-2023, 02:00 PM | #35 |
Rep 80
I have a 2024 x5 50e - the digital key on my iphone works with my profile but does not with the watch. I added the watch as an option when I added the iphone. Tried removing and adding it a couple times but same problem - watch ends up as guest profile. I then have to punch a pin in to swap to my driver profile. It doesn’t make sense since the watch is paired to the phone and was added as part of the iPhone digital key.
11-06-2023, 04:30 PM | #36 |
Rep 28
I've been having trouble using the key card with my new 2024 50e. I activated it but it would only work to lock/unlock and drive the car. It didn't load my profile and only showed Guest. When I look at the BMW ID settings it shows no card active so it doesn't show an option to link the ID/card. I had my appointment this morning with a factory rep to provide feedback so had him look at it during our video call. He couldn't figure it out either and suggested talking to the service dept. I found this thread and went to the car to double check settings that was suggested here. What's weird is that the settings still show no card activated. But when I started the car it now prompts me to either use Guest or my personal profile. I logged in with my 4 digit code and all of my settings seemed to be ok. Not sure why it shows no card active though.
12-05-2023, 07:16 PM | #37 | |
Rep 2
12-05-2023, 07:25 PM | #38 |
Rep 105
I can setup my iPhone or Watch to work but don't see a way to have them both work on the same profile. I decided go with the iPhone since its a pain putting the watch on the pad to start the car.
12-06-2023, 09:02 AM | #39 |
Rep 80
I don’t need to put my watch on the pad - I just need either to be with me (watch on wrist) for everything to work - including starting the car. The update to 8.5 is supposed to now allow two keys be associated with one profile but I’m not sure if that includes digital keys.
12-06-2023, 12:08 PM | #40 | |
Rep 8,863
pre-LCI have iDrive 7 while LCI have either 8 or 8.5, so digital profiles per key are different |
Skijackz8.50 |
12-13-2023, 01:32 PM | #42 |
Rep 80
Hi - My 2024 50e was just updated from 8 to 8.5 and now both my apple watch and phone sync to the same profile! I didnt change any settings. Before, both worked fully but only the phone would associate to my profile whereas the watch would associate to the guest profile.
nZtiZia4752.50 |
