07-03-2019, 03:35 PM | #23 | |
Rep 3,507
2022 M8 Comp Convertible
07-03-2019, 04:32 PM | #24 | |
13275
Rep 19,805
07-03-2019, 04:37 PM | #25 |
21
Rep 49
The tires are designed to run on the sidewall and keep the wheel from scraping the ground when one goes flat, but, driving it on the sidewall still ruins the tire. It will get you home, but you need to replace it afterwards.
The info about ruining the tire once you drive on it while flat is not easy to find and kinda hidden by the runflat manufacturers. |
07-03-2019, 04:39 PM | #26 | ||
Rep 2,609
07-04-2019, 09:34 AM | #27 |
Rep 128
I ordered my X5 with non runflat (19" 734) and BMW automatically added the tire repair kit (2VC) option. No spare tyres. Hopefully I don't get the chance to use the kit.
Past - E60 535i, F07 535i, G05 X5 xDrive40i
Current - I20 iX xDrive40 |
07-04-2019, 09:46 AM | #28 |
Rep 4,337
We don't have that option here in the US. I talked to a dealer here and asked if I could order the 19's with non run flats and was told no
07-04-2019, 09:46 AM | #29 | |
Rep 2,609
RFTs are not repairable (eg plug) and that's clear from all communication, but I don't know if there is a lot of knowledge about RFTs and the messy seal-and-reinflate kits? Besides the mess on the rim, is that a "good idea" for RFTs if a spare is "impossible"?
07-04-2019, 09:50 AM | #30 | |
Rep 4,337
07-04-2019, 10:04 AM | #31 |
Rep 3,507
They says this because the assumption is that you drove with a flat on the side wall breaking down the integrity of the tire. So when you get to shop they do not fix those for liability.
07-04-2019, 10:47 AM | #32 | |
Rep 4,337
Tire pressure monitors help but few drivers are prepared to pull over, pull out the nail and plug and refill on the spot and if they wait while AAA is called, by the time they get there, the tire is as flat as pancake and toast. That's where run flats or self sealing tires come in. Here's a short article that speaks to run flats vs self sealing tires - just an info article. https://www.autotrader.ca/newsfeatur...sealing-tires/ |
07-04-2019, 02:15 PM | #34 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
I also asked for non run-flats. This dealer doesn’t stock anything BUT runflats, so they don’t have any alternates on hand, and they also insinuated it might affect the warranty.
07-04-2019, 06:28 PM | #35 |
Rep 4,337
Obviously BMW sells cars with normal tires, I don't see why they won't let a buyer choose the one they want...I mean, who's paying for the car anyway.
07-04-2019, 06:49 PM | #36 | |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
I’m retired. Nowhere to go, nothing to do. Happy as a clam. For a car I only plan to keep for four years, my biggest concern is what to do with the NEXT car. I know nothing about tires, we only have to buy them rarely (my last set was a 70,000 mile Bridgestone, on sale at sams that week). I feel badly for all of you who have to worry about summer and winter conditions. I had a Honda Odyssey when I lived in Iowa, and rarely had trouble with what was probably all-season tires, but they always got roads cleared quick. I lived in the Des Moines area, so basically the only large city in Iowa. I also grew up and lived after college in New Hampshire. Didn’t change my tires then either. We just took our chances and tried to avoid driving during the worst conditions. |
07-04-2019, 06:56 PM | #37 |
Rep 23
Since I don’t have a spare, I’m probably going to get the Mobility kit and the DynaPlug kit. At least if I do have a flat & the run flat tires don’t hold up I can plug the tire & pump it back up and should at least be able to drive until I can get a new tire. Hopefully I will never need it.
07-05-2019, 08:19 AM | #38 |
Rep 61
I just keep a mobility kit in all my cars. Runflat or not if the tire blows, your screwed. For the M5 I did purchase and extra rim/tire to keep on hand. When tires need to be changed I keep the best used tire and use that as a spare.
07-05-2019, 11:25 AM | #39 |
Rep 833
The runflats have come a long way. The Bridgestone on my X5 actually aren’t terrible. Decent traction in snow and rain plus they haven’t knocked my teeth out yet.
If you drive most of the time in a metro area, runflats are fine except if they go bad. Some brands do not allow repairs (such as Pirelli) and shops like Discount Tire will only replace them. And of course they do not stock them. Outside of a metro it gets more dicey since many shops have no idea how to work with them and do not have the equipment. This is the first BMW that I haven’t replaced the runflats are purchase and I’ll probably run them until they need replacing. This discussion always creates all kinds of reactions and debates! |
BayAreaBimmers359.50 ElectroGeek190.50 |
07-05-2019, 11:25 AM | #40 |
Rep 128
Don't know much about RFTs but my last car 5GT came with RFTs. When I was quoted the price of replacement RFTs, followed by non RFTs, it was an easy decision...
LexxM31698.50 |
07-06-2019, 01:40 PM | #42 |
Rep 4,337
The mobility kit, which is nothing more than a mini 12v air compressor and slime is not recommended for run flat tires. In fact, nothing is recommended for run flat tires, that's the main purpose of run flats, your tire pressure sensor tells you when you have an issue with a tire and you then schedule an appt to have it checked/replaced. If you blew the sidewall, you're calling a flatbed.
However, for non run flat tires, this may work. I run non run flats on my X3 and carry my own pump, vise grips, water bottle, jack, tire plug kits, etc and have used it on one of the front tires. I was lucky enough to see the nail in the tire after pulling into a rest area and parking the car. Came back to the car, saw the nail, said a few swear words (to give me strength), jacked it, pulled the nail out, squeezed out the glue onto the tire and on the plug and plugged it while it was still on the car. I then filled it with air from my little pump and off we went. Two years later and am still running that same tire without issue. The Dynaplug may have also done the trick but I didn't know it existed two years ago. Here is a link to a Dynaplug video. https://www.youtube.com/watch?v=EjmPOrdd5b4 For me, no matter what kind of tires I'm running, I will alway carry tire repair tools and plugs in the car. The first objective is to be able to drive to a safe place, the last objective is to still be able to use the same tire till the tread wears out. All kinds of stuff happens in-between |
07-09-2019, 08:23 AM | #43 |
85
Rep 317
Drives: MY19 X5 40i
Hi everyone, I too did not purchase the "space saver spare" package when I order my car which I should've (regret now). I always feel safer with the spare in the car due to the past experience but dont know why I cheap out on the G05. Bought a set of wheel locks and found out that my car does not even come with the "wrench". I can't even do anything with it now . does anyone know whats the wrench size for the G05 ? looking to purchase one just in case anything happen.
Appreciate the help |
07-09-2019, 06:59 PM | #44 |
Rep 23
Being this will be my first experience with Run Flats.. what happens if I get a nail (large enough, but not tire tearing) or some small puncture that is detected by the TPMS and I presume we can run another 50 miles, give or take--- and I park the car at night after using only running 5 miles on the nailed-tire. Does this mean the next morning the car is still good to go for another 45 miles? Or would I find a dead tire by next morning ?
