06-30-2022, 05:33 AM | #23 | |
Rep 79
Unless in competitive sport, chasing last few HP, hi-flow cat is just fine. Fit next size up in diameter if you so keen. It will be close to catless. It will take it longer to warmup, as they are metal based and higher flow. Not much gain down low in rpm range, maybe 100prm earlier turbo spool. But will pick up some HP closer to red line, with tune to support. Arguably, turbo to cat section of pipe is a lot more important. Design and diameter are the key. Another alternative is to get metal fabrication company to manufacture twin parallel cats assembly, thus halfling back pressure. This works only is space permits. Benefit is that this set up do not throw CEL. Stock car with tune is much better way to go that to go catless. My 2c, based of modifying exhausts for some years now. Last edited by 2Slow.; 08-25-2022 at 08:03 PM.. |
07-22-2022, 02:21 AM | #24 |
Rep 3
Drives: M235xi Convertible
Will high-flow catted downpipe pass emissions? Or is that a lost cause?
07-22-2022, 09:43 AM | #25 | |
Joint Chiefs of Staff
24199
Rep 190,807
The active autowerke downpipes use EPA-approved GESI cats; you are much more likely to pass emissions with these downpipes. Of course, each state has different laws, so it's not 100%.
07-26-2022, 11:29 AM | #26 | ||
Rep 26
07-26-2022, 11:55 AM | #27 | |
24199
Rep 190,807
I'm not allowed to post links on here, if you cant find it on the website, dm me for the link
08-10-2022, 01:52 PM | #28 | |
Rep 4,923
https://mad-us.com/mad-b58-downpipe-...chassis-supra/
08-11-2022, 04:16 PM | #30 |
Rep 606
08-12-2022, 10:28 AM | #31 |
Rep 19
08-13-2022, 08:24 PM | #32 |
Rep 606
08-18-2022, 03:04 PM | #33 |
Wawaweewa
90
Rep 132
Drives: 2020 BMW X5 M50i
i have fi exhaust catted downpipes on my m50i, ended up getting a CEL. its still smells a bit. If i had to do it again i would've gone catless. The smell is no different but the performance gain is noticeable.
NYCX5M50i63.50 |
08-18-2022, 08:09 PM | #34 |
Rep 193
The ActiveAutowerkes Are the highest quality on the market, I’m sorry to hear you got a CEL, I agree the sound and performance gains are awesome!
08-20-2022, 05:37 PM | #35 |
24199
Rep 190,807
08-21-2022, 10:59 AM | #36 |
Rep 19
For the m50i you can use the same downpipe a x5m has and all you need is the gasket and the v band clamp for each down pipe that connect it to the lower part of it. Look at x5m exhaust diagram and you will see what I am talking aboout. Otherwise it's the same exhaust just for the x5m it's 2 pieces with a gasket and vband and the m50i it's 1 piece.
08-23-2022, 01:33 PM | #37 |
Rep 606
01-02-2023, 12:16 PM | #38 |
Rep 21
Drives: Bmw g05 Bmw e66
02-14-2023, 01:00 PM | #40 | |
Rep 2,083
02-14-2023, 05:20 PM | #41 |
24199
Rep 190,807
They use one of the most expensive cats on the market; that's how they can guarantee the no check engine light.
Bottom1615.50 |
02-15-2023, 12:04 PM | #42 | |
Rep 2,083
Now, what other DP variants are there for the m50i that aren't that expensive? Thanks
02-15-2023, 12:21 PM | #43 | |
24199
Rep 190,807
02-15-2023, 12:33 PM | #44 |
Rep 2,083
2 days because of the active shutter delete not because DP. Dp will take longer to show. For me as I already need to delete the cel manually, i dont think its good investment to spend 3k on dp just because the cel. I rather go catless. Do you have any other DP options?
