02-09-2024, 02:19 PM | #2 |
Rep 50
I tried to get mine off too because it’s making noises. I think the noise are coming from the plastic trim piece where the cargo cover clicks in. There’s an airbag in the pillar/seat so I stopped messing with it. Maybe something for the dealer. You’re going to want to disconnect the battery before ya go tearing it down. Good luck.
vitipr171.00 |
02-10-2024, 01:39 PM | #3 | |
Rep 3,937
You would first need to disconnect the batteries. Then the backrest side section between the rear seat back and door needs to be removed. Then the bottom side C pillar trim comes off. Remove illuminated sill trim. Then remove upper C pillar trim. |
vitipr171.00 |
