03-06-2021, 04:29 PM | #23 | |
Rep 176
Drives: 2019 BMW 330i
Have you coded back auto lane change/highway exit assist to see if they improved that? I've had it enabled with 11/2020.45 but it's a far cry from other auto lane change assist technologies out there. It'd be awesome if it was dynamic based on traffic conditions. It seems to just suggest carpool lane when available and start exiting when your exit is approaching. Certainly not based on traffic conditions. |
03-06-2021, 04:31 PM | #24 | ||
1200
Rep 1,587
03-07-2021, 03:07 AM | #26 | |
1200
Rep 1,587
I don't think this would work well in oz as it stands anyway. Even in the U.K. there is 1 type of rare light it's 'blind' to. If they arent develop and testing in OZ yet, or aren't that far along, then that's probably why the software is blocking and not the coding. The ucc landmasks are where it is controlled in coding btw. I can turn regions on and off, and even have it auto accept a light or not, using those 2 masks. |
03-07-2021, 04:59 AM | #27 | ||
Rep 51
If you are comfortable please can you kindly share how can I change the landmasks/enable my region? I really want to try the UCC. Thanks Deja011 |
03-07-2021, 05:47 AM | #30 |
1200
Rep 1,587
It'll come eventually, unless there is some hard regulatory block.
There was talk of there being a blocking file for earlier model AUSY BMW cars, which was located on the internal HDD/SDD. I've not looked into it, and it does seem unlikely to be the issue here considering BMW have a simple way of blocking/unblocking regions using the landmasks, which seems to be the strategy. There is one other extremely unlikely possibility. They may have changed the way the bitmasks work for TLA/UCC and all Binary 1 for the mask may not allow all features and regions. It's different to how they do aSLA for example, but a 1 in the wrong place may actually disable the function for AUSY. Issue is we don't have a key to determine what bit pattern maps to which feature/region. All we know is that the default for the SAS3 models is: 00001000 00000000 00000000 00000000 Changing this to 11111111 11111111 11111111 11111111 unlocks TLA for most regions |
03-07-2021, 05:54 AM | #31 |
Rep 2,249
21-03-530 is becoming available - seems that pretty much every file in the MGU is updated compared to 520/525, so changes incoming.
If you are considering D/L 525, wait till later this week |
03-07-2021, 06:02 AM | #32 | |
1200
Rep 1,587
Lights are buzzing as I approach the car/unlock and stay buzzing until start. Like it sometimes does when arriving at a destination after engine off |
03-07-2021, 06:06 AM | #33 |
Rep 2,249
That's an odd one! Seems the only ECU to be updated though - black across the board apart from the MGU, which gets a new bootloader & SW. I did a TAL Calc with the lite data this morning, so I knew whether or not it would be worth getting the full when it lands shortly !
03-07-2021, 07:45 AM | #34 | |
1200
Rep 1,587
03-07-2021, 10:00 AM | #35 |
Rep 2,249
Pretty much any SP18 (and SP15 for that matter) car shares ECUs with each other, there's very little difference between them, other than the Encoding configurations.
And I wouldn't expect a huge amount of ecus to change in a few days, i've seen this before where you get a lot of ECUs change from say YY-11 to YY-03, but that YY-03-5xx to YY-03-5yy, eacgh one addresses changes to targetted ECUs |
03-07-2021, 09:23 PM | #36 | |
Rep 8,775
Drives: eVeRyOnE mAD!
** must enable the BMW Connected skill in the Alexa app and link accounts ** |
03-09-2021, 03:51 AM | #39 |
Rep 2,249
Updated! But nervy though as for the first time I got a HTTP error, so it fell back to UDS ( I use esys). Thankfully though, it only took 40 minutes to flash, instead of the usually 15, but a darn sight Better than the 4 hours the old EVO did.
03-09-2021, 06:32 AM | #40 |
9
Rep 42
I'll update 525 to 21-03-530.
now I wait psdzdata file's unarchive...
2014 ~ 2017 Chevrolet Cruze J300 1.8
2017 ~ 2019 Mercedes Benz W205 C200 2019 ~ 2020 KIA Motors YG K7 Premier 3.0 2020 ~ BMW G20 320i |
03-13-2021, 10:36 AM | #44 |
1200
Rep 1,587
bimmerelectric14.50 |
