10-31-2023, 09:53 AM | #1 |
434
Rep 353
Can someone confirm the minimum rotor thickness for the 19” M-Sport rotors please.
Can’t locate on the hat. I am currently at 34.5mm and need front pads. I believe a resurface will put them under minimums.
Dont be humble, give me that rumble. 2022 F95 X5MC, 2020 G05 40i, 2016 F86 X6M (sold), 2014 328ix F30 (totaled), 2009 e91 328ix (sold), 1997 740i e38 (nikasil fail)
10-31-2023, 10:40 AM | #2 |
Rep 1,078
Minimum thicknesses are often embossed in the rotor (or is that what you meant by "hat"?).
Check www.realoem.com for the replacement rotor. Minimum thickness is sometimes spec'd there. |
10-31-2023, 11:47 AM | #3 | |
434
Rep 353
10-31-2023, 03:18 PM | #5 | |
Rep 7,484
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-31-2023 at 03:30 PM.. |
Dgjo2022X5MC433.50 |
10-31-2023, 06:48 PM | #6 |
Rep 1,078
This thread raises an interesting question. I always thought the minimum thickness spec was for machining, not wear. That is, a scored/warped rotor can be machined down to the min thickness, and remounted. But further scoring/warping mandates replacement.
10-31-2023, 09:41 PM | #7 |
434
Rep 353
I think the rotors are spent at 34.4, regardless how they got there. Be it wear or machining. Mine are ar 35.5 wear, after 45k miles. Machining will put them under. Wife’s car, so mild driving.
10-31-2023, 11:49 PM | #8 |
Rep 3,681
As far as I am ware of, the spec is spell out more for head capacity related aspect, but not structural aspect. The rotor has plenty of strenght at that thickness. It is if you take car to some serious driving, and stress the brake, under that thickness, warpage or other deformation "can" happen. It is more of they test to that thickness and meet the requirement.
2022 G05 B58/PHEV
+ a few very old BMWs |
11-01-2023, 04:58 AM | #9 |
Rep 204
Drives: 2022 BMW X5 xDrive 40i
Ok the big questions is; how much does it cost to get both the pads and the rotors replaced?
Upon visual inspection mine will be due soon (pad sensor hasn’t been touched yet). Interestingly rears seem worse than the fronts. I’m at 51k miles on my 2022. |
11-01-2023, 06:20 AM | #10 |
434
Rep 353
Rear pads replaced at about 40k miles and rotors resurfaced. They said fronts were not at replace spec yet (for +1 Maintenance Program).
Not sure what the front rotors cost. I suspect around 350 each.
11-01-2023, 09:26 AM | #11 | |
Rep 7,484
TheACN104.50 |
11-01-2023, 09:46 AM | #12 |
Rep 8,815
Make sure the gauge you are using isn't getting caught on the lip of the worn rotor giving you an inaccurate reading. I had to find a particular one where the contact point was raised slightly to avoid this on my X5M which i can feel has a sizable lip at the edge of the rotor
This is the tool I bought from amazon As for minimum thickness and how it impacts the system I found this from the Brembo site. Minimum brake rotor thickness The correct operation of a vehicle’s braking system depends on various factors. During maintenance work, a lot of attention is paid to brake pad wear but often neglecting to check the thickness of the rotors. Although entirely incorrect, it is common belief that the brake rotor is not subjected to wear. In actual fact, the same phenomenon responsible for brake pad wear leads to wear to the brake rotor as well. The rotor wear limit is specified, as thickness below this specification will not guarantee the correct braking efficiency. This is a fundamental parameter and should be kept in mind during routine checks. What are the consequences of using a rotor that is excessively worn? Reduced thickness reduces the heat dissipation capacity of the rotor and its mechanical strength, triggering a series of critical faults and failures, such as: the formation of thermal cracks on the braking surface, due to the rise in temperature and the reduction in the resistance thickness deformation of the brake rotor, resulting in vibrations and noise increased pedal travel, caused by reduction of thickness of the braking surface. In extreme cases, this can also lead to loss of tightness on the part of the caliper piston, with the risk of the pads themselves coming out of their seat or seizing. In addition to the above problems, the use of a worn rotor could lead to the onset of another extremely dangerous phenomena, which could be generated in particular in conditions of heavy-duty vehicle use. These two issues are vapour lock and fading. The high rotor temperature caused by a large number of braking actions - which is typical on a mountain trail - could generate the formation of vapour lock: in other words, the rise to above 200°C in the temperature of the braking fluid. The fluid overheating generates air bubbles inside the circuit, air bubbles are compressible, which leads to no deceleration when pressing the brake pedal, despite being pressed all the way down. The phenomenon of fading is also tied to the rise in temperatures, due to the reduction in the rotor thickness and the heavy-duty use of the vehicle. This rise in temperature reduces the friction coefficient between the brake pad and the brake rotor, with the ensuing increased braking distance.
Dgjo2022X5MC433.50 eelnoraa2032.50 |
11-01-2023, 10:37 AM | #13 | |
Rep 1,078
Obviously, if your rotors are still above min thick and there's no unusual wear, there's no need to replace them. If the rotor thickness is less than min thick, then they should be replaced. If your rotors have scoring or warp, and machining can resurface them and remain at or above min thick, then the rotors are good for use with one more new set of pads. Is anyone's understanding of this different? I'll ask the auto store machinist that does rotor resurfacing next time I stop by. |
11-01-2023, 11:58 AM | #14 |
434
Rep 353
I think my thickness gauge has a recess that would allow the lip of a rotor to not interfere like the one posted, but will check.
I wonder how much material is removed with resurfacing a rotor?
11-01-2023, 12:22 PM | #15 | |
Rep 3,681
2022 G05 B58/PHEV
11-01-2023, 12:30 PM | #16 | |
Rep 3,681
I have done plenty of pad swap with same rotor myself. Such as before and after each auto sport event, I will swap to high temp pads, then back to factory pads. So effectively I am using more than one set of pads per rotor. I haven’t measure rotor thickness for a while, from the look, they are still very thick. Next time I do brake bleed, I need to remember to measure rotor thickness
2022 G05 B58/PHEV
11-09-2023, 08:40 AM | #17 |
Rep 1,078
I had the chance to stop by a local O'Reilly's earlier this week and ask about rotor resurfacing. Here's a brief summary.
1. A take-off rotor that measures at or less than minimum thickness is a throw-away. 2. Resurfacing down to the minimum thickness is permitted, and the rotors can then be re-mounted with a new set of pads. 3. If resurfacing down to minimum thickness doesn't completely refinish the surface, replacement is recommended. 4. Warp is the biggest problem -- machining to minimum thickness might not remove the warp or completely refinish the surface. Replacement is necessary. 5. Cost is $25 per rotor. Machining is done on-site using a specialty rotor machining lathe. Turn-around time is usually no more than a day; maybe same day during the week. The replacement cost of the rotors on my Jeep is $75 each, so even these warrant machining at $25 if minimum thickness spec can be maintained. |
11-09-2023, 09:37 AM | #18 | |
Rep 3,681
2022 G05 B58/PHEV
11-10-2023, 10:11 AM | #19 |
434
Rep 353
What does everyone think about being declined for brake service coverage on rotors for the following reason: rotors not eligible at 34.42mm.
IMO the spec is 34.4, not 34.4X. Not trying to get anything for free as I paid for ultimate +1 and brakes are squealing like a stuck pig every stop.
11-10-2023, 11:20 AM | #20 | |
Rep 3,681
2022 G05 B58/PHEV
11-10-2023, 11:57 AM | #21 | |
434
Rep 353
Service Manager made a good call waiving as I flat out said I wasn’t paying that. This all feels disingenuous from BMW as they really don’t explain all this when you buy the maintenance plan in advance. They are in complete control. It’s like managed healthcare I supposed. If the need doesn’t fit some guideline, you are out of luck. I won’t buy these in the future and just ‘self insure’.
11-10-2023, 12:05 PM | #22 | |
Rep 3,681
2022 G05 B58/PHEV
