11-29-2023, 08:24 PM | #1 |
Rep 6
staggered and settings in idrive
Hello, I have a 2019 ×5 with the Staggered set up. I just put winters on for the first time there’s a setting in iDrive to set the tire size but neither the front nor backs are available in the list. How do I overcome that? And also there’s not a setting for the front and back separately. So do I enter the size of the fronts or for the backs?
Thank you for your help! |
11-30-2023, 11:21 AM | #2 |
Rep 8,826
Drives: eVeRyOnE mAD!
what size? it sounds like non-OEM which you won’t find in the menu. it only offers OEM rear sizes and will display the recommended pressures for the fronts based on that
11-30-2023, 05:32 PM | #3 | |
254
Rep 320
User guide list multiple options. No matter what, go by rear tires (not front ones). Last edited by roamio; 11-30-2023 at 05:41 PM.. |
12-01-2023, 06:49 AM | #4 |
Rep 6
2019 x5 40.
I have 275/40 r20 in the rear. 245/45 r20 in front. I enter other into the system, and it never initializes past 49% … |
12-01-2023, 07:48 AM | #5 | |
Rep 8,826
the closest size you can select in TPMS is 275/45R20. luckily your front and rear tires both have the same circumference so you won’t face transfer case issues, but your speedometer will read 1-3mph faster than actual speed. also, you may face warranty claim issues if you develop any problems related to the iDrive system or tires because they’re not OEM. |
12-01-2023, 08:03 AM | #6 |
Rep 6
Figured it out. Bad sensor. Guess batteries don’t last forever
Wheels came with the car. Private sale. It is what it is. |
