04-01-2024, 01:34 PM | #1 |
Rep 11
Turbo Inlet Pipe
I need help finding a turbo inlet pipe. I have searched all over the internet and the best I get is no ETA on shipping etc. I have already upgraded my intercooler, charge pipe, and air intake. I have a blow valve ready to be installed but wanted to tackle the turbo inlet pipe at the same time. Any suggestions?
04-01-2024, 03:29 PM | #2 | |
DIY Mechanic
78
Rep 127
Drives: 2012 BMW 535i xDrive
You can live in a car but you can’t race a house.
04-01-2024, 04:55 PM | #3 |
Rep 11
N55
ChiltiCoatl891775.00 |
04-02-2024, 12:26 PM | #5 |
Rep 83
I'm running this one. Internal diameter was 2.036" compared to the factory plastic one that measured 1.88" or 1.83" if i remember correctly. Looking at logs, I cant say for certain that I can tell a difference.
https://www.ecstuning.com/b-ecs-part...0757ecs09~ecs/
2016 BMW 535i, MHD stage 2+, XHP stage 3, VRSF charge pipe, VRSF down pipe, VRSF intercooler, ECS turbo inlet pipe
StradaRedlands4964.00 ChiltiCoatl891775.00 |
04-02-2024, 03:11 PM | #7 |
Rep 11
I have a blow valve that needs to be installed and since they have to go under the car to do that they mentioned getting the turbo inlet pipe. It has been hard as hell to find.
04-02-2024, 05:46 PM | #9 |
Rep 83
The one I linked above is the turbo inlet pipe. It goes from the air intake, into the turbo. It’s not under boost so it technically is part of the intake.
04-03-2024, 05:55 AM | #10 | |
DIY Mechanic
78
Rep 127
https://x-ph.com/ftp-f1x-535i-intake...xoCH7YQAvD_BwE
04-07-2024, 03:32 PM | #11 |
Rep 102
Bro I can barely find one too for my n55. Also any thoughts on what intake to use ?
04-07-2024, 05:01 PM | #12 |
DIY Mechanic
78
Rep 127
Stock with a drop in filter and an inlet will be fine in stock turbo.
04-07-2024, 06:44 PM | #13 |
Rep 83
04-08-2024, 08:38 AM | #14 |
DIY Mechanic
78
Rep 127
Did the sound change at all? Or did you feel any gains?
04-08-2024, 12:08 PM | #15 |
Rep 11
I put the VRSF intercooler, and K&N cold air intake, and VRSF charge pipe. Those upgrades yes make a difference especially in sport + mode. I ordered the intake pipe listed above from ECS and also have a blow valve to go with that. After those I will get a downpipe and get it tuned.
04-08-2024, 01:47 PM | #16 |
Rep 83
Nope seems to sound and run the same. I just did them as supporting mods after I had already done a downpipe, chargepipe, FMIC, and stage 2+ mhd tune. The only thing I did notice is the wgdc% is lower which tells me they did help the turbo breath a little easier. Making 3rd gear pulls I used to regularly see wgdc% hit 95% now it stays closer to 87-88% at its peak.
poverty.f1078.00 StradaRedlands4964.00 |
04-08-2024, 04:33 PM | #17 | |
DIY Mechanic
78
Rep 127
04-12-2024, 08:20 PM | #18 |
Rep 436
Drives: 2016 F10 BMW 535i M Sport
Now if they only made Silicon hose kits for our engines, would be so awesome I would buy it instantly, for this thread, There are so few companies that make piping, all do pretty much the same, ECS Tuning does make a good kit that is on my sights, anyone with a video or photos of the plumbing would really make this even better to read for all those to see.
poverty.f1078.00 |
04-15-2024, 09:00 PM | #19 |
252
Rep 333
Drives: F10 535i xDrive, F25 xDrive35i
I have the one from ECS also. I didn’t notice much of difference in sound, throttle response, etc. then again the only other modification I have is a charge pipe, nothing crazy.
