02-12-2024, 01:46 PM | #1 |
Rep 56
What to Check Before Buying CPO?
As the title suggests, what are some possibly lesser-known things to verify or ask about when buying a CPO? Anything specific to the 2020-2023 M50i worth inspecting?
I have asked for the obvious (service history, carfax, CPO inspection checklist, a few car-specific items), but is there anything you wish you had asked prior to purchase? I searched the forums (and used site:Bimmerpost.com on Google), but apologies if I missed any similar threads. |
02-12-2024, 01:56 PM | #2 |
13266
Rep 19,785
I would get a pre-purchase inspection. There are many things not covered by the CPO inspection and warranty. It should be worth the couple hundred it may cost you.
thereef5101165.00 |
02-12-2024, 02:04 PM | #3 |
Rep 958
IMO, tires are the big ones, as the 21 and 22" tires are pricey. Brake pads/rotors can be pricey depending on your DIY level. They're fairly reasonable if you DIY them, not cheap, but way better than paying for W tondomit.
I don't really know what else would be something that's not just normal stuff to check out (paint condition, interior wear, etc) or covered under warranty. |
02-12-2024, 02:19 PM | #4 | |
Rep 56
That is another topic I searched to little avail—does anyone know the rough lifespan of a set of rotors and pads? |
02-12-2024, 02:31 PM | #5 |
Rep 1,147
The CPO checklist should have tire tread depth and brake pad thickness.
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^ 2017 X5 35d--still in my diesel phase 2015 GL 350--diesel burner/highway queen 2013 Audi S6--a beast in it's day |
02-12-2024, 03:26 PM | #6 |
13266
Rep 19,785
It will depend on how and where you drive. During "normal" mixed usage you will probably see 75 - 100k miles. That said, we have seen some needing them under 50k with hard usage.
02-12-2024, 03:40 PM | #7 | |
Rep 958
That said, I agree that brakes pads and rotors should last minimum 50-100k miles. |
02-12-2024, 03:50 PM | #8 |
Rep 56
It does indeed, more just looking for a high level indication of average life in miles (obviously a lot of variables). But I suppose you can just assume an initial thickness of 10-12mm and infer from there based on mileage.
02-12-2024, 04:01 PM | #9 |
13266
Rep 19,785
Keep in mind that for CPO purposes the tread depth is measured from the top of the wear bars and not from the bottom of the tread.
02-12-2024, 04:06 PM | #10 |
Rep 1,147
Depends on the tire, RFT or non RFT, all season or performance, size, etc. some performance tires have only 8/32” when new. A depth gauge is cheap and you can measure them yourself
02-12-2024, 04:19 PM | #11 | |||
Rep 56
LDT1539.50 |
02-12-2024, 04:27 PM | #12 |
817
Rep 1,785
Be aware that CPO does not mean it will be perfect. I have heard of CPO cars having been repaired to include new body panels. It is definitely worth hiring someone who is capable of performing an overall inspection of the vehicle. Hopefully the used car manager at the dealership selling the car will be transparent and share the CPO inspection report with you. If not, I would be suspicious. Also, don't depend on a CARFAX to ensure the repair history. Some repairs fail to make it into CARFAX. Good luck with your purchase.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
LDT1539.50 Hydrocarbon24.50 |
02-12-2024, 04:37 PM | #13 | |
Rep 56
02-12-2024, 09:30 PM | #14 |
Rep 83
Please check the cosmetics carefully. Check out seat bolsters, curb rash, broken interior trim. I'd check every single storage compartment to make sure the latches are OK. There is a lot of dealer to dealer variation in the cosmetic refurbishment that goes with a CPO. Ask for the CPO inspection worksheet. It's incredibly helpful. Make sure you get both keys and the cargo cover.
X |
Hydrocarbon24.50 |
