04-24-2021, 12:37 AM | #1 |
12
Rep 42
2021 X5 45e Brake Pulse
Hi Guys,
My new 21 X5 45e now has about 2000 miles on it. And I still experience very slight pulsations when braking. It almost feel likes a ABS kicking in but much more subtle. It doesn't happen every time though. Any thoughts? Thank you in advance! |
04-24-2021, 11:05 AM | #2 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Mine is 4 months old MY21 X5 40i MSport with mild hybrid, currently has 3300 km. I am having similar pulsating shudder when I press brake pedal to slow down, especially from about 80km/hr. Initially I thought it is related to brake energy regenerative system, but it is more and more feels like brake pad deposits issue or some form of rotor warp. With Covid car is sitting in garage longer, don't know if that has anything to do with it. I also tried brake pad bedding by slowing down form about 80 km to 10km/hr repeatedly about 8 times and driving without braking immediately afterwards (as much as possible) to cool down the pads and rotors; however, the shudder is still there. Booked an appointment with dealership next week to find out what is going on.
By the way, BMW use Continental developed MK C1 brake-by-wire system. Here are two helpful videos on brake pad bedding and rotor warp:
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
04-24-2021, 11:23 AM | #3 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Here is another similar thread with similar reported issue, but the original poster didn't report back on the resolution (if there was any):
3rd brake replacement on 2019 X5, help! https://g05.bimmerpost.com/forums/sh....php?t=1803991
04-26-2021, 05:15 PM | #4 | |
12
Rep 42
04-27-2021, 11:25 AM | #5 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
The dealer is saying the brake-pedal shudder/pulsation issue is caused by pad deposit on the brake rotors. Apparently this is a common reported issue. Given the COVID situation it is plausible because I am not actually driving as much and the vehicle is sitting in the garage for days at a time. Their assessment is that it should go away as I drive more.
However, I am quoting an interesting paragraph from the article below: "… pedal feel can be tuned by engineers using driving simulators to give a more aggressive response on track and a more relaxed response in traffic. Another advantage is that pedal travel doesn't increase when the brakes take a beating and get hot. What the driver actually feels is a simulator built in to the MKC1 that generates the sensation normally fed back through the hydraulics, only it remains consistent however hard the brakes are working." https://thebrakereport.com/continent...wire-benefits/ Because the brake feel is simply a simulation built into the MK C1 system, in theory, the vibration caused by warp rotors should not be felt on the brake pedal, perhaps only should be felt by other vehicle vibrations, for example body/steering/dash is shaking. Hopefully someone with more knowledge on this brake-by-wire system will educate us.
04-27-2021, 03:16 PM | #6 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
05-04-2021, 03:36 PM | #7 | |
12
Rep 42
I asked what is causing this pulsation. Assuming that it is normal, what is the purpose of this designed pulsation? I have not received any notice on the recall you mentioned though. |
05-04-2021, 03:48 PM | #8 |
12
Rep 42
Actually just was told by the dealership that it's normal because
"when you get to the end of the travel you will feel a pulsation. Its the system pressurizing and releasing pressure. Also you have multiple systems slowing down the vehicle. You are feeling a little of that as well." Will you buy that answer? |
05-05-2021, 01:37 PM | #9 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
This explanation doesn't make a lot of sense to me. When brake pedal is pressed and travelled closer to the floor every car does bit of body shake/vibration. Here is my scenario:
Driving about 80 km/hr. Seeing a stop sign and slowly pressing the brake pedal with the aim to stop. I feel slight pulsating pedal at the beginning when I start pressing the pedal (NOT at the end when the pedal is closer to the floor). Summary: IMO brake feel isn't smooth, and learning to modulate the brake up and down to avoid shudder. My 15 year old car has better brake feel in comparison when it comes to pulsating issue. It doesn't bite and brake as fast as the X5, of course, but brake travel is smooth. I am really hoping this slight shudder goes away as I drive more.
05-05-2021, 03:06 PM | #10 |
Rep 8,766
Drives: eVeRyOnE mAD!
what's considered "new"? I have a 2020 week 49 45e... no brake pulsation in 2000 miles.
05-12-2021, 12:32 PM | #11 |
Rep 6,872
Brake by wire is a different animal than purely hydraulic systems especially when you have a hybrid involved with regeneration. With the 45e, on light brake pressure, you may not actually be engaging the brakes at all, then, it may blend in the hydraulic brakes, and at the end towards the stop, blend back out the regeneration. Personally, I think BMW has done a good job on that software blending operation.
I know the 45e does that, but I'm not as familiar with the mild hybrid system...it may do some regenerative braking, too...something is recharging their 48vdc battery, and it makes sense to use some regeneration since they have the ability...anyone know for sure? |
05-12-2021, 01:18 PM | #12 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Mild hybrid should have very similar brake regenerative system compared to 45e.
I documented my findings what the MY21 40i does when braking and decelerating here: https://www.bimmerpost.com/forums/sh...php?p=27580104
05-29-2021, 06:06 PM | #13 | |
Rep 5
Is this normal? It's my first time driving an electric/hybrid. Or should I get it taken to the dealership to look at? |
02-23-2024, 08:06 AM | #14 | |
Father Brown
29
Rep 23
SmartSaves462.00 |
02-23-2024, 08:12 AM | #15 | |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
02-23-2024, 12:59 PM | #16 |
Father Brown
29
Rep 23
Just the lower left control arm. That's the one.
SmartSaves462.00 |
04-10-2024, 06:51 PM | #17 |
Rep 28
Drives: 2018 530E xDrive, 2021 45e xD
Noticing the same in my '21 45e at about 34k miles. Seems more pronounced when braking starts from a higher speed (50mph+). If I'm just cruising around town at 20-40 with light braking then I don't notice anything. I usually just let regenerative slow me down if I know I have to stop, it's when I have to apply more brake pressure that I notice it, so it certainly could be deposits on the rotors from minimal use. At first I thought it was just the transmission having some rough downshifts as it ran through the gears but now I'm not sure what to think.
