10-31-2023, 03:30 PM | #1 |
Rep 26
2024 X5 M Competition
Hi All, need your help regarding this topic...
I've purchased a 2024 X5 M Comp and the car is marvelous, but the suspension. I fully understand this is a track oriented performance vehicle, but the suspension is far from "stiff", but ultimately extremely harsh. I'm sure at this age of engineering revolution there has to be options to keep the factory 'settings' but adding a level of comfort before I start regretting my purchase and hating it. I like the chassis rigidity and non-existent body roll, but feeling my ribs crunch in every irregular surface is painful. What will be the ideal suspension solution for this without braking the bank... anti-shock springs, air suspension kit, etc.? Please assist me as the suspension is unbearable in its original configuration. |
10-31-2023, 03:49 PM | #2 |
2729
Rep 1,673
Sorry to hear you dont like it. Did you test drive it? Ive had many different Ms and my 24 X5M is by far the most comfortable. My previous M3 was harsher and my 23 X3M throws you a few inches above the seat when running over a pebble.
10-31-2023, 04:04 PM | #3 |
Rep 2,043
Drives: 2022 X6///M Comp
What setting are you using? Did you try changing to comfort? I like a firm ride so Im always in sport.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
10-31-2023, 04:14 PM | #4 |
Rep 95
which brand tires do you have? i have noticed that the Pirelli's my car came with tend to ride a little rough over imperfections of the tire PSI is off by 1lb or two.
ive noticed this car is very sensitive to changes in tire pressures. maybe add a little more PSI and give it a try? i try to keep simlar numbers as reccomended with the rear tires being 3psi more than the front whilst the tires are cold.
2022 BMW X5M Competition
Marina Bay Blue/Silverstone, Full Car PPF & Ceramic Coating, Exoshield WPF, Forged Vossen EVO 5 in Bronzino, Full RW Carbon Fiber Kit, Carbon Seat Backs, M Performance Carbon Tips, Redstar Primary & Secondary Catless Downpipes, Dinan Carbon Fiber Intake, Dinan Stage 1 Tune |
10-31-2023, 07:41 PM | #5 |
Rep 26
Is not that I hate it, is just the suspension specifically, it is way too harsh... In sport-plus mode I get that it is super tight and rigid, but it is also rough in efficient & sport mode. From an M3 forum, I saw people posting that sport mode is "softer" than efficient, which is true a bit (only by 15-20%). I love the car, the color, the interior, the eager engine, but the suspension is just killing me. I honestly cannot suck it up and leave it as-is. I need to replace the springs or do something about it. When I test drove it, I noticed it was on the firm side, but it wasn't that horrible back then. I'm riding on Michelins sport pilot which have almost no side wall so that probably contributes, but still my 2022 M50i was marvelous riding on 22" (higher profile all season tires), but suspension was 70% same as this one (2024 X5M) since it had the dynamic handling package which adds the M professional suspension and active roll stabilization.
What do you guys recommend me doing? I really need options... thanks! |
r33_RGSport13022.00 |
10-31-2023, 07:59 PM | #6 | |
Loving Life
64
Rep 38
Your X5MC has springs and dampers in all four corners. You can try different springs - there is plenty of info on this forum on available options. If you don't mind spending some $$, coilovers are your next step. IMHO trading her in for a car you really like is the way to go. Just make sure to properly test drive it 😉 |
10-31-2023, 08:10 PM | #7 | |
Rep 3,940
10-31-2023, 09:39 PM | #9 |
Rep 3,706
How about start with 21 or 20 wheel/tires setup?
Firm vs soft is very personal, so you can refer to others preferences such as in M3 forum. In fact, X5M is already considered soft compare to M3. In your case, I wonder if you can just sell and to M60i and call it done? Suspension setup is a big part of M car. It is more than just spring and dampers. The control arms and bushing also make a contribution to the firmness. How deep can you go to make it soft like non M x5? And how long do you plan to keep the car? once you make suspension components change, it is impossible to sell it as an M car anymore.
2022 G05 B58/PHEV
+ a few very old BMWs |
X6ix GTA142.00 |
11-01-2023, 05:20 AM | #10 |
Rep 819
Something sounds fishy here....
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582) Gone but not forgotten: -'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG |
11-01-2023, 08:59 AM | #11 | |
13022
Rep 18,739
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
11-01-2023, 09:50 AM | #12 |
Rep 26
MSS Lowering springs sound like a good option. Can you please share more details on this? Of course I'm researching on my end, just wanting to make sure to capture any good point you are aware of, thanks.
11-01-2023, 11:53 AM | #13 |
50
Rep 39
Sounds like you should have got a M60i with air suspension ...
If my wife asks, it was only $499...
Car-Addicted7198.50 Ibiza3635.00 |
11-01-2023, 11:57 AM | #14 |
Rep 3,706
How would a lowering spring help in ride quality? If anything, lower spring means increase in spring rate, making ride harsher trading for flatter cornering?
2022 G05 B58/PHEV
r33_RGSport13022.00 MADBMWX5MC876.50 |
11-01-2023, 04:12 PM | #15 |
Loving Life
64
Rep 38
11-01-2023, 04:26 PM | #16 |
7199
Rep 1,950
Drives: 2020 BMW M4 CS
No easy answers here. The cost of reengineering your suspension will not be cheap. I would have a conversation with your dealership sales manager. The most reasonable choice would be to change out to 20"/21" wheels out for 20"'s but you will most likely not be able to use your M calipers. Changing the aspect ratio of the tire will make a big change in ride. There should be a good market for your take off's to defray the cost. Good luck.
11-01-2023, 09:18 PM | #17 | ||
13022
Rep 18,739
Here is the link on MSS thread. https://g05.bimmerpost.com/forums/sh....php?t=1766804 You can put your question there and get a feedback from the end users directly. I had MSS on my X3MC and currently on my XM. Quote:
Unlike conventional factory progressive spring style, some manufacturers doing it differently. Some goes softer spring rate, some goes with stiffer spring at different length. For example, H&R sport spring is progressive spring, it may have the same spring rate as stock, just increased the amount of lower rate coil on top of the same/stiffer rate to stock. While MSS, they are using tender spring to smooth out the sharp bumps, while the main spring is close or same rate as stock spring. Unfortunately, most aftermarket even OEM doesnt disclose their spring rate.
11-01-2023, 09:22 PM | #18 |
Rep 3,706
I think the way you describe it, the difference comes from dampers. Both compress and rebound dampening are lower. The trade off is handling characteristics.
2022 G05 B58/PHEV
11-01-2023, 09:49 PM | #19 |
13022
Rep 18,739
I believe he meant KW spring, not coilover.
fallen63.50 |
11-02-2023, 06:36 AM | #20 |
DD214
273
Rep 286
I thought mine was a little harsh coming from my 2023 X5 45e and Audi S6 which both had air suspension. I've had my X5MC for two months now and I'm used to it. I might grab some new Dinan springs to make the ride a bit better, but for now I think the X5MC is an amazing piece of machinery. I knew what I was getting into beforehand because I did my research, just saying...
r33_RGSport13022.00 beammeupscottie1101.00 |
11-15-2023, 08:38 PM | #21 |
Rep 193
I went with 22s and upsized the sidewalls all around. Softened the ride just enough and took away some of the wheel gap. Happy with the decision 25k+ miles and counting.
MADBMWX5MC876.50 GJCaesar19.50 |
11-17-2023, 09:24 AM | #22 | |
Rep 1,265
Did you keep the 21 stock?
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
