11-13-2019, 10:15 PM | #1 |
2020 Mineral White 30d MSport
523
Rep 2,146
Drives: 2020 Mineral White 30d MSport
Include Adaptive drive on Profile
I have been trying to add Adaptive drive into my personal profile without any luck, don't know if it's possible, the idea is to start the car in adaptive mode and not in comfort
11-13-2019, 11:23 PM | #2 | |
Rep 2,609
ECU: BDC_BODY3/00007083 FDL: FesPiaDefaultLastUserMode to value 02 for Sport Pro/Plus mode Complete set of FesPiaDefaultLastUserMode codes are listed here. The mode needs to be enabled on the car for these to work: 01 - Sport 02 - Sport Pro/Plus 03 - Sport Individual 04 - Comfort 05 - Comfort Plus 06 - Comfort Individual 07 - Eco 08 - Eco Plus 09 - Eco Individual 0A - Adaptive
x5TXguyG0511.50 |
11-14-2019, 07:59 AM | #3 | |
1053
Rep 1,952
11-14-2019, 08:24 AM | #4 | ||
523
Rep 2,146
Is it possible to code it in expert mode with BimmerCode?
11-14-2019, 08:29 AM | #5 | |||
Rep 2,609
11-14-2019, 08:33 AM | #6 | ||||
523
Rep 2,146
11-14-2019, 08:46 AM | #7 | ||
134
Rep 326
I did the same, started diving into coding with my new G05 about 6 months ago. I recommend leading it by requesting a token for esys from tokenmaster because that may take a little while, or starting a savings budget for esysx. Google for "coding no request" and that will get you a good start on a different forum with loads of information. Start reading the pdf handouts and after a couple of times reading and watching some YouTube videos you'll still be confused. After you get esys running and your car connected, and you play with it it'll start making sense very quickly. |
11-14-2019, 08:50 AM | #8 | |
1053
Rep 1,952
11-14-2019, 08:58 AM | #9 | ||
Rep 2,609
I have both Launcher Pro and ESysX setups. Both work fine with latest psdzdata for what I've done so far. ESysX is easier/less stressful to acquire. Launcher Pro Cheat Code file management is a bit more functional and easier to use than ESysX — that's a pretty minor thing and ESysX may improve as the developer seems to have understood my request to improve a bit. So both are extremely similar in daily use. ... too add to what was stated earlier.
homerrr133.50 |
