12-26-2018, 09:23 PM | #23 | ||
25
Rep 36
[1] You only need to use the top cross bar in x5 https://www.amazon.com/dp/B0002MABGE I had the following[2] one in my Lexus GX 470 and hated it. [2] https://www.amazon.com/dp/B000I1PJNO |
TLg0513.00 |
01-07-2019, 01:56 AM | #24 | |
Rep 494
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold) 2012 BMW X3 28i (sold) |
01-10-2019, 10:49 PM | #25 |
Rep 3,411
Prewiring front and rear for dashcam would be something I'd pay for as an option.
Dashcams are getting so popular it seems like BMW would want to make some money offering this a prewire option. |
01-10-2019, 11:31 PM | #26 | ||
25
Rep 36
02-14-2019, 12:05 PM | #27 |
Rep 504
I would be interested in hearing any updates on this, especially where to tap power from in the fuse box. I know some vehicles are very sensitive to additional load changes for some circuits. All I'm looking for is 12VDC switched on and off with the ignition. I don't need power for the dashcam when the vehicle is off.
Although it's easy to check, I have not yet done so... is the cigarette lighter always on or does it switch off with the ignition? If switched, this may be an easier tap than running a feed wire from the rear of the vehicle. |
02-14-2019, 12:45 PM | #28 | |
Rep 494
https://g05.bimmerpost.com/forums/sh...light=blackvue I think F27 would be the one to use. I'll be installing next week, will report back
02-14-2019, 01:03 PM | #29 | |
91
Rep 306
02-14-2019, 03:21 PM | #30 | |
Registered user
78
Rep 422
Drives: G05 3.0d MSport / F23
2019 G05 3.0d MSport in Artic Grey/ Black 2015 F15 3.0d MSport/ 2014 F15 3.0d MSport, Carbon Black with Ivory White/ Black interior. 2015 f23 2 series convertible in Glacier Silver / Black. 2010 F07 5GT SE Sapphire Black with Ivory White/black interior
02-14-2019, 06:24 PM | #31 | ||
25
Rep 36
bichoo280.50 |
02-23-2019, 12:00 AM | #32 | |
Rep 1,133
It's good to be bad
incubatewhisky24.50 |
02-23-2019, 12:27 AM | #33 |
Rep 445
BMW is likely introducing a built-in recording system - look up 6DR option in the G12 7-Series LCI guides: "6DR - Driver recorder" - price $200, 7/19 SOP
04-13-2019, 09:23 AM | #34 | |
Rep 272
Is Power Magic EZ supported?
I have DR900S and planning to by PMEZ for parking mode but not sure if that will be supported |
04-13-2019, 09:25 AM | #35 | ||
91
Rep 306
04-13-2019, 09:55 AM | #37 |
91
Rep 306
I mark the fuse that you need to use clearly
08-04-2019, 10:17 PM | #38 |
Rep 1
Generic AuKey Dash Cam with Basic USB with Mirror Mount Hardwire Power
Gents,
I have three of these basic Dash Cams and I just installed one in my wife's G05 X5 today. It took some learning to figure out the hardware strategy but I am satisfied: It's a $70 no-frills unit on Amazon: AUKEY Dash Cam, Dashboard Camera Recorder with Full HD 1080P, 6-Lane 170° Wide Angle Lens, Supercapacitor, G-Sensor and Clear Nighttime Recording. I then purchased the $14 USB Kit which I did a bit of soldering to make a homemade tap: SHISHUO Dash Cam Hardwire Kit - Mini USB and Micro USB Port 3.5m Cable with LP Mini/Mini/ATO/Micro2 Fuse, 12V to 24V Input, 5V Output for Dash Cam GPS Sat-Nav with Battery Drain Protection I tapped in into the Mirror power. The power is indeed switched. It takes about 10 minutes for the power go out when you turn off the car -- but that is just fine with me. I blew the rated 5 amp mirror Fuse #F59. So I added a replacement fuse at 7.5 amps and it seems to be holding fine. Here is the result of the work. Pretty clean and simple. I am attaching the BMW G05 Fuse Schematic that I obtained from the BMW website. |
11-10-2019, 10:50 AM | #39 |
Rep 66
Just installed mine today. I was debating between hardwire vs. using the rear cigarette outlet and went with the cigarette outlet. Took about 20 mins and you can’t see any wires hanging so I’m satisfied. Only issue I had is getting the wire to conceal in the front headliner especially at the corner. I snugged it into the gap between the headliner and the passenger side airbag; I assume that’s how others have done it?
