10-23-2023, 09:43 AM | #1 |
Rep 85
Drives: 2021 BMW X7 40i
Augmented Reality is on all the time. 2024 X6
Is there a way to only have Augmented Reality show when approaching turns, instead of just being on 100%?
If so, how? |
10-23-2023, 10:22 AM | #2 | |
Rep 2,115
Dont select AR in Cluster - otherwise it will be on all the time. Next decide where you want it to popup. Either in cluster or control display. There is a setting in ID8.5 to select where you want the AR popup to be displayed. Select your choice. None, cluster or control display Depending on what you selected above, you then must be in navigation/map view in cluster or control display for AR to pop up when there is a upcoming turn. |
10-23-2023, 10:53 AM | #3 | |
223
Rep 351
10-23-2023, 11:52 AM | #4 | |
Rep 137
Drives: '24 X6 M60i
10-23-2023, 04:08 PM | #5 |
Rep 2,115
gadgetfreak2024223.00 |
10-23-2023, 04:10 PM | #6 |
Rep 2,115
Yea, but that will only be selectable if it was showing a current turn. You'll see that setting disappear the moment there is no longer a current turn. Its a bit odd ...
10-23-2023, 06:49 PM | #8 |
Rep 85
Much Appreciated
