10-24-2018, 08:52 AM | #23 |
Rep 131
10-31-2018, 09:49 AM | #24 |
Rep 72
Thinking about trying to buy the 740M msport 5 star euro style 20 rear wheel measuring 305/40/20. I like the look of staggered, but dont want 21 because I live in the city. Does anyone know if I order the car with the square set up, then order the larger rear wheels, will I run into offset problems when installing the 305 rear? Thx
11-16-2018, 07:03 AM | #25 |
Rep 2
Wheel Offset?
This seems to be the best wheel infor so far....
https://www.wheel-size.com/size/bmw/...m-40i-eudm-456, Still no confirmation on the offsets....does anyone know the offsets for sure? My car arrives in 2 weeks and I need wheels for winter tires (I ordered with the 21" wheel and Summer tires) no good in Canadian winters....any help is appreciated. |
11-16-2018, 07:43 AM | #26 | |
Rep 128
If anyone has access to the 740M part for order yet and know how much they cost it would be appreciated. |
11-16-2018, 08:23 AM | #27 | |
Rep 276
Drives: 2019 X5 50i
https://www.bmwpartspros.com/partloc...catalogid=8798 |
11-16-2018, 09:52 AM | #28 | |
Rep 128
11-16-2018, 10:27 AM | #29 | |
Member
899
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
11-16-2018, 05:31 PM | #32 | |
Rep 2
Cheers much appreciated. |
11-16-2018, 10:39 PM | #33 | |
Rep 276
Drives: 2019 X5 50i
That's the wheel and part number, can probably call since they don't have everything online at this point for the G05. |
11-19-2018, 04:18 PM | #36 |
Rep 128
03-07-2019, 02:59 PM | #37 | |
Rep 7
I have a set of older MB GL450 wheels that are 5 x 112. Tire size - 265/40/22. I tried to see if they would fit, but the front wheel would not clear the M brake caliper. I am wondering if a wheel spacer would solve this problem?
03-07-2019, 03:08 PM | #38 | |||
Rep 428
1. Is the wheel diameter big enough for the caliper. The m brakes might need at least an 19" wheel or possibly a 20". Since you have a 22 it should be ok. 2. Offsets, the GL wheels are sound 62 mm while the new X5/x7 are around 38mm, so you need roughly 25mm spacers. This website has great info: https://www.wheel-size.com QUOTE=Brooklyn X5;24483806]I have a set of older MB GL450 wheels that are 5 x 112. Tire size - 265/40/22. I tried to see if they would fit, but the front wheel would not clear the M brake caliper. I am wondering if a wheel spacer would solve this problem? Quote:
03-07-2019, 03:10 PM | #39 | |||
Rep 428
1. Is wheel big enough to clear caliper. Probably yes with a 22" 2. Offset. Bmw is around 38mm while gl is over 60. Try a 25mm spacer. This website has good info : https://www.wheel-size.com QUOTE=Brooklyn X5;24483806]I have a set of older MB GL450 wheels that are 5 x 112. Tire size - 265/40/22. I tried to see if they would fit, but the front wheel would not clear the M brake caliper. I am wondering if a wheel spacer would solve this problem? Quote:
