      01-05-2019, 06:55 PM   #1
heinzena
Drives: 340xi M-Sport
iDrive and Lights stay on?!?
So this has happened several times - I come hom, turn the car off, and will go back to the garage some time later, 10 mins to 1+ hours, and the running lights, tail lights and iDrive are all still on! WTF? This has happened about a half dozen times in two weeks. What am I missing? This really irritates me.
      01-05-2019, 08:03 PM   #2
drpeters
Drives: 2022 M8
same here.
      01-05-2019, 08:10 PM   #3
X5_CC
X5_CC's Avatar
289
Drives: X5 40i
Do you open the driver's door before or after you turn off the car?
      01-05-2019, 08:13 PM   #4
MystroX5
MystroX5's Avatar
6290
Drives: 2020 X7 M50i/ 911
Do you have the key on you when you go out to check?
      01-05-2019, 08:15 PM   #5
jcc285
Drives: BMW M4
In comfort access- did you turn on ‘lock vehicle as you walk away with key’. I have it turned on and a couple of times it didn’t lock, lights were on as well as Idrive. I believe it has to be with the poor key recognition system of the car. Some people and myself have had situations were the key fob is not recognized especially if you have your cellphone in the vicinity. If you lock your vehicle manually, Then I have no idea, what’s gong on.
      01-06-2019, 01:38 PM   #6
heinzena
After. I have found this issue occurs only when I have a passenger.
      01-06-2019, 01:41 PM   #7
heinzena
No. Key is hanging by the door, which is about 20 feet from the car. This just happened again today and I specifically turned iDrive off before I got out. Checked it 2 HOURS later and everything still on - running lights, tail lights and iDrice. I’m really pissed by this.
I love the car, but it is a buggy mess, as has been discussed in other posts. The software is not complete nor is it commercial ready. Shocked (but not really) BMW would allow this.
      01-06-2019, 01:56 PM   #8
spike5150
Drives: 2020 X5 M50i
On F15 you have to push the start button a second time to turn off everything else unless you lock the car.
      01-06-2019, 02:25 PM   #9
heinzena
Ya that’s how it was with my last 4 BMWs. Doesn’t appear to be the case with G05
      01-06-2019, 03:57 PM   #10
EJELITE
57
Drives: 2014 S5 cab | 2019 X5
Seems to me if any door is opened before I turn the engine off, the idrive and power stay on unless I hit the engine button a 2nd time. If I shut off the engine before anyone opens a door, everything turns off once a door is opened. Worked the same way in my sisters old 2015 X3.
