09-02-2019, 09:00 PM | #133 |
Rep 7,037
“Why did they remove and inspect all the luggage compartment stuff?”
With most if not all new BMWs including the X5 having at least one battery in the trunk it is a must to inspect this area on a vehicle with electrical issues. It is a rather frequent type of post here that someone has spilled fluids in the trunk and ended up with a dead car... |
09-02-2019, 09:21 PM | #134 | |
Rep 6,121
09-03-2019, 08:41 AM | #135 | |
Rep 4,333
09-03-2019, 09:11 AM | #136 | |
Rep 6,121
Here's the location: https://www.newtis.info/tisv2/a/en/g...les/1Vnd1tdOS9
09-03-2019, 09:27 AM | #137 | |
Rep 4,333
AndroidRobot4331.50 |
09-03-2019, 10:02 AM | #138 |
Rep 6,121
Since my car was dirty it was very easy to tell the external sharkfin was not touched. IE it was still covered in dirty consistent with the rest of the roof and uninterrupted. I believe they just replaced the internal sharkfin, you can verify by checking that P/N on my service ticket.
09-03-2019, 10:41 AM | #139 | |
Rep 4,333
Yeah, the two color pix are not on a G05 but the RealOEM pic is. They are basically the same design. . |
09-03-2019, 11:20 AM | #140 | |
Rep 6,121
09-03-2019, 12:32 PM | #141 | |
Rep 4,333
Just trying to give you some peace of mind that they found root cause and you'll now be ok . |
09-03-2019, 12:57 PM | #142 | ||
Rep 6,121
09-03-2019, 01:10 PM | #143 |
Rep 506
Telematic Communication Box
The various boxes in the car are all linked together in some way. Some kind of voltage fault can, via that network, affect another box. It might be the voltage itself that propagates or a ground that floats and causes the digital electronics to go haywire and that in turn forces a box into a physical failure... So it is possible that a failure in the antenna electronics could cause other parts of the car to have physical failure too. Just some thoughts as to why other parts of your car failed. In the end, though a lot of electronics these days aren't diagnosed to find what caused a failure. Mostly what is done is to swap out components 'till things start to work. |
09-03-2019, 04:27 PM | #144 | |
Rep 6,121
09-03-2019, 06:55 PM | #145 | |
Rep 4,333
In your case, they saw water, they know you'll be back if they don't get to the root cause of the water leak. You had the following thing impacted in the picture because of the water that caused your boxes to fry. The TCB controls a lot of stuff in your car and I remember you complaining about all those things not working. Like Dan321 said, if you have boxes connected together via wiring and one box fries, its entirely probable that it will take out other boxes connected to it and fuses. So I guess what I'm saying is that ever since you took possession of your car, you may have had only real issue that has caused a myriad of symptoms. That issue is water leaking into the car in places that you cannot see. If this were my car, I would remove the passenger footwell panel, like the dealer did and leave it off and put some paper towels up above the BDC box and I would continually check it for wetness until I was satisfied that that particular leak is gone. I don't expect you to ride around with out a headliner and those are a PITA to remove but.. .. .. well, you still have a warranty even if it is a pain to take it in. I'll be interested in seeing how this service episode plays out. I certainly wish you the best of luck! Edit: for the water entry into the shark fin antenna, I would get up on a ladder and put a bead of clear silicone around the perimeter of the shark fin cover. Using your finger, press it in along the entire gasket area, wipe off any excess. You won't see it if done properly. Alternately, you can remove the shark fin cover, remove the gasket, apply a new gasket and remount the cover. I guess what I'm saying is that if you are in doubt that they removed that cover in order to fix the leak, I would do so myself. . Last edited by Marty in NY; 09-03-2019 at 09:40 PM.. |
09-04-2019, 10:22 AM | #146 | |
Rep 6,121
I might check on that BDC module and see if water is getting in there. As I've said a few times I'm certain there's a deeper issue here causing things, whether that's improper sealing of components or leaky drainage as you mentioned. I'll let you know if I find anything.
09-04-2019, 11:03 AM | #147 |
Rep 1,075
Whats more concerning is that the service department left themselves an out stating that you asked them not to water test the repair
Im sure they used windshield glue to reattach outside shark fin. But i would want them to keep leak testing until its 100 percent dry |
09-04-2019, 11:04 AM | #148 | |
Rep 4,333
I think you should sell it, go into the witness protection program and then buy a new one |
AndroidRobot4331.50 perikifi165.50 |
09-04-2019, 11:33 AM | #149 | |
Rep 6,121
09-04-2019, 11:37 AM | #150 | |
Rep 6,121
09-04-2019, 11:42 AM | #151 | |
Rep 4,333
Here's the strange thing though...if you read through what the service dept wrote on the invoice.. .. 1. Performed a water test 2. Found a water leak into the car via the shark fin cover 3. Replaced the GPS antenna which is under the shark fin cover 4. Re-glued the shark fin cover (did they replace the gasket???) 5. Did not perform a second water test because of what AR said. Now you tell me how this makes any sense, the first thing they did was a water test, then they said they couldn't do a water test. What the hell's going on? Is this their way of trying to hide behind AR's instructions so they can deny warranty if this happens again???If the dealer gives AR any crap upon a potential future visit for the same issue, I would politely show them their invoice and point to the section that said they in fact did do a water test. Thing is, for AR's peace of mind, what was really done or does he now simply have to find out for himself as he drives the car . |
09-04-2019, 11:45 AM | #152 | |
Rep 6,121
09-04-2019, 12:16 PM | #153 | |
1053
Rep 1,952
09-04-2019, 03:03 PM | #154 |
Rep 6,121
I don't but the hard water spots on my roof say otherwise.... ceramic coating probably took the brunt of the damage. I got most of the spots out.
