02-02-2021, 08:38 AM | #177 | |
12971
Rep 18,715
Going to measure again today and take some pictures. I'll post it later.
02-03-2021, 09:41 AM | #178 |
Rep 105
Hi all!
My name is Jonathan and I am New to the forum. I installed my MSS springs over the weekend on my X5M. I have not been able to find the torque specs anywhere. So, I reverse engineered torque specs. I have a small popping or clunking noise in the front when I turn left to right loading the suspension quickly, and also when I go through rough pavement, bumps and holes. Does anyone have torque specs for suspension components? MSS will not give me any torque specs for liability reasons. This is the first time I have bought any aftermarket part that does not provide torque specs in the instructions. I tried finding the service manual online and No luck. I do not want to take it to a shop because I rather work on my car myself. But I am feeling pretty desperate at this point. MSS suggestions for support are useless without having the torque specs ☹️. Thanks in advance! I did drop it all the way in case that is a question anyone has. Looks better and the rear feels solid. |
r33_RGSport12971.00 |
02-03-2021, 11:13 AM | #179 | |
12971
Rep 18,715
But BMW forced them to put it down. AFAIK, even H&R, Eibach, KW, or other suspension company doesn't include the torque specs.
02-03-2021, 04:12 PM | #180 | |
Rep 591
02-04-2021, 07:09 AM | #181 |
Rep 105
That is unfortunate. I still do think that the springs could have come with better instructions that include torque specs per region; that is the main reason according to MSS why they didn’t include them because cars torque settings are region specific and they didn’t want to be liable. Maybe they are referring to units? Anyway, when I worked as a support engineer for a machinery and automotive manufactured we that all aftermarket equipment had al torque specs, images, and manuals printed out in several languages. Maybe we just went above and beyond 😬. Thanks for the info! At least I wind waste my time looking for the manual online anymore.
02-04-2021, 07:15 AM | #182 | |
Rep 105
I went with full drop. So, definitely needs an alignment. I just haven’t aligned it yet because there is something obviously wrong. I have seen the issues that MSS systems have had with previous systems. So, I wanna make sure that it is not a bad part before I spend almost money on alignment and more time. |
02-04-2021, 07:28 AM | #183 | |
Rep 3,507
2022 M8 Comp Convertible
02-04-2021, 08:55 AM | #184 | |
12971
Rep 18,715
But keep in mind that how much more overhead that the product manufacturers will have since all of these car manufacturers now doesn't publish their torque spec publicly. For example, BMW is asking (I think) $30/day for their online TIS access or $1000+/year. Just that alone, I would say they will have to increase the products pricing. And for those that includes torque spec, I still have to double check with BMW specs. Because most of the time it is different than what BMW recommend.
02-04-2021, 12:05 PM | #185 |
Rep 105
Thank you for the input. I will add to the checklist of things to look for. It is a possibility that something might have gotten misaligned after putting weight on the axle. I checked on the lift but not after dropping.
02-04-2021, 12:10 PM | #186 | |
Rep 105
02-05-2021, 08:26 AM | #187 | |
Rep 105
Good news: I was able to adjust the strut top nut now that the springs are under load and that took care of the rattling noise I had while going through bumps or rough pavement. It seems like there was enough travel to get slack up top, which resulted on rattling while under sudden loads. I would have been able to avoid this with better instructions. This happened to be the only nut I did not reverse-engineered torque specs for. Not so great news: the clunking noise I thought I had in the front, is actually coming from the back on both sides. I took one out to check the setup and everything looks as stated in the videos and instructions the kit came with. I did connect the top strut without the spring to see how much I could turn because this the top nut cannot be accessed through the trunk to adjust from the trunk. I had 2 more people with me (mechanics) and everything looked good. I installed the strut mount with the arrows facing to the inside of the car, the bump stop is in place and everything is torqued up to specs. The only thing I can think of is the ride height? I am at 0 mm (fully dropped). I did see that some x3m’s had clunking noises when fully dropped. Anyone experienced this at full drop? Are there any recommended settings? I got my kit from IND and they have been working with MSS to resolve. Just trying to see if anyone ran into this and did not contact tech support and got it solved. I appreciate all the time and help. |
02-05-2021, 05:34 PM | #188 | |
Rep 192
02-07-2021, 09:18 AM | #189 | |
Rep 56
02-07-2021, 07:16 PM | #191 |
12971
Rep 18,715
Unless H&R supplied a bumpstop replacement, it won't go any lower than the MSS.
02-09-2021, 08:50 AM | #193 |
Yngwie J Malmsteen
27
Rep 68
Drives: F93 M8 GC - G07 X7
02-09-2021, 10:21 AM | #195 |
Rep 3,507
Who installed your MSS kit?
02-09-2021, 11:20 AM | #196 |
Rep 254
02-09-2021, 12:00 PM | #197 |
Rep 8,815
Woah WTF? I would be pissed off with that noise. Have you or the vendor reached out to MSS yet? I have my MSS at home and when looking at the rear setup I can see where the small helper spring connecting to the perch could be an issue for noise. Ben said he presses the black helper spring into the perch before he installs it to the shock.
02-09-2021, 01:43 PM | #198 |
Rep 732
Hope you and your shop find an easy solution to that noise. When you do, please share with us
'23 F93 M8 GC ZCP - HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic (Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, ‘18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, ‘13 W204 C63 AMG - ADV1 5.01SL's |
