04-29-2024, 08:21 AM | #1 |
BMW Enthusiast
87
Rep 127
Air Suspension worth it for X5?
Hi all,
I am wondering if ordering air suspension on the 25' X5 xDrive40i would be worth it? Air suspensions have always scared me a little, but open to hearing your thoughts! Will most likely go without due to cost savings and the extra piece of mind Thanks
2011 BMW 328i xDrive Sports Wagon - Deep Sea Blue Metallic over Oyster Dakota Leather
04-29-2024, 09:15 AM | #2 |
Rep 879
I prefer the 2-axle air suspension on my X5 because I do longer trips and the ride quality is great. Some people prefer a sportier ride but I'm not hot rodding this thing around.
M3 - X5 - 911 - Miata - Raptor - Edge
CGG176.00 thereef5101169.00 |
04-29-2024, 09:25 AM | #3 |
Rep 172
I haven't tried the standard suspension, but I had the air suspension on my 45e for 2 years, and now I have the M Adaptive Pro on my M60i, and I couldn't be happier with the change. It's a more sporty driving experience, firm but not uncomfortable at all. In fact, the air suspension could be uncomfortable on roundabouts due to body roll.
mustangigem58.00 |
04-29-2024, 09:27 AM | #4 |
Rep 930
If I was a big traveler or highway driver it would definitely be a nice option. We didn't get it on ours due to we like a sportier ride and to be honest it rides really nice anyways on 22s and adaptive. Even in sport it rides really nice to us. We had an X7 loaner recently with air and on the highway that thing was butter.
If you can find both on a lot to try out that would be your best bet. Also consider how long you may keep the vehicle as many say long term the air suspensions can be problematic..
Make today your best day!
04-29-2024, 09:39 AM | #5 |
BMW Enthusiast
87
Rep 127
Ok, I think I'll pass.. not carving up canyon roads but would rather a sporty ride than feeling like its a motorhome suspension - not a big highway driver either. Thanks for all your help!
04-29-2024, 09:48 AM | #6 |
13685
Rep 20,345
It all depends on what type of ride you are looking for. If you want the most comfortable with some sportiness when desired then get the air suspension.
There should be zero concerns about costs in the future. Anything can break at anytime but odds are against it, just enjoy their vehicle.
04-29-2024, 09:52 AM | #7 |
13685
Rep 20,345
You probably should try and test drive one as suspension fee; is a personal perception/preference. Anything someone says about suspension fee; should be taken with a grain of salt. On e person's sportiness is another's harshness just like one's floaty is another's comfortable.
04-29-2024, 09:53 AM | #8 |
Rep 11
I've had both in both V8 and 6 cyl variants. I currently have M-Adaptive in my M60i and I enjoy it a lot more than I thought I would. Most of my commute to work is highway so I swore by air suspension. Yes, air is smoother on the highway, but the M-Adaptive isn't exactly choppy. With that being said, I do prefer air suspension because I it does stiffen up nicely in sport mode along with reducing the ride height. You can also lower the vehicle when parked which makes it look awesome. I completely understand how stupid that sounds, but it looks really good with spacers and lowered when parked haha
vinibabs35.50 |
04-29-2024, 11:50 AM | #9 | |
Rep 866
I live in an area where the roads suck and absolutely love the air suspension. I had an F90 M5 Comp before this and I hated driving it around because of the roads. And, the air suspension can get firm at the push of a button. I do almost zero highway driving and would choose the air suspension again considering the area I live in. |
04-29-2024, 12:24 PM | #10 |
Rep 6,942
Just because the vehicle is sprung with air does not automatically mean that it is floaty. That is primarily a function of how the shocks are tuned, not the springs. To keep from bottoming out on a bump, the final spring rate between a steel spring and an air spring needs to be about the same at full compression or it couldn’t hold the vehicle up…it’s just that a steel spring is likely a tit stiffer on initial, small impacts than an air suspension which is about as progressive as you can make a spring. A steel spring can only be wound to approximate a progressive spring rate.
Where you live, and the quality of the roads could sway you one way or the other…air springs will absorb smaller bumps better than a steel spring. Keep in mind that the tires are also part of the vehicle’s overall spring rate, so shorter sidewalls on larger wheels will tend to transmit more of the impact to the chassis than a smaller wheel. |
Mattl08061005.50 |
04-29-2024, 01:14 PM | #11 | |
Rep 1,152
Air springs all leak eventually. Probably not within a 3 year lease or a 4 year ownership, but at year 6 or 8 or 10 or whatever they'll eventually leak and need replaced, steel springs don't leak and fail. |
Bambazonke213.00 |
04-29-2024, 01:27 PM | #12 | |
13685
Rep 20,345
04-29-2024, 01:48 PM | #14 |
13685
Rep 20,345
That is not the away the air suspension works as it is progressive. The spring rate actually increases as the ride is lowered. That is one of the reasons why Sport mode lowers the vehicle.
04-29-2024, 02:20 PM | #15 | |
Rep 1,152
You cannot make a volume of air stiffer when it's at a lower pressure. That's not how air pressure works. |
04-29-2024, 03:07 PM | #16 | |
13685
Rep 20,345
04-29-2024, 03:23 PM | #17 | |
Rep 1,152
There may be a clever way to make it work. An embedded steel spring that sets a minimum spring rate for example. Maybe multiple chambers that can hold different pressure levels. But a standard air bag spring has a higher spring rate the more air you put in it as the vehicle raises. |
04-29-2024, 03:34 PM | #18 | |
13685
Rep 20,345
04-29-2024, 03:59 PM | #19 |
Rep 68
Drives: '22 X5 M50i, Lexus RC350F Spor
I have the MSport standard springs on my M50i.
Combined with the 22's, potholes feel terrible in the car. Air suspension is worth it IMO. (Chicago is where I drive) I feel like I get bounced around over expansion gaps, etc. |
04-29-2024, 04:13 PM | #20 | |
Rep 425
From data I've been able to glean of the X5's air suspension, I've calculated the 20 mm reduced ride height in sport will result in an increased spring rate on the order 15% to 20%. Your statement; "But a standard air bag spring has a higher spring rate the more air you put in it as the vehicle raises." implies there is a change in spring rate due to the volume of air in the spring, but this is incorrect. It is not the volume of air in the spring, but the relative change in volume for a given spring deflection; i.e. the higher the ratio of 'volume change due to deflection' divided by 'the original volume', the greater the pressure rise due to that deflection. Also, and I don't know that this is what you were implying, but there is a fairly common misconception that the higher ride height is due to an increase in pressure in the spring. In reality, the pressure is unchanged, being what is needed to offset the weight of the vehicle, which does not change with ride height. The ride height changes because of a change in air volume. |
tooloud10790.50 |
04-29-2024, 04:19 PM | #21 |
Rep 6,942
As the vehicle rides lower, the total volume available to compress gets smaller, so as it continues to get compressed, the pressure rises more with a smaller increment of height change.
The biggest advantage to air suspension is their progressive spring rate curve that can only be approximated with a steel spring and the softer initial impact. FWIW, steel springs can fail as well, and the higher the load and the bumpier the roads, fatigue which causes their spring rate to change. At least with an air spring…it stays the same until it dies, not continually, slowly degrading over distance traveled with a steel spring. Which you prefer, fine by me, and not all brands and models function the same. There are some characteristics that will be similar depending on the implementation, but lots of opportunities to tweak it. |
04-29-2024, 04:20 PM | #22 |
Rep 279
Not sure if you’re aware, but you will only be able to select the standard design in the 40i and not M Sport if you opt for the air suspension. Just something to weigh aesthetics vs features.
LuckyBrand1448.50 |
