04-16-2024, 01:44 PM | #1 |
Rep 8
M5 F10 Deka Clutch issue
Hi ,
I have M5 F10 , FBO , Forged engine , pure turbos stage 2 Around 7month ago i ordered Deka clutch stage 2 My garage installed it for me and after around 400km when i go back home from 30km trip i can't put R anymore it just trying to put R i hear loud knocking and trans go in N , i drive aroud town to check what happen and notice 1gear gonne as well so i back home and leave car to my garage next day , they dissassembly trans and found out the clutch is completly burned In december contacted the shop with i buy the clutch i explained the whole situation and they ask me to send back the clutch to deka i sended the burned clutch and in february i get new clutch not just plates as previous but now with basket as well (many thanks to Deka and the shop) Today i pick up the car with installed brand new clutch also i put stock map on the car to be sure nothing happen to clutch My home and garage is 30km away mainly highway i drive allmost all the time around 140-160 but at somepoint i pass car and put a little more power like really not much and then i notice when it downshift it think a second and after it engage clutch properly and start to give power so thats was strange so i repeated it again but this time i drive around 120km and put some power the car drop the gear but still think engage the gear a little rpm rev and engage second time the gear but now properly and then the car start to have some power but after the second time i get error trans temp too high so i slowed down and stoped at next gas station it was around 5km Checked codes i get Clutch temp - phase red Clutch temp - phase black It was just 30km after installing new clutch Any idea what can be wrong? |
04-18-2024, 04:37 AM | #3 | |
Rep 8
Car was changing gear fine in town driving , problem start on highway speed I put BMS Oil pan for trans better cooling , is this can cause problems? Low oil pressure under load? |
04-30-2024, 02:26 PM | #4 |
Fueled by Recycled Dinosaurs!
632
Rep 1,172
Drives: F06 M6
Just had a similar issue with my S2 Deka Clutch driving from Tampa to Orlando. By the time I came to a stop and pulled in the driveway I only had 1st gear.
05-03-2024, 07:33 PM | #5 |
Rep 8
Im now after 400km
Upshift get better , little knocking but except that is fine The issue is downshifting it feel like the clutch get engaged with delay and this cause slipping I gonna make another 400km trans adapt and then will check how the clutch behave at WOT |
