08-22-2023, 09:09 PM | #1 |
Rep 3
315/30/R22 tire on front wheel
I just purchased a used 2021 X5 M50i which has 22" wheels on it and I didn't notice until later that the tire on the front passenger side is a 315/30/22. I'm trying to find a replacement 275/35/22 Continental Premium Contact 6, but I guess there's a tire shortage because I can't find it in stock anywhere. Is there much harm/danger in continuing to drive with this tire on the front wheel? I'm not sure how long it's going to take to find a replacement.
Thanks! Last edited by Rancid Richard; 11-18-2023 at 09:12 PM.. |
08-26-2023, 04:03 AM | #2 |
Rep 294
Serious issue. I'm shocked the car drives in a straight line with mismatched front tire sizes. You will surely want to get an alignment after you correct the tire issue. You should replace both fronts to avoid further uneven wear.
'13 Raptor (sold); '14 Raptor (sold); '15 A6 Quattro (sold); '19 X5 xDrive 40i (sold); '20 4Runner TRD Pro (sold), '22 MDX A-Spec (sold); '22 MDX A-Spec (sold); '24 X5 M60i
08-26-2023, 03:34 PM | #3 | |
Rep 1,449
No. Try not. Do. Or do not. There is no try.
-Yoda |
10-24-2023, 07:01 PM | #7 |
Rep 18
Drives: 2024 BMW X5 xDrive 50e M Sport
I’d like to see some pictures. Having 315 in the front sounds insane haha. Also very odd that only front passenger rim has that tire size.
10-24-2023, 07:26 PM | #8 |
Rep 3,681
Maybe someone did a rotation and put the rears up front?
Yes, 315 will not fit on 9.5” wheel.
2022 G05 B58/PHEV
+ a few very old BMWs |
10-25-2023, 02:51 AM | #10 |
Rep 3,681
Oem 21 rear wheel is only 10.5”, 1” wider than front
2022 G05 B58/PHEV
10-25-2023, 11:37 PM | #11 |
Rep 9
10-26-2023, 12:13 AM | #12 |
Rep 3,681
IMO, not supposed to, but this is what BMW does for G05. I agree with you that 11.5J is a more appropriate width for 315mm tire. BMW put 275/45R20 on 9Jx20" on all 4 corner for M Sport wheel tire setup, not even 9.5J. It is clearly this set up is for comfort, allow tire size wall to flex to maximum, and outside of industry norm
2022 G05 B58/PHEV
11-18-2023, 09:06 PM | #14 |
Rep 3
Wheel update
I couldn't find the Continentals in stock anywhere so purchased 4 new Pirelli all-seasons. When the tire installer was switching them out, he confirmed the front passenger wheel was the correct 9.5" size that they managed to squeeze the 315 on. He also showed me that the front and rear passenger wheels were bent as they moved up and down slightly when balancing. The new tires hold air and I'm driving on it like that until I decide to buy some new wheels.
I bought the car from an individual so no dealership guarantees or anything. They did give me $400 for a new tire, but the bent wheels are my issue to deal with. Here are some pics. Also included a pic of the driver's side correct tire just for comparison. I didn't notice any rubbing and I felt like it drove fine except when making a tight turn the steering wheel wouldn't want to return to center as I exited the turn. |
11-18-2023, 09:42 PM | #15 |
Rep 3,681
Interesting. The 315 on 9.5” doesn’t even look too abnormal without a side by side comparison to 275.
So what is the plan? Will you swap out the from 315 back tk 275? Or will you swap the 275 to 315 for square setup?
2022 G05 B58/PHEV
11-19-2023, 08:16 PM | #17 |
Rep 3,681
Why? I can see too narrow of tire, bead will come off wheel rim. If wider tire fits, what is the issue?
2022 G05 B58/PHEV
11-19-2023, 08:41 PM | #18 | |
254
Rep 320
*But I have to agree with you that yes, you can drive with 315s in front. As long as you are not pushing car to the limits (or close to limits). |
11-19-2023, 08:49 PM | #19 | |
Rep 3,681
This is where I always against putting spacer on, especially the front. There is so much unintended effect on suspension geometry that seller never discussed
2022 G05 B58/PHEV
roamio253.50 |
11-19-2023, 10:55 PM | #20 | |
Rep 3
I already bought 4 new Pirelli All-Season tires at the correct factory sizes for my 22" wheels and have put them on. I have these Continental tires sitting on the garage floor until I can see if someone wants to buy them. Now I just have two slightly bent wheels on the passenger side that I know I need to replace. Car drives fine and wheels hold air, but I'm sure that extra movement isn't good for the suspension. |
