01-27-2023, 09:29 PM | #1 |
Rep 7
Racechip Question
Hey all,
Have a 2020 M50 and was thinking about adding the racechip. My concern is that I assume the engine, drivetrain, transmission etc we’re built, w/ a level of margin, for the power numbers the engine came with. I know the M diff and some other components are designed to take a beating but are there some “weakest links” that could give out with a considerable boost in power? I know there’s always wear and tear regardless and realistically this will increase that, just curious if it’s minimal or if there are certain components that will give out materially faster with the increased power. Thx! |
03-09-2023, 09:00 AM | #2 |
Rep 1,354
Drives: 2022 X5 m50i
I believe the power increase by the piggyback is within the safety margins. There are people running the same engine and transmission at 650+ horsepower. A reputable piggyback tune shouldn't cause trouble to the engine and transmission unless there are defective internal parts on that particular vehicle from the factory.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
03-09-2023, 02:20 PM | #3 |
Unapologetic Tool Hoarder
734
Rep 964
Most piggybacks use an "additive" map which just takes the factory signal and adds 3-4 psi of boost depending on which map setting is selected. As long as you select the correct map for the octane and mods you have, should be fine. Crap gas on a stock engine can just as easily kill it.
07-13-2023, 03:11 PM | #5 | |
Rep 60
I have a Racechip GTS Black that I have for sell that I took off my old 2020 X5M50i. I went the bootmod route and don’t need it anymore. |
07-21-2023, 04:20 PM | #6 |
1228
Rep 1,350
Burger is showing a little over 100HP gain and even more torque with their JB4 on Map 2 and 93 octane fuel for the M60i. Good bump and quite a bit more than what was seen with the M50i.
Keep in mind that this is power at the wheels not crankshaft. Last edited by cobramite; 07-22-2023 at 06:14 PM.. |
07-25-2023, 09:48 AM | #7 | |
Joint Chiefs of Staff
24198
Rep 190,805
Other tuners must either be more conservative or blindly add boost and hope that the ECU protects the car if things go south.
07-26-2023, 10:29 AM | #8 |
1228
Rep 1,350
